I have the Whirlpool cabrio, 2years old I believe now. During the spin cycle, I hear a crackling sound from the bottom back right side of the machine when it pumps water out. It almost sounds like a loose piece inside the pump or something. Other then the sound it makes which is not continuous, the machine does not bring up any alarms or codes of malfunction and pumps water just fine. Any suspicians what it may be? Worried about something ready to go.
Did you ever resolve this. I am having the same noise
Posted on Nov 15, 2010
  • Jim Weaver Sep 28, 2011
    I too have had noises that sounded like a loose piece inside the pump. And the washing machine began leaking from the larger right rear pump. I took it apart and found a dime inside. The dime had punched a hole through the outer plastic shell of the pump body. And you can't buy the outer plastic shell separately. Rather than spend the $110 for a new pump, I mixed up some West System epoxy with some fiberglass strands and bonded most of the outer shell back together. Worked great! But tonight, the same problem. I took the right rear pump apart, no problem. So I then dismantled the left rear pump and found -- a dime. So I'm going to remount both pumps closer to the floor so I can fit long hoses to the pumps and fit some kind of separator in the feed hose to each.
    I am really ****** that Whirlpool wouldn't have considered the possibility that tiny objects would end up in the pumps and cause problems. Whatever happened to the separators that Frigidaire used to put in their washing machines. And we are REAL careful to check our pockets for change, tiny washers, etc.
    Jim Weaver
    515-292-3346
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool WTW6400SW Cabrio Washer
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking water from bottom of washer
Did you hear a clicking noise during the spin and drain cycle? If so, then change has gotten into the tub and discharge pump and cracked the plastic housing on the pump. had the same problem. Had to replace the pump.
Nov 25, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Loud during the spin cycle.
would suspect something in the drain pump rather then something witht he tub, tip unit back and check for debrisin right hand side pump
Mar 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
Open Questions:
Washing Machines Logo
Top Washing Machines Experts
