Question about HP LaserJet 4650n Printer
4250 laserjet manually feed output stack - HP LaserJet 4650n Printer
4 Suggested Answers
  • 1684 Answers
SOURCE: hp lj 4250 tray 1 stoped feeding automatically.
Here is the info from the service manual about tray configuration.
The value corresponds to the media size that is currently loaded in tray 1. ANY: If both the type and size for tray 1 are set to ANY, the printer will pull media from tray 1 first if media is loaded in the tray. A size other than ANY: The printer does not pull from tray 1 unless the type or size of the print job matches the type or size loaded in this tray.
So set both the paper size and type on tray one to "ANY" and you should be good to go.
I hope this helps, if so please rate my solution.
I have the full service manual available for instant download for $6.95 if you are interested.
Buddy
buddy@ccl-la.com
Corporate Computer
WWW.CCL-LA.COM
Posted on Jul 10, 2009
SOURCE: hp 4250 laserjet is noisy and has numerous jams.
After rexaminig the duplexer and reinstalling, the printer has worked as expected. Apparently the duplexer was not seating properly. Thanks for the recommendation to replace the swing gears. I will keep this solution filed for future reference.
Posted on Feb 17, 2010
ViscamTech
  • 528 Answers
SOURCE: why printer 4515 this error MANUALLY FEED OUTPUT
HP P4515n is not a duplex printer by default. It is a network printer. ('n' suggests it is a network printer. Duplex printers have 'd' in the model number).
If you want to print both sides, manually feed sheet by sheet. Or else you can do the following:
If you are using, say MS Word, print only the odd pages (Print the normal way. No need to manually feed paper). Then arrange the printed papers in the proper order and keep the printed side as back side. Insert the set of papers in the printer and print only the even pages.
First print a document of about 6 pages to get the hang of it.
Posted on May 12, 2011
Hp laserjet 4250 feeds multiple pages through the manual feed tray
It sounds like the paper pickup roller and separation pad for tray 1 is worn and will need to be replaced. These two parts pickup the paper and weed the pages into the printer. When they get worn down they can grab more than one page at a time. The parts are user replaceable, no need to pay a big repair bill for something like this. The parts come in a kit with rollers and pads for tray 1 and tray 2 along with the instructions and it is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302
Here is a picture of the roller and separation pad from the service manual.
I hope this helps you out.
Apr 11, 2013 | HP LaserJet 4250dtn Printer
Have an hp laserjet 4250 it has a knock when it pulls the paper and a squeal while printing any ideas how to fix it?
check through manual feed, same issue open registration assm, clean paper particles under the registration assm, if this problem with try two check paper path between registration assm and tray 2.. i
Sep 08, 2011 | HP LaserJet P2015dn Printer
Why printer 4515 this error MANUALLY FEED OUTPUT STACK for duplex pritnting
May 12, 2011 | HP P4515n LaserJet Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
I have a HP laserjet CP1518ni and the envelopes keep getting jammed when feeding them through the manual feeder.
Put a slight curl on envelopes. The curled stack should go toward the back of the tray. This will enable the printer to pick up easier.
Nov 23, 2009 | HP LaserJet CP1518 Printer
HP 4250 DN
Change the tray one behavior from the front panels paper handling menu. from there you can tell tray 1 to print first if paper is present or default to tray 2.
factory settings are to print from tray 2.
are you keeping paper in both trays??
Mar 28, 2008 | HP LaserJet 4250n Printer
HP Laserjet printer not printing
Try clearing the que. It may be the first job is to big for the memory. Also, be sure the printer is not in manual feed mode. The directions will be in the user manual if you are not sure how to change it.
Jan 19, 2008 | HP LaserJet 1300 Printer
Replacing a power supply board
The power supply assembly is quite a thing to get out. You really will need a service manual for the 4250.
Go to http://www.TheServiceManualShop.com and see if they have one listed. If not, ask them to get it for you. They can usually find them within a few hours.
You will need to remove the following assemblies just to be able to start removing the PSU:
● Rear output bin
● Rear accessory cover and tray 2 extension door.
● Top, right-side, and left-side covers
● Fuser
● Formatter assembly
Then remove the PCA guide and the part above it
Remove the power switch arm
Disconnect the PSU cables from the DC controller
Remove the fan cover plate
Disconnect the fan and thermistor connectors
Pull the PSU cable through the frame and you are about there. A bit of wriggling and wrangling and the whole assy should come out.
Oct 16, 2007 | HP LaserJet 4250n Printer
HP LaserJet 4650n Printer Logo
1,302 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
