Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error code E3
My printer is giving me an E3 error code, but I have no paper in it. This makes no sense. I have unplugged it, looked it over, plugged it back in, to no avail. HELP!!! ~Erica
    Guru:
  • 377 Answers
Hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Posted on Jun 14, 2008
I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
I have a cannon mp150 printer and am getting a E3 alarm code. I do not have a paper jam and don't know how to fix this
Sometimes a printer may give the paperjam error massage. When this happens you must go thruogh the ritual of clearing paper jam before the printer will respond to the print command again.
So you do the following:
Put of printer and unplug its power cable.
Open all printer covers. (front, back, top as ti applies to your printer)
Close them back firmly
Plug back the power plug
Try printing again.
Good Luck & God bless!
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon mp 170 printer ask to clear paper jam while there is no paper jammed.tried these1-pass a cardboard 2-reset printer by unplugging it for a minute.exactly wich part of the printer sense the problem.
Unplug the printer for at least 2 minutes from the wall.
2. Plug the printer back in but leave the printer turned off.
3. Enter Service Mode
a. Hold Stop/Reset button and the Power button for 5 seconds
b. Release Stop/Reset button but continue to hold Power button
c. Press Stop/Reset twice
d. Release the Power Button
e. Wait for the light to stop flashing. The printer is now in service mode. The display may be blank or simply read "Canon" during this time.
4. Do an EPROM reset.
a. Press the Stop/Reset button 3 times.
b. Press the Power button twice. The printer will save the changes and then it will reboot. A little cd/dvd icon will appear in the LCD screen.
3. The printer will probably now require the same setting up as when you first unpacked it. That is, you will need to select a language and let the printer do a head alignment.
The printer is now enabled.
MP150/MP160 ERROR CODES:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD over current error - USB
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | Canon PIXMA MP170 All-In-One InkJet...
When i print any photo it can't print error show E3
hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
Nov 18, 2010 | Canon Office Equipment & Supplies
My canon mp190 gives E3 paperjam error but there is no paperjam how do i fix it?
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
May 18, 2010 | Office Equipment & Supplies
Error code E3 with no paper jam
it is problem your printer can not feed paper properly or problem paper feed sensor please try to resum button press when occard this E3 signal or clean sensor or claugth
Nov 21, 2009 | Computers & Internet
My canon mp240 has the E3 error and it will not go away
The E3 eeror is a paper jam error.
First, Unplug the printer from the power cord. Disconnect the printer cable as well.
2nd, open the covers and using a flashlight, look for any small debris inside the printer. The smallest piece can trip the error. Remove anything you find.
Next, get some "canned air" at any computer or office supply store and blow the inside of the printer thoroughly. You may even turn it upside down so debris can fall out.
Plug it back in to the wall socket and connect to your PC again and give it a try. That should resolve the issue.
Oct 29, 2009 | Canon PIXMA MP240 All-In-One InkJet...
CANON PIXMA MP160 E3 error
I work in a shop repairing these printers and have had a large number with the same fault - displaying E-3 with no jam in the paper path. This is caused by a broken part in the paper feed mechanism that pevents the printer from taking the paper. The part located right at the bottom of the printer looks like two white gears connected together with a central spring. At present I am trying to find a supplier of the spare parts - will check back.
May 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
259 people viewed this question
old marine
old marine
