Question about Kenmore 73952 Gas Dryer
Gas dryer not turning
How do i locate the drive belt on my gas dryer, too replace it as drum is not turning
  • 2 more comments
  • rbrame1 Aug 28, 2008
    The dryer drum won't turn when you push the start button.
  • cruzer47 Sep 03, 2008
    i have gas dryer which needs a new belt. i have the belt. i have it removed but how do i get it back on? do i have to remove the drum, because i can't get it over the drum? it's a frigidaire, propane gas dryer, model -- DWXR463GGWW
    thanks
  • Anonymous Sep 29, 2008
    dryey turns on but will not rotate
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please post your brand and model number in order to give instructions on how to disassemble.
    Novelist:
  • 161 Answers
I can explain how to do this but I would suggest going to the library and looking for a generic repair book with diagrams. It's hard to explain but very easy to do. Most Whirlpool, Kenmore and Roper dryers are basically the same as far as belts and moving parts. The only difference is the features. What you neet to know applies to both gas and electric dryers. You should also replace the idler pulley and both rear drum rollers while you are in there. One of these probably caused the belt to break. Your dryer will run so quietly after this you will hardly know it's running You will also need the diagram on the belt package to replace the belt as it is very tricky the first time especially if you haven't seen it in place. Replacing all the parts I mentioned will cost around $20 - $35 and take about an hour. While you have it apart clean out all lint and check vent hoses and outside damper. DO NOT USE FLEXIBLE PLASTIC DUCT PIPE!!!!!!! It is now against most building codes for darn good reason. It's a fire hazard!
Posted on Jun 29, 2008
The motore will run, but it is not spinning. The motor smells hot when it is running and not spinning.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt.
Here is a link to the belt.
Jan 06, 2011 | Amana ALE443RAW Gas Dryer
Diagram for setting up belt on drum tenion
Replacing the Belt
  • Step 1 Put the dryer door-side down on the floor. This allows easier access to the back.
  • Step 2 Locate the center pivot suspending the dryer drum. If held by a clamp, removed any nuts or screws retaining the pivot axle.
  • Step 3 Move the pivot out of the bracket and slide the new belt inside the bracket.
  • Step 4 Replace the drum pivot in the bracket and reassemble the bracket.
    Looping the Belt
  • Step 1 Flip the dryer up so it is once again sitting upright.
  • Step 2 Locate the groove or wear mark the previous belt left in in the circumference of the drum.
  • Step 3 Wrap the belt around the drum in this groove or wear mark, with available slack at the bottom of the drum.
  • Step 4 Wrap the belt around the drive wheel located on the drive motor in the lower corner of the dryer.
  • Step 5 Insure the belt is snug but not biting the drive wheel. This indicates the proper size belt is installed.
    Reassembly
  • Step 1 Reattach any clips or wires to the back cover.
  • Step 2 Reattach the back cover using the six-sided sheet metal screws removed earlier.
  • Step 3 Reattach the top cover. Close tightly so clips secure the cover.
  • Step 4 Plug in the dryer and turn it on to test the belt repair.
  • Step 5 Reattach the dryer vent conduit
  • Feb 06, 2010 | GE Dryers
    Does a Kenmore Series 80 have a drum belt . The dryer does not spin. Can't find the drum belt
    Yes, it has a drum belt. If you can't see the belt wrapped around the exterior of the drum, more than likely it has broken and is wrapped around the drive motor shaft, or lying on the interior cabinet bottom. If the dryer still heats, but the drum does not turn, this is probably why. Please post back with your model number (located on a nameplate around the door opening) and I can tell you how to access it and/or replace it.
    Dec 29, 2009 | Dryers
    Dryer will not heat, checked and changed thermal fuse and no heat
    The igniter is located on the burner assemly inside the dryer cabinet under the dryer drum. You can view it by removing the lower toe panel directly below the dryer door. This is accomplished by inserting a putty knife along the seam where the dryer front meets the toe panel. About two inches in from each side is a retaining clip that you must push down with the the putty knife, while pulling out on the toe panel. Repeat this on the opposite side and the pane will come free.
    The way the ignition system on your dryer is supposed to work is like this:
    1. Press the start button.
    2. The igniter on the burner assembly begins to glow.
    3. Once the igniter reaches the required current potential, the gas safety valve opens.
    4. Gas is introduced into the manifold and you have ignition.
    NOTE: It can take roughly 30 – 90 seconds from the time you press start to the time it takes for the gas to ignite.
    This is a built in safety feature that prevents free flowing gas from entering the dryer cabinet without ignition. Such a situation could lead to an explosion.
    There are two basic types of igniters:
    Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
    Norton2.gif (Rectangular in shape) – needs to produce 3.2 to 3.7 amps2.gif for the gas safety valve to work.
    I believe your dryer takes the Norton type igniter. The part number is 279311 and can be purchased at pcappliancerepair.com for about $22. NOTE: Just because your current igniter may still glow, does not mean it is good. Igniters will wear out with age and the current potential will decrease to the point where it no longer will open the gas safety valve.
    Now...another cause of poor heating quality and longer dry times is poorly istalled, kinked, or clogged dryer exhaust ventilation ducting. If you have not checked the dryer ducting from where it exits the dryer to the point where it leaves your home, now may be a good time to do so. A dryer needs proper ventilation in order to dry efficiently.
    You can easily replace the igniter by performing the following steps:
    1. UNPLUG the dryer and remove the lint screen from inside the dryer door.
    2. Insert a putty knife along the front seaam where the top panel of the dryer meets the dryer front. Locate the retaining clips and push down while lifting on the top panel. The dryer top will lift up.
    3. Unplug the door switch connector plug and any ground wire that may be installed on the casing and disconnect the door hinge springs.
    4. Locate and remove the dryer chute that covers the blower fan assembly and disconnect the auto dry sensor plug.
    5. Hold the door closed and locate the four screws that hold the front panel in place. There should be one screw on each side at the top and at the bottom.
    6. With the door shut, lean against the front panel and remove the four screws. Once removed, hold the top of the drum as you pull the front panel away and remove.
    You should now have complete access to the dryer interior. You do not have to remove the drum, but if you have to for better access, release the belt tension on the drum. While the tension is released, remove the belt from the drive motor pulley. Leave the belt wrapped around the drum and lift the entire drum with it to remove from the cabinet. You now have full access to the burner assembly to replace the igniter. All you should have to do is disconnect the connector plug and a couple of mounting screws.
    Once you have the igniter installed, you need to re-install the drum and belt by following these steps:
    1. With the belt still looped around the dryer drum (grooved side facing the drum - try to line the belt up with the wear marks already on the drum from the belt) lift the drum with the belt and insert the back rim of the drum onto the support rollers in the rear of the dryer first.
    2. With the drum resting on the rollers, slowly turn the drum clockwise until the rollers seat into the rear drum groove. You should feel the drum drop into place once it seats correctly.
    3. Hold the drum in place (you can do this by resting it against your shoulder so you have both hands free). Loop the belt over the drive motor shaft first.
    4. Then, with the tensioner in your right hand, pull the wheel to the right and place the belt on the idler wheel with your left hand.
    5. Release the tensioner and the idler wheel will tighten up the drive belt against the drum.
    If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram K.
    Once you have the belt installed, re-install the dryer front panel by lifting the front of the drum slightly and placing the drum support wheels under the drum. Lift the entire front panel with drum in place and insert the front panel in the side panels. Hold the door shut so it doesn't fly open and line up the screw holes on the bottom edge of the front panel and then align the top. Reinstall the door springs, the auto dry sensor plug, the dryer chute that covers the blower fan housing, followed by the door switch connector plug and ground wire. Lower the top panel back in place.
    I know this is rather lengthy, so take your time and read thoroughly. This is not a difficult repair at all. If you still have questions, please let me know. I hope you find this helpful.
    Sep 14, 2009 | Whirlpool GGQ8831L Gas Dryer
    Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
    Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
    http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
    Here is a parts/disassembly diagram:
    http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
    Here is a belt installation diagram:
    Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
    Click here for a belt installation diagram.
    All links courtesy of www.repairclinic.com
    Aug 16, 2009 | Maytag Dryers
    Gas dryer gets hot but the drum doesn't turn. Broken belt?
    open the door to the dryer and inside the rimof the door there is a switch, puch the switch in and with the oppisite hand puch the start button on the dryer. if the drum does not spin then you know its the belt. Pull Lint vent out if top mounted and remove the 2 screws, Between the top of dryer and the front panel, stick a putty knife roughly 3 inches from the side of dryer. There are locks that you will unlock with putty knife. once top is removed at top corners of front panel inside you will find 1 swcrew on each corner, and pull off front panel, slip new belt in and start putting things back together.
    Jul 27, 2009 | Kenmore 75922 Gas Dryer
    The dryer will get hot but the drum will not go around
    More than likely, the belt is broken. Otherwise, the drum motor is shot. (That's not very likely though).
    Apr 22, 2009 | Whirlpool LGR5636L Gas Dryer
    My hotpoint vtd20 dryer is vibrating when running. When stopped, with my hand i can barely turn the drum (not sure if it turned easily before) any advice?
    hi Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
    Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
    Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
    Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
    Some older dryers have a V-belt pulley drum drive. With this system, two or three pulleys of different sizes set the speed of the drum. To change this type of belt, decrease the tension on the idler pulley and install the new belt in the V-grooves of all pulleys. Then place the idler pulley back into position.
    With any dryer, make absolutely sure that you replace the old belt with a new one made especially for the dryer. Any difference in belts can change the speed of the drum and cause problems with other dryer components.
    thank u................
    Sep 12, 2008 | Dryers
    GE Dryer DVL 223GB1WW
    ALWAYS UNPLUG ANY APPLIANCE AND TURN OFF THE GAS VAVE BEHIND THE DRIER BEFORE ATTEMTING TO MOVE IT. I HAVE REPAIRED GAS FIRED EQUIPMENT FOR YEARS ...ALWAYS MAKE SURE YOU LOCATE YOUR GAS METER IN THE HOUSE OR OUTSIDE AND HAVE A ADJUSTABLE WRENCH READY. I HAD A GAS VALVE BREAK-OFF IN MY HAND AND, A FLEX-LINE BREAK WHEN I MOVED A DRIER ... I WAS LUCKY I KNEW WHERE THE METER WAS. YOU CANT BE TOO SAFE !!! THE ONLY WAY TO CHECK A BELT IS TO REMOVE IT ... THERE IS A SEPERATE ADJUSTABLE PULLEY THAT ADJUST THE BELT TENSION (USUALLY LOCATED AT THE BOTTOM OF DRIER BELOW THE DRUM NEAR THE DRIVE MOTOR) YOU MAY OR MAY NOT HAVE TO LOOSEN THIS ADJUSTABLE PULLEY TO REMOVE THE BELT. FIND A CLEAR AREA WHERE THE BELT IS NOT ON THE SRUM AND PRESS ON THE BELT ... THERE SHOULD BE NO MORE THAN 1/2" OF "PLAY" ( MOVEMENT)IN THE BELT AFTER YOU REMOVE THE BELT ... TURN IT IN-SIDE OUT. AND SLOWLY ROTATE IT ... INSPECTING EVERY INCH FOR CRACKS AND EVSERSIVE SIDE WEAR. IF THERE ARE ANY CRACKS, VISABLE PLYS (LAYERS) OF THE BELT CAN BE SEEN, OR IT IS REAL SHINNY ON THE SIDES... THE BELT SHOULD BE REPLACED. WHILE THE BELT IS OFF ... USE YUR HAND AND SPIN THE DRUM TO CHECK FOR ANY WOBBLE.... THERE SHOULD BE NO WOBLING ... IF THERE IS IT MAY INDICATE BAD BEARINGS... HOPE THIS HELPED
    Apr 28, 2007 | GE DVL223GB Gas Dryer
    Kenmore 73952 Gas Dryer Logo
    146 people viewed this question
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
