Question about Big Green Egg Large All-in-One Grill / Smoker
I dropped my green egg, it now has a huge crack on the side and the bottom broke in three places. how can I fix this?
    Scholar:
  • 129 Answers
I hate to give you bad news but repair is near hopeless, I would try a heavy duty epoxy JB weld or JB industro weld. notch out all cracked areas then fill notch and crack with epoxy. Allow to dry fully. JB weld is safe in high temp of engine compartments. Good Luck
Posted on Oct 03, 2010
Tip
EGGS on the Floor, No More!
Keep the eggs on one side of carton, so as it weakens when you grasp it the majority weight is closest to you preventing the now, softening carton from collapsing from the weight at the far end (from your hand.) of the carton. This will prevent many dropped eggs.
P.S. PLOPPING the eggs on to the pan cracks te egg easier than hitting it on the side rim to crack it. You will get less shell fragments this way. Give a try, you'll probably agree. Odd but True.
on Apr 06, 2012 | Kitchen Appliances - Others
How to tell when eggs are spoiled
Eggs are usually good for three to four weeks after the expiration date. To test, put them in water. Good eggs will drop to the bottom, rotton eggs will float to the top.
Jul 04, 2014 | Home
How are you supposed to heat up the green egg
There are you tube videos. I temporarily take daisy vent cap off top of egg, open bottom vent door wide open, light lump coal 2-3 spots with a loof lighter (from ace hardware) and then close lid. I have one section of galvanized dryer vent from Lowes that I stick on top which accelerates preheating of egg. Once the temp gets to 500, I remove the section of vent by grabbing it with a glove or hotpad. Wait a minute or two for smoke to die down. Place daisy back on top and close bottom vent door down to 1/2" and close daisy 1/2 on top and this should drop temp to 175-250. Use fine adjustments 1/6-1/8" until desired temp is reached. Your food can go on at any time after removing dryer vent. Just burp lid by slightly lifting to allow any heat burst to escape. I also have a gas conversion that works awesome. I just add a small smoke ox over burner that provides enough smoke on front end of cooking process. Advice- keep the butts and ribs on for 6 hours.
May 01, 2014 | Big Green Egg Extra Large - XLHD...
How do you tell if an egg is bad
When the chick walks away! :) My father used to throw out many he seems to know. I never worry about it i survived without a fridge for a year. I left my eggs out in warm summer heat in my place for a week and had no issues. Others i've left in the fridge for 6 months and ate anyways, no issues. If an egg smells like sulphur then it has gone bad. Some people just want the best of the best and leave the rest to the poor. If that is the case then an egg is no longer freshest when the moisture content starts to drop and the yolk breaks upon cracking and falling into the pan. I eat my eggs scrambled so i don't care if it spills out.
Nov 30, 2013 | Kitchen Appliances - Others
Bottom propellers won't spin on my black spider xt
Had the exact same problem wire to gear was not welded properly reattach and done.
Nov 30, 2012 | Toys
When my green egg gets to temp over 600 the lid becomes lose and falls off when you lift it. I've already broke one. Why is this
It sounds like a problem with the hinge springs, rather than the lid. One will usually break before you realize it has. Then the second one goes, before you realize it. And it's usually when you have the Egg heated to a high temperature. You should also check the steel band around the egg, that is part of the hinge system to make sure it has not been overtightened or is to loose.
The folks at Big Green Egg take this sort of thing seriously and are devoted to their customers. You should also contact them about this issue.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Big Green Egg Large All-in-One Grill /...
Egg cookers
I found the instructions
Sprinkle a few grains of salt on bottom of egg cooker. (Salt attracts microwaves and is necessary to help cook bottom of egg)
Break egg into egg cooker.
One egg in micro at a time.
Will fork piece yolk and white to bottom of cooker, three times. _ This is very important.
Line up notches on egg cooker lid and cup then twist until locked
Micro on High for 30 seconds
Let stand 10 seconds
If bottom of egg is not cooked turn egg over with a spoon and microwave on high for another 10 to 20 second or until cooked.
Dec 16, 2008 | Microwave Ovens
I have a tefal TT550015 toast 'n' Egg and have no instructions on how to use it. Please advise
To use the egg side only, fill the measuring cup with the correct amounts of water. (One side is for boiled eggs, one is for poached eggs.) Pour the water into the basin at the bottom. For boiled- Place 1-4 eggs in the tray with the four holes. Use the sharp thing at the bottom of the measuring cup to pierce the egg shell. Place the lid over top, and hit the 'egg' button. When the light on the button goes out, remove the lid. For poached, grease the pan. Spray/ butter, whatever. DO NOT rely on the non-stick. The thick black tray for boiling eggs goes on first. With the egg in the greased pan (scrambled or whole) place the pan into the unit. There are four plastic pieces in the boiling tray to show you where it goes, the handles aligned. The round tray, with the square holes in it, can be used to warm pre-cooked meat.This is optional, and that tray goes on top. Place the lid over the top, and press 'egg'.
WARNING: this cooks by steam, and any remainder can cause burns. Be careful when removing the lid. Same goes for the product. The boiled eggs should not be touched directly.
To make an egg sandwich, load the egg side and the bread/english muffin/bagel into the toaster. Press the 'egg/toast' button BEFORE starting the toaster. The toaster will start on a timer so that the egg and toast will be done at the same time. When the toast pops up, you are good to go.
Note: there should be no water afterwards, maybe a little oil if you cooked meat. Hard water residue is easily removed with vineger and a paper towel.
Dec 02, 2008 | Back to Basics TEM-500 Egg & Muffin...
Big Green Egg Large All-in-One Grill / Smoker Logo
446 people viewed this question
Top Big Green Egg Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Johnathan Lence
Johnathan Lence
Are you a Big Green Egg Grilling Expert? Answer questions, earn points and help others
