I have installed xp on computer with a motherboard that has an ide and a sata header. The dvd is connected to the sata header but computer doesn't recognise it. I understand that I should have installed sata drivers at installation but sadly thats too late now. I don't want to go to the trouble of starting all over again and would like to install these now. I have attempted to do by installing the drivers from the main board cd installation disk but this doesn't work. How do I integrate these now and get xp to recognise the drive.
  • 2 more comments
  • viner Sep 13, 2010
    Yes I have been into the bios and under the heading, Standard CMOS headings, this is what I see:-
    IDE Channel 0 Master WD 3000JB
    IDE Channel 0 Slave Lite-On DVDRW LH
    IDE Channel 1 Master None
    IDE Channel 2 Master None
    Floppy Drive A 1.44 MB
    Halt on all, but keyboard.
    You will note that the Sata Drive/Header is not listed. I am told that this is a known problem, ie........ XP doesn't recognise sata having installed drivers after xp installation. However, while this appears to be a known problem, I have been unable to find the answer.
    Thanks for the quick response. I see where your coming from, I think. You see, I dont have a problem with either of these two drives listed as they both work fine. As I have stated already, there are two headers on this board. The second is a sata header and its this header that the sata DVD is connected to. So why is this not shown in either CMOS or my computer. Maybe there is something I am missing here from understanding your response so I hope you will be patient with me. I know we will get there in the end.
    Again, thanks for the prompt reply. Can we put this on hold for a while as I will away for a few days and would love to return to this when I get back.
    Kind regards.
  • viner Sep 15, 2010
    Delighted at the quick, efficent and informed service.
    Many thanks.
    President:
  • 1,851 Answers
Have you checked the SATA settings at the bios? Check the bios settings and then try to reinstall the drivers from the cd rom.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 13, 2010
  • 18 more comments
  • Stelios
    Stelios Sep 13, 2010
    As I can see from your post your DVD rom is listed as slave IDE device on the 1st channel, how do you suppose that it's SATA. Take a look at the connectors for IDE (also known as PATA) and SATA.
    If your device is IDE, check the jumpers for master - slave so that the hard disk is master and the dvd rom slave.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    Sorry, it was my fault that I didn't noticed that you use 2 dvd rom drives. Well back to bios check for a section that emmulates SATA as another device. I can't be more precise cause I don't know your motherboard's brand / model. Try for the emulation or post me back the details for the motherboard to check for you.
    Thanks and regards
    Stelios
  • Stelios
    In the meantime post me back your motherboards details for me to research.
    Waiting clarification, don't hesitate to post.
    Thanks and regards
    Stelios
    Problem solved, thanks to some clues in your posts. Before I contacted you, I was under the impression that the two headers with no drives attached were indeed IDE headers until I looked into peripheral devices and I spotted that SATA was set to IDE. I now know that SATA headers had been recognised but the attached DVD Rom wasn't. You mentioned jumpers in one of your posts so I removed the drive and changed the jumper from master to slave. I booted computer and it hung for a while at the first SATA header indicating that it was looking for drives. As this hadn't been hapening before, I figured on on the right track. I then removed the drive again and reset the jumpers to csel, and bingo, it recognised the drive and problem solved. I wish to thank you for your valued assistance and I am accepting your solution. But I will ask you one more question:- Since this was a seperate channel, ie, SATA, why did it not work on either master or slave settings? This info will give me a better understanding of how to set up another motherboard in the future. If you can answer in another post, I would be delighted, if not, I am happy. The problem has been solved to my satisfaction.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Many thanks,
    Viner.
    Problem solved, thanks to some clues in your posts. Before I contacted you, I was under the impression that the two headers with no drives attached were indeed IDE headers until I looked into peripheral devices and I spotted that SATA was set to IDE. I now know that SATA headers had been recognised but the attached DVD Rom wasn't. You mentioned jumpers in one of your posts so I removed the drive and changed the jumper from master to slave. I booted computer and it hung for a while at the first SATA header indicating that it was looking for drives. As this hadn't been happening before, I figured on the right track. I then removed the drive again and reset the jumpers to csel, and bingo, it recognised the drive and problem solved. I wish to thank you for your valued assistance and I am accepting your solution. But I will ask you one more question: - Since this was a separate channel, i.e., SATA, why did it not work on either master or slave settings? This info will give me a better understanding of how to set up another motherboard in the future. If you can answer in another post, I would be delighted, if not, I am happy. The problem has been solved to my satisfaction.
    Many thanks,
    Viner.
  • Stelios
    Stelios Sep 15, 2010
    Your case was a little comlicated, a hope you will never come up again with a similar. The bios settings was priority at the SATA channel but the SATA channel has no devises (in fact it was wrong setup from the bios) The next boot device was IDE. At the IDE cables either we set up by the jumbers the master - slave devices or we use CSEL (for Cable SELection) and the bios assumes that the last device on the cable is the master.
    I hope I cleared up the things a little.
    Thanks for the acception.
    Stelios
  • 977 Answers
Hey!
According to your replies, it seems that you were told only half of the solution... The SATA controller settings is within the BIOS settings, but it's supposed to be under Advanced Settings/Peripheral Settings/etc. - depends on your BIOS type - and NOT under Standard BIOS Settings.
The way I see it (I might be mistaken, though), the BIOS controller is currently disabled, therefore your DVD is not recognized.
I can tell you for sure that no re-installation is required! The only scenario in which it is necessary is when the SATA mode has to be changes from IDE to AHCI - but this has nothing to do with your case, as I see it!
Anyways, can you specify your motherboard model? It will help me help you better.
Waiting for your reply,
Pelu.
I was unable to connect LG DVD R/W to mercury KVM800M .Which one model of DVD R/W supported to it?
IDE (PATA) or SATA.
There are headers on the motherboard for each style.
Which Operating System are you using?
http://www.ehow.com/how_8578195_install-sata-driver-after-xp.html
I see it is a DVD 'burner'. (DVD-R/W)
Do you have burner software?
InfraRecorder is free,
http://infrarecorder.org/
http://infrarecorder.org/?page_id=4
You can click on each screenshot on the link above, and enlarge it.
http://en.wikipedia.org/wiki/Infra_Recorder
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 23, 2012 | Mercury KVM800M Motherboard
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
How do you install an lg gh24ls70 dvd rewriter into a compaq presario computer runnining windows xp that is 8 years old
If it's a sata connection on the drive you may not have any sata sockets on the motherboard. You will need something like an IDE to Sata adapter like this one: Adapter.
Feb 18, 2012 | LG Computers & Internet
Can I installing a sata DVD Burner in presario SR1219UK
Yes.
Also, the beauty of SATA is that you can connect to ANY of the SATA headers on the motherboard, and BIOS will find the device.
(A SATA harddrive is usually connected to SATA 1 header. However it DOESN'T matter )
Regards,
joecoolvette
Feb 06, 2012 | Computers & Internet
Computer BIOS recognizes the SATA DVD Rewriter but Windows XP does not. The drive opens the loading door but it does not appear in the Windows XP explorer (My Computer).
Windows XP doesn't nativey support SATA. Check in BIOS to see if your motherboard supports sata to IDE emulation.
Comment back if you need further assistance.
Aug 17, 2011 | LG GH24LS50 Super Multi DVD±RW (±R DL) ...
My motherboard is 880gm-ud2h. I have a Sata 3 hard disk installed on it. After installing windows XP 2, my system works fine. But once i pull out the power and open again my computer, Windows XP does not...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 23, 2011 | Gigabyte 880GMA-UD2H Motherboard and AMD...
I have a an INTEL Motherboard Model DH55HC. I am installing a basic Internal DVD writer (DVR-A18M) Interface ATA/ATAPi-7. I have the power cable from the POWER SUPPLY in the correct plug. I attach the...
That motherboard doesnt support ATA it supports upto 6 SATA devices which is actually better and faster. You will need to take your DVD/RW back and ask to swap for a SATA and also make sure you buy a SATA cable and good thing is these are actually cheaper and faster. Its actually a very nice motherboard dont be disappointed. Cheers from Scott and plz vote
Jan 24, 2011 | Intel DH55HC Motherboard
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
ASUS P5QC does not detect any devices... I have a HD and a DVD hooked up. The jumpers are set to normal but they are connected to the MB with one cable. Does it need to be a master slave setup?
Yes, since you are using two IDE drives on One flat ribbon cable, you need to set the harddrive as a Master drive, and the optical, (DVD), drive as a Slave drive.
When two IDE drives are installed on one cable, BIOS needs a way to find the drive that has the O/S, (Operating System), then the optical drive.
Would recommend you buy a SATA optical drive, as soon as you can afford it. SATA DVD burners aren't that expensive.
Your motherboard is set up for SATA, and SATA is WAY faster than IDE. (IDE is also referred to as EIDE, ATA, and PATA)
Then of course a SATA harddrive, and a fresh genuine copy of Windows in the future.
SATA doesn't care where you plug in a drive, and doesn't care which drive connects to what SATA header. It will find that drive. You can connect any SATA drive, to ANY SATA header on the motherboard.
Having two IDE drives such as an IDE harddrive, and an IDE optical drive on the same cable, S-L-O-W-S your computer down! BIOS has to look to see which drive has the O/S first, then it will look for the optical drive.
Thought I would include two links that tell you, and show you how to set jumpers on the jumper pins, on an IDE harddrive, and IDE optical drive,
1.Harddrive:
http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.Optical drive:
http://www.youtube.com/watch?v=lldXwgPabhE&feature=channel
Should my solution have helped you, feel free to rate it.
Jul 13, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
