Question about Troy Garden
My pony wants to just take off just pulls across the garden no matter where i set the depth handle what do i do so my tiller will just dig the garden
  • Troy Master
  • 8,404 Answers
Your garden seems to be especially hard. Set the depth to the minimum and hold it back if it wants to run away with you. Continue back and forth ... maybe side to side ... increasing the depth slightly as you complete each series of passes. Key is holding it back.
Posted on Sep 13, 2010
Troy bilt pony,moves so fastu cant hold it back,??????
I found that when you have the tiller at full throttle it can get away easily. Try pulling back the speed a bit and change the depth of the tines to grab a bit more but not enough to launch it. Good luck! Hope this helps you. Cheers, Michele
Oct 20, 2014 | Troy-Bilt Pony Garden Tiller
Tines on tb sr with tecum engiene wont dig gearlube is full
Gear or key could be sheared or broken or stripped. disassemble to see. Try to turn tines freehand if they turn internal problem exist disassemble to repair.
Apr 09, 2014 | Troy-Bilt Pony Garden Tiller
Tiller takes of and can't control where going
There should be a handle you pull to engage the tines and drive wheels. A cable runs from the handle to the drive pulley that essentially 'puts it in gear' when the handle is pulled. Either the cable is not disengaging when you release the handle or it needs adjustment. First try spraying some liquid wrench or WD40 at each end of the cable and pull the handle a few times (take care not to get any on the drive belt). This may free it up. Otherwise check your owner''s manual for the procedure to adjust it properly. Good luck.
May 22, 2011 | Troy-Bilt Pony Garden Tiller
Tiller running off, can't control it.
Slowly lower your tilling depth regulator a little at a time. Make a pass or two with it set almost as high as it will go then drop it a couple of notches and keep making more passes over the same ground. If you lower the tines to far down on hard ground it will just take off like you are describing. Just take it slow until you get your ground worked up and then it will work great.
Frank
Jun 09, 2010 | Troy-Bilt Pony Garden Tiller
I have a Pony 1100 series Rotiller that takes off very fast and hard to control (I'm not a small guy either)even after setting the throttle at the lower speed and adjusting to depth highth. The ground I...
The reason that it does this, is your tiller is too light. There isn't enough weight to make the tiller dig without lifting the tires up and running on the tines. MTD owns troy-bilt now, and has made them light and cheap like the rest of the MTD lines. Your best bet is to add additional weight to the front, back, and you can even add weight to the tires if you wish. The easiest way is a rock or piece of concrete on top of the handle where the handle meets the engine. I mixed up concrete and cast it onto the front guard, put some in a plastic garbage bag and hung it in that same place I described for a rock, and let it set there. Then I took off the bag, and I have a form-fitting rock that can be removed if you wish. The extra weight will keep the wheels down, and make the tiller more manageable.
Mar 07, 2010 | Troy-Bilt Pony Garden Tiller
Troy bilt jr tiller
If you try to till too deep, this is what will happen. You have to start shallow and and gradually lower the depth on subsequent passes. That will even happen on my 'Horse' model if I try to go too deep too fast.
May 25, 2009 | Troy-Bilt Pony Garden Tiller
Tiller will not till in forward motion.
sounds like your drive belt is worn or the handle bar adjustment is too tall and your handle is not adjusted.
Apr 26, 2009 | Troy-Bilt Pony Garden Tiller
Pony Tiller (1985). Pull cord does not pull/frozen in machine.
see if the motor turns over pull the spark plug put some lubricant inhole other wise pull off pull cord assembly try turning crank becarfull not tobreak rings moveback and forth little bit at atime if it turns over check pull cord out
Mar 28, 2009 | Troy-Bilt Pony Garden Tiller
WHEN TILLING TILER WONT MOVE FORWARD WHEELS JUST SPIN. HAVE TO PICK UP ON HANDLE TO GET IT TO MOVE.
Usually this means you are trying to dig too deep in one pass. Try setting the depth such that your first pass only scratches the surface, dislodging grass, etc. Then, on successive passes dig 1-2 inches, this will prevent the tines from "biting off more than they can chew" and holding back the machine. It will take about 4 passes to till one tiller width in "loose"(garden) soil and possibly more elsewhere. Hope that helps.
Mar 13, 2009 | Mtd Super Bronco Rt Tiller
Garden Logo
150 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
