I have a samsung mfp 65x series fax machine and right now it only prints the fax receive report after an hour but i want to set it in a way that it prints the fax receive report immediately when the fax is send
DJYar
  • 41 Answers
SOURCE: wont' send a fax
In my experience, anything plugged up to a phone line can be some of the most susceptible to electric discharge. Thunderstorms, power surges, brown out, all of these can cripple or kill a fax machine. When I saw this symptom on a fax, 9 times out of 10 it was caused by a power surge of some sort. The line error is most likely the machine's outgoing line has been zapped. The 775 (and it's father, the 770) are some of the most straightforward faxes I have dealt with when it comes to faxing. There is no internal setting that I am aware of that would inhibit the sending of faxes. I would double check the transmission report to make sure that the machine isn't doing something weird like adding extra digits to the numbers you are dialing. It would still be worth your time to try a few things, though. I would plug the fax into another phone jack using a different phone cord if available. Also try using the fax as a telephone, call a number and see if you can connect. If you can, make sure both parties can hear each other clearly. If you can not, the machine will need to be replaced.
Posted on Aug 23, 2007
Soulvisitor
  • 1113 Answers
SOURCE: black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Posted on Dec 03, 2007
SOURCE: setting up fax machine to receive
Scanned documents are very fuzzy ( not readable) even when set on 600 dpi. What can I do? I had a F50 and had no problems.
Posted on Mar 04, 2008
  • 5 Answers
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Posted on Sep 08, 2008
  • 215 Answers
SOURCE: display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Posted on Feb 18, 2009
We keep receiving a T.30 Protocol Trace Report with the "Type: Receive" and "Result: Communication Error (17)". How do we figure out what this means? Thnaks.
If this is printing out and consuming a lot of paper it can get annoying. This report is intended for a technician to trace problems with your machine. The report basically tells you that your fax attempt failed and gives all the technical settings. To the average user this is meaningless. The print feature for this is normally turned off, but I have seen a few cases where the default was set to print. Under the diagnostics menu, find the T-30 error setting and set it to never. Check the firware on your printer to make sure it is current. Print the configuration page and check the firmware version on the front page. The current version is 48.181.8. There are many modem fixes included with the firmware.
May 23, 2011 | HP® LaserJet M5035 MFP Laser...
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I would like to print a received report. How do I do that?
if hour model is sf 5100P you can print but no P you can not
Mar 02, 2011 | Samsung SF-5100 Plain Paper Laser Fax
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
WE have a canon laser class 700 series fax machine. Is there a way to get an automatic confirmation to print after something has been successfully sent?
Press adisional funcktion button,select report settings,select TX report set it to "output on"
Then you will be able to receive the report for every fax you sent.
Dec 18, 2008 | Office Equipment & Supplies
FAX CONFIRMATION PAGE
Touch ADMINISTRATION then touch CONFIGURATION PAGES then MENUMAP and that will print a guide for you to look for FAX REPORTS and when to print them. You can also have a thumbnail put on a report
Aug 06, 2008 | HP LaserJet M3027x MFP Printer
Not printing faxes
It appears you have a faulty connection. Make sure the line is connected properly, also check to see if you have your settings set to Fax/Fax Receive mode.
May 27, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
