Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
What size water line - GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
    President:
  • 2,468 Answers
1/4 inch plastic or copper line
Posted on Sep 13, 2010
What size water filter should be used for this ice maker Frigidaire IM115?
Thank you for your post, friend!
Based off the information you have provided you need to know what size water filter needs to be used for a IM115 inside of a Frigidaire refrigerator. Typically, the IM115 needs an in line water filter and that would be attached on the line. If you need additional information on that part I would recommend contacting the manufacturer for assistance. Hopefully this is helpful. -Matt
Feb 12, 2015 | Frigidaire Refrigerators
What size water line do I run for my kenmore all freezer ice maker
If it's a new in-wall run to it, standard 1/2" is fine. From the wall to the freezer you can do 3/8" or 1/2"
An ice maker doesn't use a lot of water so you can consider it a low demand system. If you're connecting from wall to freezer most hardware stores have premade hoses; just like the water hoses for a washer or a toilet.
Jan 24, 2015 | Kenmore 18.6 cu. ft. Built-In All-Freezer...
I just bought a Bosh Ecosense dishwasher. I need to know size of the water supply line and drain hose?
The size of the water supply line is 3/8th inch (10mm)
The drain line is 7/8th inch (22mm)
Oct 10, 2011 | Bosch Dishwashers
What is a 1/2 inch or 3/4 inch water tap? For washer n side by side fridge with water dispenser.
As standard size for most fridges as much as we know they take 1/4 inch water lines
As you could buy fridge water line kits from appliance service shops
Jun 07, 2011 | Bosch Washing Machines
The water pressure for drinks is really really slow. checked all the lines and they all seem ok. Just bouth a filter so it should be that. Any suggestions
check the valve where the water line is connected to the house water supply,if it's one of those self tapper valves it could be the valve is bad or the hole has to be opened up one size more.shut down the house water supply then go to the back of the fridge,disconnect the water feed line,stick it in a bucket and have someone turn the water back on,if it's coming out slowly there then you know it's that valve,shut the water off again,remove the tapper valve and drill out the hole one size bigger and see if that helps,if it doesn't change the valve.if the water is coming out with force then you most likely have a bad water valve on the back of the fridge,sediment gets in them and plugs them up and the valve should be changed out.
Apr 19, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
There is not enough water pressure to properly operate. (House pressure is unchanged..)
Make sure you have the appropriate size inlet water line. if it is to small it won't provide the necessary amount of water. This is usually the problem, you may have a pump issue, but check the inlet line size first
Dec 22, 2010 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a model 109163. I'm trying to pump water from a creek. The suction hose is about 6 ft below the pump and 12ft long. The output hose is running about 300 ft at a gradual incline to about 10 ft. My...
In order for the pump to **** up water, it must discharge air. Try this. Install a hose bibb (faucet) in the discharge line over top of the pump. Fill the pump housing with water, turn on the pump and open the hose bibb/faucet until full water flow is established. Almost all air should be out of the pump and suction line at this time. Now when you close the hose bibb/faucet, the pump will have plenty of pressure to fill the long discharge line.
Suction line should be 2-1/2 inch if that is the pump suction size.
What size is your discharge line?
There should be a check valve/foot valve on the end of the line in the creek to keep water in the pump once it is primed.
Gary
Dec 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
We have a rinnai tankless water heater in a builing with 36 apartments and the tenants have been complaining of cold showers. what do we need to do to get hot water all the time for our tenants?
It will take a good plumber to calculate that, and he/she will need info like size of water line entering the building, size and material of hot water lines to apartments, number of baths in each unit, size and capacity rating of current water heater, and maybe more. Chances are that the water heater isn't big enough to keep up with demand, especially in cold weather.
Dec 07, 2009 | GPS
I would like to know what size water hook up ineed to hook water line to fridge
It will either be 1/4 inch or 3/8 inch. It depends on your manufacturer.
Jul 11, 2009 | Refrigerators
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
41 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
