Question about Pentair 1.0 Hp Whisperflo Pump
Hi, anybody any idea what the number or size of the inboard (nearest pump) bearing is? I replaced it about 18mths ago but it is getting noisey again and I would like to buy a replacement bearing before stripping the pump. Regards Mike
    Novelist:
  • 116 Answers
I believe it is a 6203. might be a 6304, I think I have seen more than one size on the same pump depending on exactly which AOSmith motor you got
Posted on Sep 18, 2010
Testimonial: "Thanks, not too sure which pumpI have only know it is 3/4hp. Very useful info all the same."
  • Derek
    Derek Sep 20, 2010
    Hey another thing to keep in mind, if you got a pump repair shop around you can bring them the armature and they'll probably pull the two bearing and press on two new ones for ya for a minimal fee. If the guys are nice, and/or you get in good with them they may just sell you the bearings too if you wanna go it yourself. Where did you buy your bearings last time do you remember? Lastly I would probably replace both bearing if your gunna go to the trouble to tear the thing apart.
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
Hello. so i have a 1/2 HP sta-rite pump. a while back it start making a whining nose. im curious is if it makes more sense to buy a new pump or buy a rebuild kit. thank you
Hi mwsang...
It would be cheaper to buy the bearings and replace them as this is causing your whining noise.
When you get the pump motor apart then you can take the bearings off the rotor and take them to the nearest bearing shop for replacments.
Replace your bearings and it will be good for a long time again.
Please take time to rate me
Aug 28, 2011 | Vacuums
Clutch was replaced a year ago and now when i push the clutch it wont allow me to change gears and it sounds like an air pump
That sounds like you have a problem in the pressure plate! Go to the nearest garage and pull down the transmission to replace the clutch assembly. But if you could get the warranty from the one who replace the clutch, inquire about it. Mostly the mechanic would replace the clutch assembly( clutch disc, pressure plate, and release bearing ). So that it will be a one time job.
Either you could tow your vehicle to the nearest garage or drive it( before starting the engine put the gear to 1st and let it start, slowly at 1st gear you could drive into the nearest shop ).
Hope that helps you out!
thanks for using FixYa!
Jun 27, 2011 | 1998 Toyota Tacoma
There is a humming noise coming from the trunk. If you hold the lines to the fuel pump, it isn't so bad. Don't think it is a wheel bearing. It starts when you turn on the car, then quits for awhile and...
THE NOISE YOU ARE HEARING IS THE ELECTRIC HIGH PRESSURE FUEL PUMP IN THE GAS TANK, THE NOISE IS CAUSED BY THE PUMPS ROTOR BEARINGS BEING EXCESSILY WORN, IT COULD STOP WORKING TODAY OR KEEP GOING FOR YEARS, BUT THE NOISE IS A WARNING THAT THE PUMP HAS A PROBLEM. I RECOMEND IF IT IS REALLY THAT NOISEY YOU HAVE IT REPLACED.
Mar 29, 2011 | 2001 Audi A4
Very noisey pump
needs bearings asap.. search your local area for pool pump motor repair with free testing and get it repaired before you destroy the motor and pump ..click here is how to remove your pump
Jan 09, 2011 | Pool & Spa
I need to replace rear wheel tires and bearings for a CTM HS 2800. Where can I find replacements.?
Hi. Probably the best idea is to google the make and model number, and find the nearest agent to order the parts for you.
Good luck. Neil.
Jun 02, 2010 | Ctm HS-2800 Power Wheelchair
Location and replacing an oil pump
oil pump is located inside oil pan, you would have to drop oil pan to get to pump.if lower engine is noisey you should check bearings also maybe even replacing them.kind of a big job.
Oct 02, 2009 | 1997 Chevrolet Tahoe
Noise in front end, when u make a turn it stop and starts again
a wheel bearing will make noise when there is weight on it. if you turn the wheel from side to side while driving and shift the weight it will tell you what side is the noisey bearing. the bearing is pressed in. you must use a press to replace.
Mar 16, 2009 | 1996 Saturn SC
Rear wheel bearings keep going after only a short period of use.
When you install the bearing are you replacing the complete hub? The torque spec for this is 130-174 ft.lbs. Also are the rims and tires of stock size?
Jul 07, 2008 | 1998 Ford Escort
Pentair 1.0 Hp Whisperflo Pump Logo
102 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
