Question about Whirlpool Washing Machines
I have a 7 year old Whirlpool washing machine Model no. LSQ9549LW2. I started to have small crumbles of loose black paint or thin rubber on my clothes.\r\n Can you help me on that? Thanks JC
  • 163 Answers
SOURCE: change belt.
this is a easy job for a tech but a hard one to regular people have to remove the transmition and thats is by removing a nut in the tub, so better call a tech and pay for it, is not to espensive repair at least in my area...good luck
Posted on Aug 07, 2006
  • 209 Answers
SOURCE: front loader washing machine = black streaks on clothing
I am a recently retired engineer of 20 years once you have ruled out anything getting inside the machine by accident etc, like something in pockets or greasy overalls, then its likely to be the drum bearings, has the machine started to get noisy on the spin the drum bearings are covered by a rubber seal, this seal gets damaged or worn and water leaks into the bearings themselves washing out the grease back into the drum where the washing is, you could also notice slight water marks on the floor underneath the machine on the floor, take the back off and look for water marks coming from the drum outer casing behind the pulley, these marks will be brown and will originate from a small drain hole, if any of the above change the bearings before any real damage is done, either to the clothes or the machine, as repair can be expensive? sorry, hope i have helped you as to where to look at least,
Posted on Sep 19, 2007
likha
  • 790 Answers
SOURCE: Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Posted on Nov 02, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 66 Answers
SOURCE: clothes dryer brown marks problem
if that mark is comming from the dryer .the drum has a rust. and you cant paint it or the seal of the drum is bad that seal is around the drum.
Posted on Feb 18, 2008
After 20 years of use, pieces of thin black rubber are deposited around the bowl after the wash cycle. Where is this material coming from?
are you sure that it is rubber
the black is mostly from the mud build up under the agitator from using washing powders that do not completely flush out on the spin cycle. Remove the agitator and /or bowl to clean out the gunk
after 20 years you will be amazed at how dirty the machine is where you can't see
Apr 09, 2015 | Washing Machines
I have a whirlpool wwi851ew , when I press the necessary buttons to start the machine it starts to fill when I press the start button, the problem is keeps draining the water out of it, does anyone ha
check the vacume pipe ....remove lid.......look for thin black white or clear pipe coming from the drum to a small round plastic part........when water level rises the vacume created closes a switch to stop water and start machine..
cheers
Nov 01, 2014 | Whirlpool Washing Machines
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Identifying model number of 10 year old Whirlpool washer
What problem are you having? Will it not just spin out or does it not agitate?
Nov 06, 2012 | Whirlpool Washing Machines
Hello, I have a whirlpool duet washer, modelwfw9200sq. It is leaking. We had a repair person fix this last year ( just a small rubber tube comes loose) Can you tell me again where this was located on...
Front - bottom. You must remove the front kick panel to view.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 28, 2010 | Whirlpool WFW9200S Front Load Washer
I have a Whirlpool Duet. It is about 8 years old and used heavily (family of 8). It started making a really loud noise during the spin cycle. There is also some type of material peeling/crumbling off down...
The load noise is most likely the main bearing. What does the peeling crumbling material look like? It may just be soap scum/mildew or something. Let me know if I can help with anything else.
Apr 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
There is extensive rusting around the liquid bleach receptacle of my four year old stackable Maytag washing machine. Am constantly removing rust and painting over with appliance paint. Rust reappears in...
I can not respond to the whitlpool ceo but I can tell you how to fix your problem.
Go to the hardware store and get a small container of a product called naval jelly. Paiint this on the rusty area, let it sit for thirty minutes and wipe away all of the rust. Next paint the area with rustoleum primer followed by rustoleum paint.
Jul 06, 2009 | Maytag MTW6300TQ Top Load Stacked Washer /...
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
d
Oct 12, 2008 | Whirlpool Washing Machines
Washing Machines Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
