Question about HP VM114UA notebook
How do I remove the defective display screen and install a new one for the HP G71-340US notebook?
  • 140 Answers
Hi, Plz click the following link for the details. Here it showing HP Pavillion dv900 screen replacement.. All the model having smiler steps to replace the screen
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-hp-pavilion-dv9000-laptop/
Posted on Sep 13, 2010
2 Suggested Answers
  • 95 Answers
SOURCE: Install display screen for HP G71-340US notebook
http://computershopper.com/laptops/howto/replace-your-laptop-screen
Posted on Apr 09, 2010
Anprguru@hotmail.comProblem with a HP 6735s, when booted the screen displays as if the horizontal hold is defective. However I have tried attaching an external monitor and the problem is NOT reproduced. I...
The sync. processor within the display is faulty and unfortunately an integral part of the screen.
New screen I'm sorry to say.
Ebay have a selection of prices.
Jan 01, 2011 | HP Compaq 6735s Notebook
Hp g60t went into hibernation last friday it wouldn't come out of hibernation so i had to hold in the power button and shut down. laptop turns on but no video now the screen stays black. i tried a reset...
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the steps provided below.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now turn on the notebook and check for the issue. If the issue persists, then remove and reseat the memory modules of the notebook and check for the issue.
Step 2: Remove and Reseat the Memory Modules
You can refer the service manual provided below for information to remove and reseat the memory modules of the notebook.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer page no: 52 & 53
NOTE: PDF manuals require the Adobe Acrobat Reader for viewing and printing.
Further, if the issue persists after performing the above steps, then the issue could be due to hardware malfunction of the video card or defective LCD display screen of the notebook. Hence, I recommend you to connect an external monitor to the notebook and then check whether the display works fine on external monitor or not.
Step 3: External Monitor
You can follow the steps listed below to connect an external monitor to the notebook.
1. Turn off the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
At this time, please follow the instructions mentioned below for switching the display to the external monitor:
The notebook's video card supports three modes. Built-in screen only; external video only; and both on simultaneously (mirrored). If you're not seeing the image on the desired device(s), the notebook's video card is probably in another mode. Press FN + F4 to cycle through the display options: Notebook display, External monitor, both.
If you press FN + F4 once, the external monitor will display & there will be no Notebook LCD display.
If you press FN + F4 twice, the external monitor will display & there will be some shading on the Notebook LCD.
If you press FN + F4 thrice, both Notebook LCD & external monitor will display.
If the issue persists on the external monitor, then this could be due to defective video card on the notebook. However, if the display on the external monitor is fine, then the issue is with the LCD display panel of the notebook. In either cases, the notebook requires a detailed onsite diagnosis by a service technician.
I believe the information provided would be helpful to isolate the issue with your notebook.
Jun 07, 2010 | HP G60t Notebook
Monitor does not come on when laptop is switched on
This issue could be due to presence of static charges on the notebook or hardware malfunction of the display screen or defective video card on the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check for the issue. If the issue persists, then connect an external monitor to the notebook and check for the issue on it.
Step 2: External Monitor
You can follow the steps below to connect an external monitor to the notebook.
2. Connect the monitor cable from the external monitor to the monitor port on the rear/side of the computer.
If your notebook is covered under the HP warranty, then I would suggest you to contact HP to get the notebook repaired under warranty from HP.
Jun 01, 2010 | HP Pavilion dv9000z Notebook
My hp dv4-1435dx screen is blank.It was on then it froze and then went blank. I have tried to fix it by removing the battery and replacing it a number of times. It comes on when started and plays the...
This could be due to presence of static charges on the notebook or hardware malfunction of the video card or defective LCD display screen of the notebook. To resolve the issue, perform the following steps.
Step 1: Hard Reset
This will discharge the static charges from the notebook. Now check if the display works fine or not. Incase, if the issue persists, then the video card or LCD screen must have gone bad, and to isolate the same, please connect an external monitor to the notebook and check for the display on it. You can follow the steps below to connect an external monitor to the notebook.
If your notebook is under HP warranty, then contact HP to get the notebook repaired for free of cost.
Jun 01, 2010 | HP Pavilion dv4000 Notebook
My hp notebook dv2201ca power on by itself, but lc...
Hi, to isolate the issue perform the following.
Step 1: Hard Reset
Step 2 :External Monitor
May 20, 2010 | HP Pavilion dv6000z Notebook
I bought a new hp dv2000 laptop 2 yrs back. till date it was working very fine sudenly yesterday morning when i powered on the laptop thin lines appearing on the screen display... i tried to on the system...
honestly the problem is in your lcd display. it is already defective lcd. replacement of lcd is much expensive. it would be better to buy a new unit rather than replacing the lcd.
Feb 08, 2010 | HP Pavilion dv2000t Notebook
HP laptop lcd replacement renders 4 split screens
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
Dec 19, 2009 | HP Pavilion dv6000z Notebook
No display
Basic diagnostics when you experience display problems
Display is black?
Does the external vga output works?
Yes >> only your display assembly is defect
No >> your mainboard is defect
Mostly it results in the replacement of the complete mainboard.
Last things you can trie is flash a new bios version using the the external output if that works.
Nov 23, 2008 | HP Compaq NC6400 Business Notebook
HP VM114UA notebook Logo
474 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
