Question about HP 35s Scientific Calculator
Hp 35s...hex display showes 0h 0h cant change out of this mode
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Press right-shift [BASE] 1 to select decimal. [BASE] is the blue-shifted function of the 1 key.
Posted on Nov 01, 2010
Ifb dishwasher showing an error of 19h
How to reset / resolve Error 19H display IFB neptune DX
Follow following steps
1 power on the machine
2 push start / pause button
3 use + or - buttons to bring it to 0H
4 rotate cycle selector / circular knob to reset position
5 Display will change to 1.
6 again push the start/pause button to complete 1 min cycle.
7 after the display shows 0 . rotate cycle selector / circular knob to choose you preferred cycle.
Sep 05, 2016 | Dishwashers
HP 35s in OCT mode, calculations don't work
There are two separate issues here.
Your calculator is in Algebraic mode. To switch to RPN, press MODE 5 .
Your calculator is also in Octal mode. To switch to Decimal, press right-shift 1 1 .
Mar 24, 2014 | HP 35s Scientific Calculator
How to but the calculator in enginering mode
Press left-shift DISPLAY 3 then a digit for the number of desired digits.
Mar 06, 2014 | HP 35s Scientific Calculator
How to remove RAD from HP35s
Press MODE then 1, 2, or 3 to select the desired angular mode. In any mode other than degrees the display will indicate the mode.
Mar 13, 2013 | HP 35s Scientific Calculator
35s Scientific Calculator: How do remove the BIN expression shown on the disp...
Press right-shift [BASE] 1.
Right-shift is the blue shift key just above the ON key. BASE is on the 1 key.
May 17, 2010 | HP 35s Scientific Calculator
How to fix a none responsive button in hp 35s calculator
Resetting the Calculator
If the calculator doesn't respond to keystrokes or if it is otherwise behaving unusually, attempt to reset it. Resetting the calculator halts the current calculation and cancels program entry, digit entry, a running program, a SOLVE calculation, an ∫ FN calculation, a VIEW display, or an INPUT display. Stored data usually remain intact.
To reset the calculator, hold down the C key and press GTO . If you are unable to reset the calculator, try installing fresh batteries. If the calculator cannot be reset, or if it still fails to operate properly, you should attempt to clear memory using the special procedure described in the next section. If the calculator still does not respond to keystrokes, use a thin, pointed object to press the RESET hole.
The calculator can reset itself if it is dropped or if power is interrupted.
CLEARING the MEMORY
If the calculator fails to respond to keystrokes, and you are unable to restore operation by resetting it or changing the batteries, try the following MEMORY CLEAR procedure. These keystrokes clear all of memory, reset the calculator, and restore all format and modes to their original, default settings (shown below):
  1. Press and hold down the C key.
  2. Press and hold down the R/S key
  3. Press i (You will be holding three keys simultaneously)
  4. When you release all three keys, the display shows MEMORY CLEAR if the operation is successful.
Mar 02, 2010 | HP 35s Scientific Calculator
I have a brady label machine 2461
Hex dump mode is mostly used for trouble shooting of the printer. To exit the hex dump mode, enter the Diagnostics menu / Hex
Dump Mode and select ‘Disable’. Exit the menu, save changes and
return to the ‘READY’ mode.
Dec 07, 2008 | Brady 2461 Thermal Label Printer
HP 35s Scientific Calculator Logo
4,637 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
