Question about Epson TM-L90
EPSON TM-L90 - Successfully sending and printing label data as required. However after printing a few labels the alignment is wrong and the label is printed across 2 labels. What is the correct ESC/POS command (Hex) to send to get it to move to next label / black mark?
Rain041304
  • 63 Answers
SOURCE: My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Posted on Feb 12, 2008
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
  • 99 Answers
SOURCE: driver TM-L90
Hi...here is the European download page for this model, ...hope it helps!
http://content.epson.de/en/rsd/service/index.1022.htm
Posted on Jun 03, 2008
  • 7 Answers
SOURCE: TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
Posted on Aug 13, 2008
SOURCE: Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Posted on Feb 24, 2011
Paper feed to far for labels
You should adjust the shutter as well to the size of the paper. Another thing is you can manually select the paper type under the printer settings. Go to Printers and Faxes > Properties of your default printer and manually select the paper type.
Sep 30, 2008 | Epson TM-L60II Thermal Printer
Every time I print it suddenly stops in the middle of printing and says "error".
hi there
the only one i could find is TM-U220 , which falls under the TM-U200 series, as stated in this link.. i i advise you to get in contact with Epson directly , as they are the only ones who can assist you with this issue..
I hope this serves you well
http://pos.epson.com/products/TM-U220.htm
http://pos.epson.com/developers/index.htm
Nov 04, 2010 | Epson TM U210PD Matrix Label Printer
We are using the Zebra 170XilllPlus printer for printing rolls of labels which they have some preprinted portions on them. However, after we printed the first label of a roll successfully the next and all...
Make sure the pause light is on and press calibrate. See if this calibration solves the problem. If not align the media sensors (top and bottom) to a position that is aligned with the least amount of preprinted data and calibrate again. Print configuration Power on while holding cancel key for 10 seconds. Use the config to help troubleshoot. Make sure the sensor type matches the media. Download user manual at zebra.com.
Nov 04, 2010 | Zebra 170XiIIIPlus Thermal Label Printer
Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Feb 24, 2009 | Epson TM-L90
I need To Download The Epson TM-T90P Printer Driver
http://www.fixya.com/support/r672065-epson_printer_drivers
Nov 05, 2008 | Epson TM T90P Label Printer
Driver TM-L90
Jun 03, 2008 | Epson TM-L90
Epson TM-T88IV causing small margins when printing to Lexmark 250dn
PRINTER WORKS BUT prints the moment I scan a item,WHICH I DONT WANT. I WANT IT TO PRINT ONLY IF I NEED TO
Aug 03, 2007 | Epson TM-T88IV Label Printer
??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Jul 01, 2007 | Epson TM-L90
Epson TM-T90 thermal printer
your print driver is printing in graphics mode or in reduction mode. disable print spooling, disable A4 reduction or use a faster driver like the epson advanced driver or my fav the generic text only (super fast)
Jan 30, 2007 | Epson TM T90P Label Printer
Epson TM-L90 Logo
123 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
