Question about Ricoh Aficio 1018 Printer
When my ricoh afico 1018 printor is on error corde desplay sc320?
  • 903 Answers
SC320 is a polygon mirror motor error. It could be caused by a poor connection or a faulty circuit board, but the most likely culprit is the polygon mirror motor itself. Replacing this motor (part #G0291961) is the most likely solution.
Hope that helps!
Posted on Sep 24, 2010
  • marietaretan Jul 08, 2011
    how much will it cost when i replay that so called polygon mirror motor.
    how much will it cost when i REPLACE the polygon mirror motor. i mean
Error sc320 how to reset this problem please explain in detail. thanks.
SC320 IS A LASER PROBLEM .
KINDLY AND CEREFULLY REMOVE THE LASER UNIT AND WASH WITH DETERGENT VERY THOUROUGHLY AND DRY UNDER THE SUN FOR ABOUT THREE HOURS AND REPLACE IT BACK TO ITS POSITION .
IF U POWER THE MACHINE AND THE SAME PROBLEM OCCURS, CHANGE THE LASER COPLETELY.
GOODLUCK.
Oct 08, 2013 | Ricoh Aficio 1018 Printer
Code sc320 errore
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Ricoh Aficio 1018 Printer
My aficio 1018 shows an error SC320 what is the most likely problem and solution
Your laser mirror motor has gone bad. You will need to have it replaced. The part number is G0291961 and they are around $125.00.
Here is a picture of what it looks like:
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 18, 2010 | Ricoh Aficio 1018 Printer
What is code sc320
SC320 is a Polygon Mirror Motor Error/Lock
Sep 14, 2010 | Ricoh Aficio 2022 Black and White Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Apr 10, 2009 | Ricoh Aficio 1013F Copier
Error SC320 appear on screen..
Polygonal mirror motor error change...
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Polygon mirror motor defective
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1018 photocopier
For the Aficio 1018. SC-320 is laser failure - the polygon mirror motor inside the laser has failed and needs replacing. You will need to contact your nearest service agent for repair.
For your RICOH Aficio 1013F - SC-551 is overheat in standby mode as far as I can tell. The circuitry that controls the fuser section ie manages the heat has problem. Unless its right near a source of heat like a heater or has no circulation around you machine you will need contact a repair agent for this machine also.
Mar 18, 2008 | Ricoh Aficio 1013F Copier
Hi it is the polygon motor failure error
2nd motor down on this link is what you need.
Nov 30, 2007 | Office Equipment & Supplies
Ricoh Aficio 1018 Printer Logo
899 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
