I need help setting up my ANY_WAY WIFI PRINTER, using the wireless settings. I done it once before about a year ago and had to recover my laptop since and cant remember how I done it!
  • 1 more comment
  • Ross Robertson Sep 13, 2010
    thanks for the reply but i was looking for step by step installation as ive tried using the manual before (the pages you stated), with no success. i need to know what to change in the 'NETWORK' and 'WIRELESS' tabs within the toolbox of the printer settings and also what to change them to.
    I HAVE THE ANY_WAY WIFI PRINTER/SCANNER/PHOTOCOPIER AND NEED TO KNOW HOW TO GET IT SET UP TO WORK WIRELESSLY. I HAVE GOT IT WORKING USING THE USB CABLE AND HAVE HAD IT WORKING BEFORE USING WIRELESS BUT CANT REMEMBER HOW I DONE IT. I NEED TO KNOW WHAT SETTINGS I SHOULD INPUT IN THE 'WIRELESS' SECTION AND ALSO THE 'NETWORK' SECTION, WITHIN THE OLIVETTI TOOLBOX.
    NEED HELP FAST AS ITS REALLY STARTING TO ANNOY ME NOW ............ AAAAAARGH!
    THANKS IN ADVANCE
    ROSS
    thanks for the reply but its not the drivers im having a problem with!
    i know how to get the drivers and how to install it via usb. i need to know the settings to use for the NETWORK and WIRELESS tabs, within the OLIVETTI TOOLBOX!
    President:
  • 4,070 Answers
Hi! Turn on the printer's wireless connection and turn on the laptop's wifi connectivity. Once they see each other you can start pairing them and use it wirelessly. Hope this helps and thank you for using FixYa!
Posted on Sep 14, 2010
  • 734 Answers
Your drivers/software for your printer are on the page below. Download the one that fits your printer by saving it to your Desktop and then install the software from there. Be sure not to connect the printer until prompted.
http://www.olivetti.com/site/public/support.asp?sid=1&code=B9173
Good Luck,
Marcus
Posted on Sep 13, 2010
  • 19,396 Answers
Hi.
You need drivers and an USB cable.
First install the printer as USB, then follow Activating Wi Fi components. Procedure is detailed from page 9/part 3 of manual below.
Here the manual for Olivetti AnyWay
If you have misplaced the printer disk, then you will need to download the drivers from Olivetti website: CUSTOMER CARE - Olivetti
How to set up wireless printer to laptop step by step
1 install Wifi printer driver to computer (not just normal driver)
2 install wifi dongle If required
3 run printer driver and search for wifi printer and once found ADD to printer list
4 print away
Feb 19, 2014 | HP Deskjet D2545 InkJet Printer
Wifi hotspot
Try to use this program to help you! My laptop can't turn on hotspot not long ago. And a friend sent me a program, which help me turn on WiFi hotspot on laptop!
Top 3 Ways to Create Build Set up Free Wi Fi Hotspot on Windows 10 8 1 8 7...
May 14, 2013 | HP Compaq Presario CQ60Z Notebook
I am not able to connect wirelessly with a new dell inspiron mini 10 i have fios at home and it will not connect
If your trying to get on the internet with a wireless connection..and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (unplug for a few minutes) try --be sure the wifi switch is enabled on the netbook---try---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Dec 28, 2010 | Dell Inspiron Mini 10 Notebook
My lexmark x4975 will connect by USB but will not connect by wireless. The help assistant asked if any lights were showing on the WI FI indicator - none are lit. How can I make wireless connection?
using your pc/laptop you will have to create a new connection an search for the printer when this has been done, make sure the printers wireless is enabled before attempting to create a new connection
May 03, 2010 | Lexmark X4975 Wireless Color Multifunction...
Can I connect wirelessly to this printer from my laptop
If this printer has Wi-Fi then yes you can connect to your router.
The printer must have an internal Wireless PServer it will have a Node Name this is what is needed to connect to the Router. If your router is set for Wireless and the SSID is working (ie no wirless isolation) then when you set up the printer driver it will ask you to connect to the router via an ethernet 100MB patch cable first to load the correct type of port for the printer drive, you only need do this once.
Then if the printer is set to boot in WLAN mode it should get an IP address via DHCP on your router.
Hope this helps, please rate my advice I will post more help if needed just add on to the end of this post.
Oct 15, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
Can't connect Toshiba laptop to Linksys Wireless Routher!!
If this is a new router then the wireless is turned off by default. You need to log on to it and enable it. Don't forget to turn on security such as wep or wpa. Your toshiba should be able to see the ssid or id that each wifi broadcasts. It will also or should be the strongest signal you see.
If the router is older and the wifi is enabled then make sure that the security setting match on the toshiba. ie wep/wpa key. If it is more than about year old then you can have a failure of the wifi section. That means replaceing the router ( I have a stack of different brands all about 1 year old with a dead wifi section).
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Can't get computer and printer to communicate
Make sure the wireless LAN of your computer is set to AdHoc mode if the Printer is set to that function.
Mar 11, 2009 | Office Equipment & Supplies
150 people viewed this question
jasbo
jasbo
