Question about AcerPower SV PC Desktop
Acerpower sv wont turn on, the fan only keep spinning with no display. And no signal beeps
    Scholar:
  • 181 Answers
Good day.
Primary culprit is your motherboard and the processor. But just to be sure, check your power supply cables going to your board and the voltage. Next, to isolate the problem and the board/cpu, remove all the device (cards, memory, drives, etc.) then power on, if there still no beeps then your board is dead, no way to check for the processor unless you have a good processor.
Good luck
Ted
Posted on Sep 15, 2010
When i turn the power on, 3 beeps play, the fan runs and the power light comes on, but nothing else
Hearing ONE beep is normal, and a signal that the computer hardware is OK.
Hearing THREE beeps is a signal that something is wrong:
* burnt-out CPU,
* one of the fans is not spinning (clogged?) or spinning too slowly (about to seize-up),
* one of the RAM chips is defective
* the video-card is not working
If there is more than one RAM stick, remove all but one stick, and start it up, to see if it starts.
Check that the fans are spinning freely.
Dec 14, 2010 | Gateway GM5260 PC Desktop
Hp pavillion 533w wont boot up green light on front comes on but thats it no fans coming on either
Hi ,
If the green light comes on on the front panel then it means the fan is spinning so what u can do is a self test for the monitor.Disconnect the vga cable from the back panel of the computer tower and then check if there is a message displayed on the monitor that should say check video signal or no inoput signal ,if there is no such message displayed then it means the monitor is a fault .If not then reset the memory card and then check .U can also run a test for the motherboard to do this u will have to remove the memory card and then turn the computer on if u hear long beeping noise it means the motherboard is fine .If u dont hear any sound then the mother board needs to be repaired or replaced...
all the best
May 01, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
CAN'T FIND VIDIO DRIVERS OR AUDIO DRIVER FOR ACERPOWER SV
try going to www.update.microsoft.com do a custom update and click on the hardware tab to see if they have drivers listed for your hardware. if they do not then go to device manager and right click on the display device and then left click on properties. after that you will click on the details tab for the driver. go to www.pcidatabase.com and enter in the device and vendor should help you track down a solution.
Dec 08, 2009 | AcerPower SV PC Desktop
My AcerPower SV has only an internal cd-rom. So iwant to take it out and install an internal dvd-rom. However only one side panel comes off the computer and there doesn't appear to be way to get the other...
This service manual says to remove the front bezel (plastic cover) by "releasing 6 latches". However on my AcerPower the front bezel appears to screwed on, which really complicates things. I'm pretty sure once the front bezel is removed, the floppy and cd-rom can slide out from the front. Hope this helps.
http://www.acersupport.com/acerpanam/manuals/acer/0000/servicemanuals/ACF329.pdf
Nov 17, 2009 | AcerPower SV PC Desktop
Acer Power SV, I need to reformat but no Wn Xp disc
buddy you have to need xp window cd you can buy it or take from your freind without xp window cd you cannot install window.
Oct 20, 2009 | AcerPower SV PC Desktop
Maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Sep 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The driver download for the video settings wont execute
download from the
www.lostmydrivers.com/
select display drivers
select your model name and number
then download it
Jun 30, 2009 | AcerPower SV PC Desktop
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Acer desktop fails to boot
a definet short on the motherboard. keep your cpu and cmos battery and break the board
Dec 30, 2007 | Acer Aspire SA20 PC Desktop
AcerPower SV PC Desktop Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
