Question about NewCon Optik LRB 20,000 A Laser Rangefinder
I have LRB20000 .It gives wrong measures and the measures are different values even when we aim at the same target .Some times the indicator gives zero reading .There is no stimulation tone when pressing measure. thanks alot
I overheated my Makita 9557PB angle grinder. I replaced the brushes. Bearings seem ok: the motor assembly turns freely, smoothly, and quietly. The running motor is slow, with a loud "grinding" sound.
Measure the value difference in Ohm between the carbon brushes on the armature there are some collectors in the commutator give an other ohm value if compared to other collectors in the comutator of the armature . if measure turn the blad very slow so the collectros can be positioned to measure the ohm difference. range to measure 0-200ohm on ohmmeter.
If only one brush made trouble ( much more sparking ) then the electric field is not in ohm value balance, control always if there are slide contacts used they are solid. on the field. Measure the difference. between the 2 field coils of the electric field . if its also different replace allways the field and the armature if thats also have problems (BUT DON,T FORGET to order a new drive gear for the armature and new brushes. !!!
Aug 28, 2016 | Makita 4-1 2 in Grinder 9557PB
Is the 2 auto aim gta5 ps3
- Make sure you're in GTA5 story mode
- Go to start menu
- In Settings, go to Controls
- Switch targeting mode to Assisted Aim (Partial) or Assisted Aim (Full)
With Assisted Aim (Full) you can even switch between targets.
Jan 19, 2016 | Sony Playstation 3 (PS3) Console
Wii ghost recon. Can not fire the rocket launcher. I press the Z button to aim,then when I press the B button it dose not fire. What am I doing wrong?
Try Reload (Aim Off-Screen press B button). Possible that your Rocket Launcher is not loaded?
Also remember, the Zeus has to be aimed at a target for three long seconds before it can fire. (due to the fact that it is a target-seeking rocket launcher)
Jul 30, 2011 | Nintendo Video Game Consoles & Games
Iv put two of the same record on each deck and set them to 0% and I have to adjust them to keep them in sync
The problem is the "tolerance" of the electronic components that go into all electronic devices - your turntables included. Take a simple resistor. Buy 2 (or even 2 dozen) of the same value and measure them with the same meter. I bet you'll see to different values displayed. Next, use a different meter to measure the same resistors - I bet they display yet different values. You can do the same thing with 2 transistors, capacitors - you name it. It's not limited to just electronics, either.
Manufacturing processes have not managed to hit the 100% predictability mark yet. As a result, no two parts produced are exactly the same. No two loads of raw materials are the same - so it is going to be practically impossible for the finished output to be the same. Sure, they've come close - but I doubt we'll ever see the kind of similarity between supposed "identical" devices that you're looking to find.
You may find that "sweet spot" of pitch on 2, 3 or even 50 turntables where they play exactly in sync, but the indicator dials will not be in the same exact spot.
I hope this helps.
Dec 28, 2010 | Vestax Pdx2000 Direct Drive Turntable...
Unit puts out AC172v not 240vac,Setting
I think you measured the o/p voltage by digital multimeter which measure r.m.s. voltage that gives the wrong value measure the voltage by anolog miltimeter that meter shows the pointer and will gives proper value definetly upto 230vac
Mar 07, 2010 | MGE UPS Pulsar Evolution 1500 UPS System
Our online UPS is giving only about 204-206 volts, instead of 240. I changed the batteries, but the output voltage hasnt changed. What could be the problem? Could you suggest some things I can try?
oh that voltage is ok if you are measuring voltage by digital multimeter then it shows wrong value measure voltage by anologue multimeter it will show 240v correctly dont suspect on measured voltage
Feb 27, 2010 | APC Symmetra RM 2 kVA UPS System
How do I use the Bell AirStrike Digital Floor Pump
The gauge measures three different amounts. Be certain that you have it set to PSI. Then set the target PSI. The green LED indicator will then flash when you are within 5 PSI of your target and will flash constant when the target PSI is reached.
Jan 02, 2010 | Airstrike Bell 1800 Floor Bike Pump
How to read the different scale on an ohm meter ,moving the decimal point to get the right value
The setting of the control knob or push button selects the maxmium value it will measure at that setting.If the resistance you are measuring is above this setting you will get an out of range indication.Different units signal this in different ways.
You will then need to move to at least to the next larger number up until you get a number reading.
Hope this helps,Eric
Sep 23, 2009 | Measuring Tools & Sensors
Excel formula creation
= (a3) minus (b3) won't do it for you?
Sep 05, 2008 | Excel (SS8SATAS5128400R)
Optics Logo
48 people viewed this question
Top NewCon Optik Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a NewCon Optik Optic Expert? Answer questions, earn points and help others
