Question about iRobot Roomba 560 Robotic Vacuum
My Roomba 560 is making a clunking noise when it is on and it keeps stopping saying that I need to clean the brushes. I've thoroughly cleaned the brushes and I've cleaned lint from other small crevices but I'm still getting the error. Any suggestions?
  • 3 Answers
I'm having the same problem with my 560 after a day of use. For me, it's caused by the little yellow spacer that's clipped onto each side of the bristly brush. When the brush assembly is closed, it wedges rather tightly next to that yellow spacer on the left. This causes a lot of friction and heat, and mine's worn away quite a bit already.
My solution was to just unclip that spacer and leave it off. It's probably not an ideal long-term solution, because dirt and hair will be more likely to get into the drivetrain. But at least it works now.
Another thing that these roombas apparently suffer from is clogged up gears. If you aren't having the same problem as me, you could try the instructions here to clean the gears:
http://www.robotreviews.com/wiki/cleaning
Hope that helps!
Posted on Sep 17, 2010
In the case of my Roomba, this was caused by hair wrapped around the rod between the little yellow doohicky with the tab end and the rest of the brush. The brushes have the end with the square knob and the end with the complicated little yellow doohickey (I really have no better way to describe it). Unclip the doohickey by squeezing and pulling (you may have to try a couple different places until you get the right angle), then pull the hair off of the metal rod. Any **** in there can make the brushes jam, so clean them out regularly.
I wasn't cleaning them for the first couple weeks because I couldn't figure out how to get them off, and it caused this problem pretty quickly. (Older Roomba you matched tabs with notches and pulled it off, this one has a couple tiny tabs grasping the metal rod and you have to grab the outside of the doohickey in line with them and squeeze to pull it off).
From the iRobot help line,
1) Clean the brushes thoroughly including this area, then run and see if everything is OK. If so, just remember to clean them well and regularly.
2) Run the Roomba with no brushes, no cage, and no dustbin. If it still jams and misbehaves like this, the cleaning module is the problem, and you will either need to clean it out yourself or send it to them for repair.
3) Run the Roomba with just one brush (including cage and dustbin), and if that's OK, with just the other brush. Whichever brush is causing issues may need to be replaced because something is warped, or maybe you need to inspect it carefully for crud.
Posted on Jun 01, 2011
Mine was also the spacers but I found that when I swapped them to the opposite ends it no longer made the noise. So maybe try swapping ends before removing them completely.
Posted on Nov 25, 2010
  • Petruska5 Jan 13, 2011
    I tried switching and it worked for a short while, but the problem reappeared, so now I've tried to smooth the yellow piece with some sandpaper, and it seems to work...
  • aacassens Feb 28, 2011
    Ya gotta disassemble the gear box and clean the crud out. Go to this You Tube video and he shows how to do it.http://www.youtube.com/watch?v=7QWhsu4c0...
4 Suggested Answers
SOURCE: Brushes are clean, but Roomba stops and says clean brushes
I decided to take it apart and see if I could fix it because even if something inside went "SPROING" and I couldn't get it back together, it wouldn't be any worse than it was already.
FIrst, remove the dust bin part and the brushes. Then, there are four screws on the bottom gray panel which have to be removed first in order to get to the gears which hold the brushes. I did not remove the little sweeper brush on the front, but I just slide it through the hole in the gray panel.
Then in order to get out the orange section which actually holds the brushes, there are four screws which must be removed. The orange section is attached to a blue section. This entire unit comes out by sliding it toward the area where the dust bin goes, being careful not to tear the light gray rubber gasket which covers the side.
Once that section is removed, there are two screws on each side. These screws hold the orange thing to the blue thing. Once the screws are removed, lift up only the side which has the white squares into which the brushes are inserted. These are actually the back side of little gears. There is a face plate on the outside of the orange part on this end. The other end contains a bunch of wires and I was careful not to disconnect any of them.
The face plate has six screws which must all be removed. Use caution when removing the face plate. Hold it up so that all of the stuff doesn't fall out. It has a bunch of gears, little brass looking fittings and grease. Take care to only remove the gears which have the squares which hold the brushes AND do it one at a time unless you like working jigsaw puzzles. I used tweezers and a pin to clean the "gunk" consisting of hair, fuzz, etc., out of the little gears.
Reverse the process to put it back together. Hazel, my little Roomba, played me a happy little song and immediately went back to work. She seems as good as new.
Posted on Nov 20, 2008
SOURCE: roomba keeps saying clean brushes yet are clean!
Remove the Yellow connectors on the end of the brushes and clean around the pin well. If there is too much there, the roomba thinks there is something stuck and goes into clear mode (as if there is a chord stuck).
Posted on Feb 24, 2009
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Posted on Mar 10, 2009
My Roomba 560 just goes in circles and then stops and beeps. ! red is on but will not tell me what the problem is. 2 months ago it was making a clunking noise and would say that I needed to remove and...
Your bump sensors are malfunctioning. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend them...
Aug 02, 2011 | iRobot Roomba 560 Robotic Vacuum
Makes clicking noise and runs for a couple of minutes and then says error 2 open roomba and clean brush cage-do that and the same thing happens 2 minutes later
Pet hair often gets sucked into the gear box that drives the brushes and can clog it enough to generate this error. you need to remove the CHM (cleaning head module) and open the gear box on it to clean it out... you can also visit iRobots site and buy a new one that has been redesigned to avoid this issue.
Cheers, immorion
ps check out robotreviews.com for super detailed walkthrough of this process.
Nov 27, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba 530 makes a thumping noise every secondand stops with a message to clean he brushes. I have cleaned the brushes and filter but to no availe the thumping continues.
You also need to pull off the yellow bearings from the end of the brushes (one on the brush one and one on the rubber one) and remove hair from the axle there.
May 20, 2010 | iRobot Roomba 560 Robotic Vacuum
Bin barely fills. Lots of dog hair between brushes and bin, and is now dropping hair balls as it goes around the house
This is why Roomba recommends a thorough clean of your carpet with a standard vac prior to using your mini vac. Once all heavy debris has been removed, the roomba will maintain that state of clean. If you have that much dog hair, you cant expect such a small roller, brush and dustbin to keep up. sounds like you need the dirt dog instead. It is capable of handling heavier demand areas. Or the
iRobot Roomba® 562 Pet Series
Feb 17, 2010 | iRobot 560 Roomba Vacuuming Robot, Black...
New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below http://swiftracer.com/index.php?myPage=RoombaDiagnosticMode.php
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Dec 26, 2008 | iRobot Roomba 560 Robotic Vacuum
Open Questions:
See all iRobot Roomba 560 Robotic Vacuum Questions
iRobot Roomba 560 Robotic Vacuum Logo
3,324 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
