Question about Linksys Wireless-G WRT54GS Router (e125894)
My boyfriends sister just gave us a wireless router - I can get it hooked up appropriately, but I don't have the CD rom or the network key! HELP? can we use it?
smeago1
  • 136 Answers
SOURCE: Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Posted on Jan 07, 2008
luiskiev
  • 144 Answers
SOURCE: How can i reset my Linksys Wireless-G2.4GHZ Broadband Router settings
Try to reset the router. This should resolve your problem. That model has a small hole were you must press with some a paper clip for exemple for a few seconds. This will reset the router to its original state.
Posted on Nov 07, 2008
  • 41 Answers
SOURCE: Lost encryption key for wireless connection
Yes there is a way you can find out the encryption key or passphease. You can also change it according to your preference.
first connect the router with an ethernet cable to the NB
Go to command prompt and type IPCONFIG
get the default gateway number
type the DG number in the internet explorer address bar
it will prompt for a username and password
Default username : admin
Default password : admin
not once u you are at the router configuration page go to wireless tab and click on wireless security
type the 10 digit phone number in the key 1 boz and make sure it is selected as yr passphrase
not reinstall yr wireless card drivers and connect again
it should work
for further help refer to this link :-
faculty.valenciacc.edu/wyousif/WLAN/Presentations/Configuring%20Linksys%20Wireless%20Router.ppt
Hope this helps..
Regards,
Anup
Posted on Apr 06, 2009
  • 8404 Answers
SOURCE: I was installing the Linksys router and I hooked
Replace your cat 5 cable please. I believe you have a bad cable end. DO NOT DISCARD THE CABLE UNTIL PROVEN FAULTY.
It is also possible you have a faulty port on the router. Though rare, it does happen. Drove me nuts one evening. It was a short trip.
I have lots of experience with cables having 25 computers on 5 networks in my home. Why? Darn good question my friend. I have made 99% of my cables.
Thanks for posting at FixYa.com
please vote
positive comments appreciated.
thanks
a
Posted on Dec 13, 2009
nblady
  • 206 Answers
SOURCE: Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Posted on Feb 19, 2010
Testimonial: "Thank you for your suggestion...I tried it to no avail. I also received an email that said my cable may have a problem??? I am so frustrated."
Tring to get PC to send signal to hp printer thru belkin N300 router
  • Hook up printer to network.
  • Give the printer a static IP address outside of DHCP scope. (If your network address is 192.168.0.0 typically any address from 192.168.0.1-50 will be. 192.168.0.1 will usually be your router.
  • Install the printer on computer with appropriate driver and install as a network printer, not local.
  • Enter the IP you gave the printer.
  • Done
If your printer doesn't have networking capability let me know and I can explain setting up a printer share.
Jan 10, 2013 | Belkin Basic Wireless Router
I have a netgear wgr614 wireless router but don`t have the network key how do i obtain it?
You can do a reset on it and put the CD in and run the setup again and put your password in.
Apr 20, 2011 | NetGear WGR614 Wireless Router
Hi I'm trying to connect to my sister's internet and asked for WPA key, i looked on the router box but not sure which number to use? can u help pls
You might try using the router serial number which is sometimes used as the default key. However, it's also possible the key was changed through the the router's setup pages. If that's the case, you'll need to get the key from your sister if she has it recorded somewhere. There may be a text file somewhere on her computer with the network setup information listed. You can also reset the router, which will restore factory default settings, and go through the network setup and set a new key.
Dec 17, 2010 | Arris SURFboard SBG900 Wireless Router...
My sister gave me her Linksys wireless router and I have a laptop but I can't seem to get it to work, it kept saying there an error after i install the disk to my laptop
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 27, 2010 | Linksys Wireless-G Broadband Router
Can't hook up to wireless network w dlink key
have you ran the installation wizard that came with that router. it will make the connections for you. and you have to have a wireless adapter in your computer and turned on when you do it. the wizard will walk you through it, it is one the installation cd
Dec 29, 2009 | Computers & Internet
Will not connect to internet. no drivers in computer
The WRT54GS router from Linksys is a wireless-G broadband router. This router lets the user access the Internet through a wireless connection as well as use it to share resources among computers on the network. The Linksys WRT54GS comes with a CD-ROM, which will run a Setup Wizard to walk you through configuring your router. Without the CD-ROM, configuration can be done through the router's web-based utility.
  1. p 1 Launch your web browser, then type 192.168.1.1 in the address field. Press "Enter". On the password screen, leave the user name blank. Use admin for the password. Click "OK".
  2. Step 2 Select the appropriate Internet setup settings in the Setup>Basic screen. Many of these settings are obtained from your Internet Servicemag-glass_10x10.gif Prvider (ISP). Other than the settings obtained from your ISP, the default settings should work for most network applications. Set the time zone in the "Time Zone" field. Click "Save Changes" before navigating away from this screen.
  3. Step 3 Select the appropriate wireless standard from the drop down menu in Setup>Basic Wireless Settings. If in doubt as to your wireless standard, leave the default selection at "Mixed'. This will work for most network applications. Type a name for the Wireless Networkmag-glass_10x10.gif Name. This name must be identical for all wireless devices on the network. Click "Save Settings" before navigating away from this screen.
  4. Step 4 Select the appropriate security method for your wireless network in the "Wireless>Wireless Securitymag-glass_10x10.gif" screen. If you do not wish to utilize security, leave the default setting of "Disabled". It is recommended to use some form of security for your wireless network. Whether you use WPA or WEP security, all devices on your wireless network must use the same encryption method and encryption key. Click "Save Settings" before navigating away from this screen.
  5. Step 5 Reboot the router so all the changes take effect.
Nov 14, 2009 | Linksys Wireless-G WRT54GS Router...
I have a linksys wireless router that someone just gave me but i dont have the installation cd. Is there any other way to install it? I have tried hooking it up but i get nothing.
No need ti install cd for router
steps
1,connect router to isp provider connection
2,connect network cable from the laptop/pc to router
type ip address of the router on the computer browser
eg:192.168.1.1
username:admin
password: admin or admin12
configure the router by the help of isp provider
Nov 01, 2009 | Linksys WRT160N Wireless Router
I have DI524 wireless router but no network key can you help
- Try to enter 10 Zeros as your network key or your friends home phone number.
Mar 16, 2009 | D-Link AirPlus DI-524 Wireless Router
Not able to hook this router up
on the right track
connect modem to router WAN port
connect pc to modem LAN port by cable
DO NOT use wireless to configure router
http://192.168.0.1 is the address of the router
the admin name is 'admin' no quotes
the password is blank, not the word 'blank' a blank screen.. unless your sister changed it
read the online help
set an admin password
set a WEP encryption password
after config router can use wireless if prefer
NEVER make config changes by wireless
Oct 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
14 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
