Screen brightness is dull and about half or less of normal. And the tv makes a pop once sometimes twice when turned on. but comes on and has sound and picture.
  • 5 more comments
  • mike ashworth Sep 13, 2010
    not the tv expanding due to heat its a pop in the elecyric part of it. the screen is very dull but everthing else works fine.
    HP PL5060N 50'' PLASMA
    DITTO
    BY FLAT OR SWOLLEN CAPS WHAT WOULD BE THE LOOK OF THEM? TOP PUFFED UP SIDES? BURNT? NOTHING ON EITHER SIDE HAS ANY OF THAT UNLESS I'M LOOKING FOR THE BIGTIME BULGE OR BURN. NO BLOWN FUSES ALL WHITE.
    [IMGhttp://i841.photobucket.com/albums/zz332...[/IMG] [IMGhttp://i841.photobucket.com/albums/zz332...[/IMG] [IMGhttp://i841.photobucket.com/albums/zz332...[/IMG]
    i tried to send you pics lmk if ya got them and what you need to look at on it.
    i have a meter where do i test/ please be firm on this, and what setting do i set the meter on
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be with a component going bad inside the unit, please post back with the manufacturers name and model no# of the unit.
Thanks
Rylee
Posted on Sep 13, 2010
  • 3 more comments
  • Rylee Smith
    Rylee Smith Sep 13, 2010
    The issue seems to be with the Y, Z and the control boards should also be checked. To start with you?ll need to open the back of the unit and check these boards for any blown/swollen/flat capacitors. Y board is located on the left looking from the back and Z board is the board that is on the right hand side and controller board is the one located next to the power supply board. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Thanks for the pictures, just checked capacitors seems to be fine so the issue is either its not getting enough voltage, please test the connectors for VA, Vscan voltages
  • Shahid Electronics
    Shahid Electronics Sep 21, 2010
  • Rylee Smith
    Rylee Smith Sep 21, 2010
    @ wellcum- Have you ever seen a Projection/Plasma TV? And yes get yourself checked by a good Psychiatrist :)
    Shahid Electronics Sep 23, 2010
    ....lol
  • 11,800 Answers
I'm assuming that you have tried to raise the level of the brightness from the image settings and it didn't helped.
In that case this is a hardware problem:
 - if the tv is a old CRT type or a plasma then it's a sign that the screen has aged. This is terminal since replacing the screen would cost as much as a new tv.
 - if the tv is an LCD then the CCFL tubes that generate the light are either undervolted because the inverter powering them is faulty or the tubes themselves are aged prematurely. Replacing the failed parts will cost you around $200.
 The sound is caused by the expansion of the plastic case of the tv, extremely common on tv's that heat a lot like plasma's and CRT's. Nothing to worry about.
  • Azrael SRL Sep 13, 2010
    If you are sure it's in the electronics then it's a discharge because a board is deformed and too close to the ground. Not very dangerous but it may wear out other components in the long run so take the cover off start the tv in the darkness and look for the spark. When you have fond its origin just move that part away from any other parts of the tv.
  • 10,515 Answers
The pop noise and dull picture confirms that there is an internal failure. It would be really tough to speculate the exact cause. However, in most of the cases it is due to a bad IC in the power supply unit.If you have experience in repairing electronics, could read schematics and would be able to keep precautions, you could open up the TV. Locate the power supply board and on that you could see some bulged / fused / swelled / leaked capacitors. De solder them and buy the same value caps from Radioshack or Fry's. Re solder them properly and you could fix the problem.
Other than this, it needs more advance troubleshooting which would need other testing equipments.You could revert once you check the power supply board and we could further continue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • taran_2005
    taran_2005 Sep 13, 2010
    Thanks for your response!!
    I understand your concern, however there is no reset button. If you could provide me with the make and model, i could tell you where you could buy a service manual and also guide you to fix this problem. Obviously, you need to take care of all the precautions.
    Hope i helped you.
Why is my screen is very dull?
Not knowing what make and model computer you're referring to makes it difficult to give you a specific reason. A couple known reasons for any laptop to have a dull screen are: 1. The brightness has been turned down (you should be able to turn it back up pressing the function key and one of the "F" keys simultaneously) or 2. The lamp and/or inverter are wearing out and producing less light output (which would require a screen or inverter replacement to correct)
Apr 28, 2014 | Dell Computers & Internet
My Vizio GV42L is fading to a dull whitish color after 2-3 minutes. I can still see the TV program I am on but the screen just goes to a dull whitish color. No boxes or anything popping up. Basical
Either its back light inverter board, or, the LVDS cable has the fault. First try by re-seat the LVDS cable, and check. Thus you can make sure about the fault. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 06, 2013 | Vizio GV42L 42 in. LCD Television
Hi everybody, I have a Philips plasma 50PF7321. Two main issues. Sometimes I only get half the screen on ( bottom half). In this case I get a "cut" image and not a "compressed" image, I...
It sounds like you have a problem were the Y sus/buffers board (the one on the left ) has issues with the connectors to the screen need unpluging cleaning and putting back
Apr 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
shad
Jan 04, 2009 | Sharp R-1480 Microwave Oven
The screen comes on fine but then dims????
Hi there, I have the same monitor, but mine has a broken screen. It's probably the inverter chip, that makes your contrast bright.
Jan 03, 2009 | Westinghouse L2410NM 24 in. LCD TV
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv turns itself off
hello. it sound's like you have a picture tube that is shorting out from a something arking in side of your set.!!! eather on the (CTR PIN COUSHION).!!! OR ON THS CHASSIE.!!! THAT WHAT MAKING IT DO THAT.!!! TIME TO GET A NEW SET.!!! HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Aug 11, 2008 | RCA 20F511T TV
Tv making popping sound
Turn down the volume and see if you still hear it,a loud pop or snap could be high voltage call your servicer in your area ASAP
while its under warranty and have him check the high voltage circuits for a intermittenting pop or snap.And have the model # ready!! Good Luck!
Dec 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Nov 21, 2007 | Televison & Video
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
