I have lg wd-8090fb display SE error - Washing Machines
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
Brussels
  • 16 Answers
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
  • 22 Answers
SOURCE: error "SE" on LG WD-14381FBB
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Posted on Jul 31, 2009
  • 6277 Answers
SOURCE: My lg intello wd 8074fhb
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Jun 12, 2011
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
Have WD1295fb model with error SE , tries to start but fails ?
Check the door lock motor and switch assembly to ensure that the switch works correctly. Check with Ohm meter to ensure continuity when operated.
Nov 30, 2013 | LG WD-1295FB Front Load Washer
SE is appearing on the screen of LG washing machine
LG washing machine error code SE indicates a "motor fault" although the error code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections and carbon brushes (if fitted).
Aug 29, 2011 | LG WD-80130F 7.2kg Washing machine
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
John C.
Jun 12, 2011 | Washing Machines
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Error "SE" on LG WD-14381FBB
Jul 31, 2009 | LG WM-2277HW Front Load Washer
Oct 19, 2008 | Washing Machines
SE ERROR ON THE WD-12235FB
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Thanks for using FixYa!
Sep 08, 2008 | LG WD-1280FHD Front Load Washer
Aug 02, 2008 | LG WD-1280FHD Front Load Washer
May 22, 2008 | LG Washing Machines
Washing Machines Logo
187 people viewed this question
Top Washing Machines Experts
