Question about Belkin (F5D5231-4) Router
Somebody logged into my belkin router and now my belkin name router changed to toshiba pc (the pc used by guest) and i cannot connect to my wireless anymore. thank you
  • 708 Answers
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Posted on Oct 17, 2010
How do I recover from lost guest password?
If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
Dec 09, 2015 | Belkin Wireless Dual-Band N450 Router
I live Honolulu Hawaii. When wifi connects a page comes up...Guest Access Belkin login. What is the password?
Obviously I shouldn't know the password. But it looks like the WiFi access point you're trying to connect has a external login page configured. Which require a user name & password. Although some system has free browsing option for guest. You should contact the administrator for your username & password.
Thank you
Feb 03, 2015 | Belkin Computers & Internet
Hoh to i conect rajesh net in my pc
Log in to your belkin router go to connection, select PPPOE go to next step put username password provided to u. in servicename put service name (Rajeshnet3) or (RajeshDC3) which ever provided by Rajeshnet. save settings thats all.. only problem is you will have to keep on change setting of service name in router to connect DC and internet as they using 2 diffrent servers.
I hope it might help you.
Jan 15, 2011 | Belkin Surf N300 Wireless N Router
How do I secure my wireless connection?
The exact access and setting procedure can be found at Belkins web site.
Disconnect all cables to the router, then, in essence you connect to the router, usually via direct connection and direct your browser to the address specified (somthing like 192.168.1.1) and log into the router. Things that you want to change are ssytem ID, router name, Router access password (RECORD IT!!!!) and set up wireless security. An easy access password would be your home phone or cell phone number. if you make a cryptic password, tape it to the router, as you will forget it when a guest visits and needs access.
Another setting to check is that your router broadcasts it's presence, usually set to yes, but not always, by default.
SAVE settings on EACH PAGE or they do not save, as you go from page to page changing settings.
Oct 14, 2010 | Belkin Computers & Internet
I need to change the name of my Belkin Wireless (automatic) name and password. Can you walk me through this?
How to quickly install and use your Belkin wireless G router 1. Step 1
Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2
Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3
Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4
Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
5. Step 5
Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 01, 2010 | Computers & Internet
A guest used her laptop in my home. connected to my router and now theres a security lock preventing me from signing on
Did your guest perhaps log in to your router and make some changes? If so, I recommend you press the "reset" button on the router and re-set it up.
Dec 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My g wireless Belkin USB Network adapter doesn't seem to be funcionig. I cannot access Internet Explorer. I have HP PC with Windows XP. I',m using Sprint WiFi.
Is your router connected to your Broadband modem (cable or DSL) into its broadband port? The router must be first connected wired to set it up for wireless access. Use your browser to access http://192.168.1.1 and log in with login info from the manual. Once you get in, set the Network Name (SSID) then the wireless security. I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you set here to log in with your wireless computers.
Nov 11, 2009 | Belkin (F6D3230-4) Router (F6D32304)
My belkin N1 vision, keep disconnecting from internet. my landline pc works fine. i am only having the problem when connecting with my laptop. i am using a mac book pro with mac os x latest edition. thanks
My N1 Vision does the same thing, If you turn off the guest account, you should find its ok. Only when this Guest account is on, thats when it disconnects. Hope this helps. John
Oct 03, 2009 | Belkin N1 Vision Wireless Router
How do I rename it so I can further protect my network
  1. Log-in to your router (default: 192.168.2.1)
  2. Go to LAN Settings
  3. Change Local Domain Name to a name of your liking.
  4. Click Apply Changes.
  5. Done.
If you have any more questions or this is not clear to you, just come back here and leave a comment - I'm happy to help.
May 22, 2009 | Belkin (54G F5D7230UK4) Wireless Router
Router
VATODAMAGE
that light indicates data flow on port 3, please ensure the WAN cable is connected to the wqan port, not LAN3
vatodamage & GUEST
using a cable connection, connect to routers web interface http://192.168.2.1 and check the wireless security settings are the same on the router and on the pc that does not have connectivity
Guest, always post a separate problem, that way you get the right answer
Jun 12, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D5231-4) Router Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
