Question about Dell 5310n Laser Printer
Our Dell 5310n printer is telling us there is a paper jam and to check the cartridge. I have looked and there is no paper to remove and I haven't a clue how to sort this out and i need it for work. Can anyone help please
Remove the cartridge. On the left side about 8-10 inches in from the front a small plastic arm sticks up. This frequently gets knocked out of its mount and doesn't move anymore. You have to remove the tray and some plastic bits and pop that arm back in its mount.
Posted on Sep 22, 2010
Close door or replace cartridge message won't go away
Dell growing very fast in computer market because Dell provide best and affordable products to users but one thing is confronting by many users is that "Close door or replace cartridge message won't go away" that's why Dell experts provide a toll-free Dell Support Phone Number through which number every Dell user can easily connect with Dell experts and solve issue within a couple of minutes. Don't late to call because Dell experts provide first come first serve service so call anytime without any hesitation 24x7.
Jan 08, 2016 | Dell 5210n Laser Printer
Dell 5310N printing without jams, but pages are wrinkled in an accordion fashion, horizontally across the page.\r\n User also wants to know if they can use manual feed to do multiple envelopes at a time. ...
To fix mine I had to go in and trace the paper route with the duplex option installed...loosened on of the bolts just a little ... now works fine it was being dragged by the overtightened roller.
Sep 20, 2011 | Dell 5310n Laser Printer
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
Error 241.1 Paper Jam. I have reseated the tray
Brand New T652n lexmark printer get a paper jam every time! just opened and haven't been able to print one paper. Doesn't matter if you print from tray one or tray two. It gets stuck right after the rollers pick it up and try to send it to the toner. Any suggestions? I've tried to reseat the toner, plain paper, sized the paper correctly, I've tried just about everything I can think of! I can feed paper manually through the top tray, and it will print. But, just using the manual tray defeats the purpose of the other two trays. Anyone else having this issue?
May 26, 2010 | Dell 5310n Laser Printer
Dell 1720 laser printer shows paper jam after clearing jam and turning off and back on.
some paper piece may be left in the printer.
Please check where was the leading edge of the paper when it was jammed. some sensors may have got stuck while removing paper. open the toner door remove the toner cartridge, just see all the sensor flags with fingers, refix toner and power on and try printing
Dec 01, 2009 | Dell 1720dn Laser Printer
Dell1600n showing a document jam, have tried everything eg switching it off but cant find a solution. it prints fine and copies fine as well just isnt taking anything from the ADF. So I cant send a fax...
check the gears in the adf maybe you have one that is misaligned ,run a piece of paper following the paper path check the flag sensor make sure none of them is jammed close or misaligned.
Good luck
Jul 09, 2009 | Dell 5310n Laser Printer
202.01 and 202.03 Paper Jam
The 202.03 error code has to do with an early life failure of the fuser. Try replacing the fuser. If that doesn't work, a tech is needed to replace rear door. Don't forget to reset maintenance counts when you replace fuser!!
Jul 01, 2009 | Dell 5310n Laser Printer
Dell 3010cn paper jam 075-134
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 12, 2008 | Dell 3010cn Laser Printer
5310n dell printer
Does it detect an old cartridge properly? Please verify this before disassembling. I've seen incompatible cartridges sent before. The service manual is the same for the 5210 http://support.dell.com/support/edocs/systems/prn5210/
Jun 26, 2008 | Dell 5310n Laser Printer
Dell 5310n Laser Printer Logo
1,036 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
