Question about Thetford Norcold RV Cooler/Freezer
My norcold fridge/freezer in my kiefer built horse trailer will not work on ac power. led display shows A code. I replaced the circuit board and checked the breaker as well it still shows the same code and will not work. any thoughts?
5 Suggested Answers
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Gort007
  • 1187 Answers
SOURCE: How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Posted on Sep 21, 2009
  • 332 Answers
SOURCE: My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Posted on Mar 15, 2010
walesarumi
  • 6993 Answers
SOURCE: reset circuit board on
there are two methods by which you can reset the circuit board, depending on the model of your refrigerator:
Procedure 1:
Click on the below link, scroll to the second (2nd) page. Read and follow the reset procedure.
http://www.rvtechlibrary.com/appliances/noco_old.pdf
Procedure 2: http://www.rvtechlibrary.com/appliances/noco_new.pdf
Good luck.
Posted on Jun 27, 2011
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerator doen't work on electric
check the fuse on the back of the board on the fridge itself
Sep 01, 2009 | Thetford Norcold RV Cooler/Freezer
Fridge and freezer stopped working.Power still on (light on in fridge). Digital control for fridge and freezer shows straight line no numbers. Any suggestions?
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Jun 05, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold RV Cooler/Freezer Logo
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
