Question about Refrigerators
Hi Folks -- I've got a must-do today warm fridge job that just came in, so here's hoping you can help me pronto. [Your TV champs have been doing wonders for me since day #1.] It's a Frigidaire PL8S67EESB5, and the freezer is remaining at 5F so far, but the fridge started warming up last night and is now at 55F and aiming for room temp of 75ish. I'm fairly new at teching with fridges so I need all the smarts you can give me, plus please tell me the 5 or 6 likeliest parts that I should buy and take with me. The owner pushed against the interior back wall of the freezer, but could not feel or hear the crunch of icing up, so please give me coaching that's based on both scenarios -- icing up and not icing up. Many thanks, Frank // Gramps // renthelp // BDCD928E
  • renthelp Sep 13, 2010
    Hi Caroldon --
    Many thanks for big help.
    I need you to help me clear up my understanding of a few of your above points :::
    #2 Would the auto defrost timer be located just above the ceiling of the refrigerator compartment?
    #2a Please aim me at a site on the Net where I can see a good pix of this unit that will show me clearly where each suspect part is.
    #3 Check what on the defrost heater coil?
    #4 Are you talking about the thermostat that clamps on to the coil tubing just as it enters the freezer compartment?
    @5 If I find that the problem is in the area of the auto defrost section, what parts should I suspect first? The auto defrost timer? The defrost coil heater? Other?
    Thanks again for your help. You have saved me some bucks already.
  • renthelp Sep 16, 2010
    Thanks Roniecon and Caroldon --
    I believe that you have a second email from me which I wrote for more clarifications, but if you no
    longer have it -- no problem, I'll rewrite.
  • 6,927 Answers
The freezer is the key,remove the inner panel and blower fan from the inside of the freezer compartment ,check to see if the drain bellow the evaporator coil is stopped up,and froze .If so,the drain has trash,and debris in it stopping the water flow and therefore freezing up.Also,check the deflector door in the unit,this is controlled by the control in the freezer,not the fridge compartment,set the control to a lower setting ,warmer if you will.This will cause the coldest air to be deflected to the fridge area,but it still will be freezing in the freezing unit.Then adjust the thermostat in the fridge compartmenttto a colder setting,this controls the cycling of the compressor.
Posted on Sep 14, 2010
  • 17,130 Answers
1. Possible that instead of speculating open the back to see for icing. If so does tto fan work or is blocked. If fan is not working chnage fan.
2. If fan is working into a choked chamber then the auto timer is not worrking.. checck auto defrost timer.
3. Check path of the air flow of the fan. Check on the defrost heater coil.
4.Possible that the thermostat setting is not reacting in the fridge section causing the icing. Check for broken leads.
5. Put fridge on test after 6 hours an check during this period if cooling is OK. If so the fault is in the area of the auto defrost section.
6. Confirm the test before you buy any part.
Posted on Sep 13, 2010
  • Donald DCruz
    Donald DCruz Sep 17, 2010
    Normally the timer is located at the rear bottom of the fridge, the heaters just above the coils that frost up.
    You can trace from the heater coil wires to the timer unit.
  • Donald DCruz
    Also you forgot to rate me. Please!
Why won't the temperature setting stay and it keeps going to hi temperatue
try a new thermostat ,a universal one will do the job providing it comes with a wiring diagram
Nov 20, 2011 | Frigidaire Refrigerators
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Hi, Hoping someone can help me as I just received my Quickie Aspire Power wheelchair today but they could not supply me with a manual. Can you help me getting one as I've tried looking online. Thank...
Netti Since Sunrise Medical is no longer making these chairs you might have to directly to them Call 1-800-333-4000 and ask for their help Good Luck Hope this helps
Nov 01, 2010 | Invacare Supply Group Invacare Pronto M51...
My fridge goes through warm cycles
hi , Glad to help you...
your freezer cabinet need to get all out and open the back wall.
  1. you have 2 element that can be check one is the heating element , two is the thermostat.
  2. you need a volt meter to check them.
  3. if the frost is all over the coils then one of the element i told you before, is bad
  4. if the frost is in one area not all over then you got gas leak.
  5. good luck 911service today . com
  6. I hope you find this Very Helpful and best regards!
Jan 05, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Warm fridge cool freezer
Hi folks,
IS, the freezer so packed full with packages that they are covering the air vents in the freezer that must be open to share the circulation with the fridge?
Let me know!
If not keep calling the server and pay him only when he fixes it!
Sep 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
