Question about Colnago Freeship Ferrari Cx-20 Bicycle W/16" Rims Turbo
Colnago C50 with 11 speed choras group set. When changing up to the big chain ring ready to decend whilst still in one of the largest 2 or 3 rear sprockets the chain slips off Please advice how to adjust the front mech to stop this problem
    Problem Solver:
  • 10 Answers
Is the chain falling off to the outside? if it is you can adjust the "High " limit screw on front derailleur. There are two screws on top of derailleur usaully marked with a L or a H.Shift rear to small cog and front on large ring. Slowly turn screw marked H till you see front derailleur move in. When it starts to rub on chain back off 1/8 of a turn. Run the rear up and down a cuople of gears making sure nothing rubs and adjust accordingly . Same with the front. That should do it! Also when changing to the big ring up front you should try to be on a middle to small cog on the rear so you don't get into a "cross chain" situation. When running on the small ring you should be on large to middle on the back. Hope that helps you out.
Posted on Sep 13, 2010
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
Knocking noise of chain
How many miles have you put on the chain.
You may just need a new chain and sprocket set.
As these do wear over a period of time.
Have you been lubricating the chain regularly ?
if this is an O ring chain, they rely on the oils in between.
If you need to change the chain, look at an X ring chain, these suffer wear less quickly.
Apr 03, 2014 | Motorcycles
I have a brand new Red 22 group set up on a new Masi Evolution Frame. After about 400miles the chain started to derail off the lower rear derailleur tension wheel when ever I hit a bump while riding in the...
sidjjjjjjjjjjjjjjjjjjjjjjjjjjjjlkdjasjdnjkahdasnjdhabnsabdabhbnsabdnmabdjkhjkwqb wsnbjhbguysahbdagbxhjasbx njabgdyhabsk,dmankjxhigbknbchsgjanmanjaabjbsahgsavbnbsahgsabjnsbajhsajnmsa,hauisjanmsayihanm,.saaiosaiklnma,. saskalhhanm
Mar 01, 2014 | Sram Red 22 Groupset
I have a Huffy Savannah model 56770 16 speed. How do I shift into gear 7 through 16 ?
Google "bicycle shifting technique", for example:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible.
Excess sideways stress on the chain will wear it out prematurely and decrease its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you're having a problem with. Get behind the bike and look straight along the top of the chain. As you can see the line of the chain is a mild zig-zag where it is parallel to the bike at each gear but needs to angle across the drivetrain in between. On some bikes the chain might even come in contact with the next larger chainring when used this way.
The big-big combo uses up all available chain length and the rear derailleur will be pulled toward the front of the bike, sometimes so far that it is in danger of being snapped off.
THERE IS NO UPSIDE TO CROSS-CHAINING.
As you can see, the rear derailleur is probably not long enough to **** up all the slack this gear combination creates. There are other combinations that would yield the equivalent gear ratio without either stressing the drivetrain or dropping the chain.
The basics of shifting are these:
1) The big ring and right side of the cassette in back are for speed.
2) The small ring and the left side of the cassette are for high torque, lower speed
Ancient bike wisdom for beginners: If your legs ache, shift down. If your lungs ache, shift up.
Apr 25, 2011 | Huffy Cycling
Incoming calls only rings once
In the profile setting along with the ringtones and volume setting there should be a setting for ring option - this is prob set to 'ring once ' as apose to ring or decending...
Helps
Pindy92
Oct 08, 2010 | Cell Phones
Where is the serial number on a fuji feather?
NORMALLY UNDER THE BOTTOM BRACKET WHERE THE PEDAL ARMS GO THROUGH THE FRAME.THEN AGAIN I OWN A COLNAGO AND IT HAS NO SERIAL NUMBER.JUST THE WORD "COLNAGO" STAMPED INTO THE BOTTOM OF THE FRAME.HOPE THIS HELPS
Sep 07, 2010 | Fuji 2010 Fuji Feather Single Speed Road...
Campagnolo Record 10 sp. short cage rear drlr.+ 13-26 cassette
You don't say if this happens in the BIG ring, small ring or both. If it's just the big ring I'd suspect there isn't enough chain length.
Cross chaining is unnecessary and bad for your drivetrain. I never go more than one cog past the center of my cassette opposite the chainring I use.
http://www.parktool.com/repair/readhowto.asp?id=26
May 02, 2010 | Campagnolo Record 10 Rear Derailleur
I have shimano rd6500 rear derailleurs. when chain is on small chain-ring and smaller rear sprockets the derailleur cage is rubbing against the chain.How do i tension chain to hold cage away from chain,...
If you learn to shift correctly this won't happen..
Google bicycle shifting technique, for example:
You should NEVER run cross-chained (big-big or small-small). The drive train performs best when the chainline is as close to straight as possible. Excess sideways stress on the chain will wear it out prematurely and increase its normal efficiency.
To demonstrate this for yourself, put the bike in the same combination of gears you're having a problem with. Get behind the bike and look staright along the top of the chain. As you can see the line of the chain is a mild zig-zag where it is parallel to the bike at each gear but needs to angle across the drivetrain in between. On some bikes the chain might even come in contact with the next larger chainring when used this way.
If you can shift to the big-big combination without snapping the rear derailleur off, you're lucky. The big-big combo uses up all available chain length and the rear derailleur will be pulled toward the front of the bike, sometimes so far that it is in danger of being snapped off.
As you can see, the rear derailleur is not long enough to **** up all the slack this gear combination creates. There are other combinations that would yield the equivalent gear ratio without either stressing the drivetrain or dropping the chain.
Feb 24, 2010 | Shimano 105 Triple Braze On Front...
Throwing chain too far on an upshift up and off
The "H" screw is the one that is letting your chain jump of f of the ring. If the screws are not labeled, the way to distinguish the two is to shift the front as high as it can go and hold it there manually. Screw either adjusting screw in. If you are screwing the correct one, it either will not move at all or move only very slightly.
First thing is first: flip your bike over onto the bars and saddle. The best method to adjust these settings is to shift into your small ring and let loose the shifter cable. Now shift your rear derailleur into the lowest gear and manually pedal the bike while adjusting the "L" screw on the front until the derailleur cage allows relatively free rotation of the chain. Now set the barrel adjuster on your down tube fully turned in (clockwise). Pull the cable taut and reattach at the derailleur. Shift into your middle ring (or high ring if you have a double-ring crank) and then shift the rear to the highest gear. Use the barrel adjuster to get the derailleur cage to just clear the chain while cranking. If you have already succesfully set your "H" screw to a point where the chain no longer jumps off, then you are all set here. If not, hold the front shifter in while cranking and set the stop so the chain cannot get off of the big ring, but far enough out so you can purposely over-shift by just a bit. Sometimes if you shift early, that little bit of over-shift is very helpful.
i hope this helped, but if you would like to see pictures of this happening, go to parktool.com/repair and check out their tips on derailleur adjustment.
matthew
Oct 22, 2009 | Campagnolo Record Front Derailleur
SAMSUNG PROPEL - Always Ascending Ring
this s bcoz of ring tone settings baba...u jus check whether u selected decending option...deselect that...then u r ring tone will be proper!!!
Jul 25, 2009 | Samsung Propel Cell Phone
Colnago Freeship Ferrari Cx-20 Bicycle W/16" Rims Turbo Logo
138 people viewed this question
Top Colnago Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Colnago Cycling Expert? Answer questions, earn points and help others
