Car won't start went i turn the key clicking sound, lights work raidio works seem battery is fine.
sicaudio
  • 96 Answers
SOURCE: Car wouldnt start. Just a
check the main wire from the battery to the starter 1st if it is ok remove the starter and take it to any major parts store and them retest it on a bench machine (they do it free)
Posted on Aug 01, 2008
  • 77 Answers
SOURCE: My 2004 530i won't start.
If you hear a mechanical hum then its either something with the starter or the battery. Charge your battery and see if its just a little too weak to turn the engine over. If that doesnt fix it, then you might have to replace the starter. Unless there is a serious mechanical issue, your engine shouldnt be the reason the starter can't get it to turn over.
Posted on Oct 19, 2008
  • 6 Answers
SOURCE: car won't start, battery fine, just hear clicks
Even though the lights work, the battery may still be just short on power to turn the motor over thus the clicking. Try charging the battery or jumping, if you still get a clicking it would be the starter solenoid. Considering the year you may just want to replace the whole starter.
Posted on May 18, 2009
  • 1348 Answers
SOURCE: Engine won't start. Dash lights flash rapidly when key turned.
the battery says 12 volts but may be dropping to 4 or 5 under a load...i would suggest jumpstarting the car and see what happens.the battery should read in the high 12 volts and not less than 9.5 under cranking. the dash lights go out on your car when starting,and the alarm will go off ,and disable the ignition if the voltage is too low in cranking the car because the computer will shut it down and activate the anti theft.....check your battery posts are tight. best of luck
Posted on Jul 22, 2009
  • 784 Answers
SOURCE: C230 Key Won`t Turn the car only went i use 14.3V
The starter is turning only when the solenoid close the contact to deliver the current to the starter . When this happens it then turns the bendix to engage with the flying wheel to start the engine.
The reason that you need higher voltage to have correct needed current going through the contact of the solenoid, hence the starter. The contact is corroded or rusty due to high spark at high current at every start time causing high resistance. V=IR the R resistance of the contact now is high so it need higher voltage (14.3 vs, 12.8 V) to deliver the same needed current for the starter.
Unfortunately, the solenoid is integrated with the starter, so you can not just replace the solenoid without replacing the starter.
If you can find the new battery holding at 14.3 V as you mentioned, then that is an economical solution since replacing the starter is costing more.
BTW where can I find the battery at 14.3V in case my friend's car has a same problem?
Posted on Jul 27, 2009
Clicking sound but engine won't start
This actually does sound like the battery is low on charge. A battery which is quite low on charge will still light the headlights and run many other electrical accessories, but will not engage the starter (which requires much more power than other accessories).
I would start by making sure that an electrical device, such as interior lights, glove box lights, trunk light or something else has not been left on. Then carefully jump start the engine. It is also possible that the battery might need to be replaced for not holding a charge.
Nov 25, 2012 | 2006 Subaru Outback
When I drove home from work friday everything fine. When I went to start teh car today I just get clicking sound does not turn over. Radio and lights work. 2006 Sonata.
Battery is too low to turn the engine over. Get it jumped and drive it to AutoZone. They will run a free diagnostic and tell you whether it's the battery or the alternator.
Jun 25, 2012 | 2006 Hyundai Sonata
Battery is new, engine won't turn over.
The voltmeter should only go as high as 14-15 volts when the engine is running. I would check for a poor connection between the battery and starter.
Oct 10, 2017 | Jeep Grand Cherokee Cars & Trucks
Car won`t start at all. Just a fast clicking sound from the engine when the ignition key is turned. The lights, radio etc all work fine.
Low battery or bad connection at terminal. Try jumping from a car that's running. If it still doesn't crank, then you have a bad solenoid.
Aug 28, 2010 | 2001 Hyundai Accent
The car wont start the bary is ok as the raidio
Your starter selenoid is bad replace the starter if its all one assembly
Jan 07, 2010 | 1988 Mazda 626 Turbo
2000 Cavalier won't start, making fast clicking sound w/ ignition
Low voltage will cause the problem you are having,get the battery charged,and then have the alternator checked for the correct out put,13.65 to 14.25 if it is not in this range give or take a couple of volts,replace it,I would have the battery replaced also,so you won`t have the problem again.Have a shop replace the battery,if you do it yourself,the memory could be erased if certain measures are not performed.
Nov 14, 2009 | 2000 Chevrolet Cavalier
Got in my jeep turned the key and nothing! it will not start.
remove the small wire going to starter motor solonoid and put a test light on it --if it doesnt light up when key is turned then work your way back till you find the fault,relay? contact switch on ignition??
Apr 11, 2009 | 1995 Jeep Grand Cherokee
I Starting problem...
if you notice this van should have a statrer solenoid on the fender as well as on the starter, clean the body of the solenoid on the fender area and make sure that the ground cable is secure and tight do not wiggle which is just making it loose if it is so go under the vehicle and make sure that the cable is tight
Aug 22, 2008 | 1997 Ford Econoline
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
