Question about Tally Line Matrix T6100 Printer
I received a thermal fault on my Tally T6100 printer. I cleared the error and put it back online. It seems to be working fine, but, what caused the error and do I need to do something to keep this from becoming a more serious problem?
  • Sreekanth C Menon Sep 13, 2010
    Need error details (error code, when it prompt etc)
  • jleaphart Sep 13, 2010
    I didn't check to see the fault code. The red fault light was lit and the digital display simply said, "THERMAL FAULT". Sorry. I don't have anymore info. on this fault. I pressed the "clear" key, then the "online" button and it started working after that.
  • 140 Answers
It could be the problem with your Hammer bank. Plz check it having good impression while printing. Most of this problem related to Hammer bank in this model.
Posted on Sep 13, 2010
Testimonial: "I appreciate the quick response and the help."
    The color is a little on the light side, but it is acceptable. Is the hammer bank controlled by the silver arm on the left side of this printer beside the paper holders?
    nop. in line matrix printers two technologies using to print by striking head. One is shuttle and one is hammer bank. A very big size (a group of print heads)
Error message setup to address the power of the printer
If there is a message on LCD display to "SET THE ADDRESS" the printer will be fitted with a CO AX/Twin Ax Interface
Press CLEAR to CLEAR the error, then enter the menus on the printer and set an address for the Co-Ax/Twin Ax interface, if you are using this the address would need to match the system set up.
If you are not using Co-Ax/Twin Ax set a random address to clear the error.
Perhaps consider removing the interface if you are not using it
Feb 19, 2013 | Tally Line Matrix T6100 Printer
Self test error
just p m card replace and tested working fine
Feb 22, 2012 | Tally Line Matrix T6100 Printer
I need Linux Printer Drivers for Tally T6100.
http://www.tallygenicom.com/ipl/w3/support/drivers/t6100-drv.htm
From here download the unix driver - MUST BE GOOD
Mar 24, 2011 | Tally Line Matrix T6100 Printer
Our drive istallation for tally 6100 line printer has been lost and am looking for one please if you have let me know the free link or advice me thanks
Yes, free links are available. Click here to visit the driver download page. OR click here to download the driver directly.
The driver for T6100 is for installation on Win2000/XP but may also work on later versions.
Dec 10, 2009 | Tally Line Matrix T6100 Printer
Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
May 23, 2008 | Tally Line Matrix T6050 Printer
THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Apr 09, 2008 | Tally Matrix T2280 Printer
Tray1:A4 SVC L1 ERROR
I too have just bought a 2nd hand printer (Tally T8006) that also worked well until the fuser oil seemingly has to 'swamped' everywhere and which now throws up the same error code as above. Will attempt to 'dry it out' and see if the code clears. Have also recently sourced an original installation CD, will check out fault codes when it arrives - Gazz
Aug 31, 2007 | Tally T8006e Laser Printer
Blk 0 chksum error
fault "blk 0 chksum error" is attributable to a corrupt firmware. Fortunately the firmware can be reloaded and restore the printer in operating condition. You can download a firmware from the tallygenicom.com site under support and drivers then download it in your PC. Normally you need to put the printer is flash download mode also instruction can be seen from the site. If you cannot do this I can assist you with this.
Jul 27, 2007 | Tally Line Matrix T6100 Printer
Tally T6100
i need printer driver. kindly send me very much urgentaly.
thank you!
Jun 01, 2007 | Tally Line Matrix T6100 Printer
Tally Line Matrix T6100 Printer Logo
306 people viewed this question
Top Tally Office Equipment & Supplies Experts
Toby
Toby
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
