Question about Nvidia Quadro FX 1400 Graphic Card
SOURCE: Where can I get a replacement cooling fan an NVidia Quadro4 750
I had a problem with the fan/heat sink assembly on an nVidia GeForce 5500 FX card a year ago. The card was in a multimedia computer and had lots of running hours on the fan, and the fan's sleeve bearings were shot, causing it to rattle. Failure of the fan seemed imminent, and before it did so and damaged the GPU chip on the card, I decided to fix it. Unfortunately, nVidia had used many different styles of fan/heat sink assemblies on this product, all of which were apparently obsolete. On closer inspection, however, one could see that the original fan on the chip cooler assembly was the core from a Sunon KD1204PFB1 12VDC/1.4W 40mm sleeve bearing brushless tubeaxial fan. One could also clearly see where the three struts were cut to remove the fan from its rectangular housing. The fan was glued to a clear plastic 3-tab mounting "spider", which, in turn, was attached to the heat sink with three small screws.
Here's what I did to fix mine; perhaps a similar approach will work for you.
1. Remove the video card from the computer.
2. Unplug the fan connector. On some cards the fan is plugged into a 2-pin header on the card, while on others it is connected to +12V via a Molex-type disk drive supply tap.
3. Remove three small flat head Phillips screws and lift fan assembly off heat sink. You will need a #0 Phillips driver or small jeweler-type crosspoint driver. DON'T LOSE THE SCREWS!
4. Very carefully pry fan from the clear plastic mounting spider. Most likely, it has been secured in the factory with some type of cyanoacrylate adhesive, i.e., "Crazy Glue". Take care not to crack the spider, as you will need to reuse it. It is better to peel the label off the back of the fan motor, than try to get the entire fan assembly off at once.
5. Clean up cyanoacrylate glue residue from spider by carefully grinding with an elliptical or spherical burr in a Dremel tool, to produce a flat surface.
6. Get a similar replacement fan. In this case we'll use a Sunon KDE1204PFVX 12VDC/1.9W 9.5CFM, 40x40x10mm MagLev bearing fan. (Ordered from Jameco Electronics, Belmont, California http://www.jameco.com, about $7+tax & shipping. It costs about $2 more than the sleeve bearing OEM equivalent, but the MagLev bearings should outlast the computer by decades.) Cut the fan core out of the duct housing in a similar fashion to the original. Be careful not to snip the wires.
7. Align the fan motor cable with the cable guide tab on the spider, to route the cable away from the hub and keep it out of the fan blades.
8. Use a small blob of hot-melt glue to secure the fan onto the plastic spider. Press the fan gently against the spider until the glue solidifies, between your thumb and index finger.
9. Install the motor assembly on the heat sink with the three small screws. Route the motor cable between the heat sink fins as before. (The original cable had electrical tape wrapped around it where it passed between the fins, but I deemed it unnecessary to duplicate this. If the chip were to get too hot, it would probably cause the hot melt glue to fail, as well as cook the PC board anyway. In normal operation the heat sink fins stay close to room temperature.)
10. Connect the motor wires to the original connector, matching wire colors. (red = +12V, black = ground) If connecting to a Molex-type disk drive power tap, note that +12V is on the yellow wire.
11. Reinstall the card in the computer, connect the fan to the power supply, and power it up to verify that it spins. If everything looks good, button up the computer and you're done.
Posted on Dec 09, 2009
SOURCE: I have a computer running
$ this is a serious problem it is general that high end GPU s get hotter with the amount of graphic intensive work you do.
$look if the GPU's run cooler in windows vista or seven just for your experience
$look for some other cooling methods like moving it into a Air conditioned room or try installing a water cooling system for the GPU's you can get it online for a reasonable price
Posted on Mar 28, 2011
Mar 07, 2014 | Nvidia Quadro FX 3450 Graphics adapter-256...
Nov 22, 2012 | HP xw6400 Workstation - 2 x Intel Xeon...
Jul 27, 2012 | Nvidia Quadro FX 550, FX550, 128MB,PCI-E...
Feb 28, 2011 | Computers & Internet
Sep 16, 2009 | Intel Computers & Internet
Jun 05, 2009 | PNY NVIDIA Quadro FX 1400 / 128MB DDR /...
Sep 12, 2008 | Computers & Internet
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
559 people viewed this question
