Question about Whirlpool Washing Machines
Hi i have a whirlpool 6th sense model no awo 3571 was wondering if there is sopose to be a ball in the pump
  • 1028 Answers
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Posted on Apr 28, 2008
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
mnwarfield10
  • 452 Answers
SOURCE: Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Posted on Dec 30, 2009
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
  • 343 Answers
SOURCE: whirlpool 6th Sense displaying FP
On the lower front panel is a small door which may be behind the kick panel. Behind this door is the drain filter.. Do not undo this filter till you have emptied the machine, as any water in the machine will flow from the pump, when opened.. Leaning the machine back against the wall will help contain what water is left in the machine..
Undo filter, check and clean.
Check that a coin or hairclip has not fouled pump impellers.
If the impeller has come away from the pump shaft, the pump motor needs to be replaced.. A tech should be called for this job!
Good luck....Nomess
Posted on Aug 04, 2010
My 6th sense a+a 7 kg awo 3571 8 year old washer doesn't seem to be adding enough water to wash or rince . Clothes have a strong smell of detergent
You should open machine from the bottom and unscrew the draining pipe that comes from the drum. In there there is a plastic ball. Take it out and put machine back together (clean draining pipe and hole in the drum where it comes together or it will leak). That ball is there to prevents spill outs in case of doom, but in practice threw time like 7-8 years it gets clogged and prevents pump to dry drum properly (can also burn your pump ergo new machine).
Now clean drum around the entrance and detergent dispenser with strong detergent (you can take product specially designed for mold or just use bleach) and after wash it on 90°C long program.
Change detergent as it may be bad quality. Try to use liquid one.
If problem persist it may be quantity of water. You can change quantity threw software (look it up and increase it, if it's set too low) (check manuals on that).
There may be human error, if you use programs that are short and cool or if you let your cloth seat in the drum after it's finish or if you add to much of detergent. You may get these results as well.
Mar 30, 2016 | Washing Machines
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Hi, my whirlpool aquasteam 6th sense washing machine has a fault, its flashing a red symbol on the screen . . what is this?
The F05 fault is nothing to do with what soaps you use.. Its a little red wire located at the front bottom centre of your aquasteam washer that has come lose or detached. A task to get to it but pretty easy and dodgey repair men would have your pants down for such a simple thing
Dec 11, 2010 | Whirlpool Washing Machines
My 6th sense whilpool awo 3516/5 washing machine wont let the water drain, now on inspection we did find that a sock was caught in the outlet pipe and we removed this but the machine will still not let the...
Might be something stuck in the flyweel of pump also try to see if pump is moving free with your fingers but before you do that unplug the unit from mains
Sep 16, 2017 | Whirlpool Washing Machines
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
Washing machine spills detergent out of its ''drawer'' (Whirlpool
Did you ever find a solution? My Kenmore washer has the same issue.
Jan 22, 2010 | Whirlpool Washing Machines
Dec 30, 2009 | Washing Machines
FP fault code on whirlpool washing machine
i have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Nov 07, 2009 | Whirlpool Washing Machines
Washing Machines Logo
93 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
