Generic functional diagram showing all input/output connector pin-outs and signal names for a motherboard
  • vze1urce Sep 13, 2010
    Your ans. is a good start but I would like to make a readable printed copy. Further, I would like typical external pin-out vs line names for the various connectors (printable) That might get me to where I want to be as-re my understanding of the mother board. Just tell me where I can find the info. BillZ
  • vze1urce Sep 15, 2010
    Thank You
  • 4,323 Answers
Hi
The schematic of a generic maotherboard--
The block diagram of a generic motherboard--
This is another system block diagram--
Hope this helps... If it does please do not forget to accept the solution or post back for more details or any further assistance.
Daniel
Posted on Sep 13, 2010
  • Daniel Scott
    Daniel Scott Sep 14, 2010
    Hi Bill,
    You can click those pictures to view an enlarged view. Also check this picture--
    Motherboard picture
    Daniel
  • 734 Answers
HI there,
Go to this page and you'll be in motherboard diagram/manual heaven in no time.
http://www.tech-faq.com/where-to-find-motherboard-manuals.html
Best Regards,
Marcus
Posted on Sep 14, 2010
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Specifications nec fd 1137c
what are you looking for? Here is what I have:
LED Indicator: Green
Interface Connector: 34-pin connector right-angled header connector
Operation Mode Write / Read: 2MB mode / 1.6MB mode / 1MB mode
Disk Used
(90mm / 3.5): High density (2HD) / High density (2HD) / Normal density (2DD)
Data Transfer Rate: 500KBps / 500KBps / 250KBps
Unformatted Data Capacity: 2MB / 1.6MB / 1MB
Rotational Speed: 300rpm / 360rpm / 300rpm
Track Density: 5.3 track/mm (135tpi)
Track to Track Time: 3ms
Required Power: +5V single (4.5V ~ 5.5V)
Signal Output Driver: Open Collector TTL
Input signal Pull-up: 1K Ohm 30%
Function Setting at Delivery: Interface Setting:Pin2: MODE SELECT input (LOW: 1.6MB mode) Pin12: DRIVE SELECT 1 input Pin34: DISK CHANGE Output Other Function Setting: 1. Automatic density setting for 2DD (1MB) disk or 2HD (1.6MB/2MB) disk 2. LED Turn on Condition: DRIVE SELECT 3. Motor Rotating Condition: MOTOR ON 4. Ready and seek-complete gate (full-mask) for INDEX and READ DATA output pulses 5. Auto-chucking at disk installation 6. Auto-recalibration at power on 7. Frame is electrically shorted to DC 0V
Dimensions: 101.6 W X 25.4 H X 145 D mm excluding front bezel
Weight: 345g
Mounting: Vertical/horizontal with spindle motor down
MTBF: 30,000 POH
Safety Standards: UL, CSA, TUV
May 27, 2014 | Teac Computers & Internet
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
    Mouse
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    Line in what is that for
    In general:
    Line In is the standard name for any generic audio input. Line Out would be for the corresponding output.
    It allows a standard for audio equipment manufacturers to use when designing for interconnection.
    http://en.wikipedia.org/wiki/Line_level
    "Consumer electronic devices concerned with audio (for example Sound cards) often have a connector labeled "line in" and/or "line out". Line out provides an audio signal output and line in receives a signal input. The line in/out connections on a computer sound card are generally unbalanced, with a TRS connector of 6.35 mm (1/4"), 3.5 mm (1/8" miniature) or 2.5 mm (3/32" subminiature). The connections on most other consumer equipment use RCA jacks. In most cases changing the volume setting on the source equipment does not vary the strength of the line out signal."
    Jan 11, 2011 | RCA Electronics - Others
    Mother board
    Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
    Pros: None noted, given available product data.
    Cons: None noted, given available product data.
    Suitability: A compact motherboard, suited for small computers.
    Value: In view of its inexpensive price, this motherboard has great features for the money.
    Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
    XFXg31
    General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Shrinking of the display
    The DB15 VGA (Video Graphics Array) connector contains however 15 pins in three rows of 5 pins each. These five pins carry the color and synchronisation signals, also a digital I2C interface for two-way communication between the video controller and monitor. The common 15-pin VGA connector found on most video cards, computer monitors, high definition televisions which support VGA connections. The following schematic diagram and table shows respectively connector and pin assignment of DB15 VGA.
    Pin
    Name
    Function
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    RED
    GREEN
    BLUE
    n/c
    GND
    RED_RTN
    GREEN_RTN
    BLUE_RTN
    VDC
    GND
    n/c
    SDA
    HSYNC
    VSYNC
    SLC
    Red Video
    Green Video
    Blue Video
    not connected
    Signal Ground
    Red Ground
    Green Ground
    Blue Ground
    5 VDC supply (fused)
    Signal Ground
    not connected
    DDC/I2C data
    Horizontal Sycn
    Vertical Sycn
    DDC/I2C Clock
    Aug 10, 2009 | SAMTRON 55V 15" CRT Monitor
    Front panel connector J16 dell dimension 2350
    Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
    Jul 15, 2009 | Computers & Internet
    Gateway Intel 850 Socket 478 ATX Motherboard Power Supply
    Please use the following as a reference: ATX12V Power Supply Design Guide, http://www.formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf
    Sections 4.5.2 and 4.5.3 (Page 38) list the signal and wire colors for the +12V2DC (2x2 pin) and Peripheral (Molex) Connectors. Figure 11 (page 36) shows diagrams of the connectors and pin-outs for reference.
    Most likely, you are looking for the 2x2 pin connector; pins 1&2 are common (black wire), pins 3&4 are +12V2DC (yellow wire w/black stripe)
    Dec 14, 2008 | Gateway (4000782) Motherboard
    EPSON PHOTO PC 500 DIGITAL CAMERA
    Serial meaning 2.5mm stereo headphone looking jack to DB9 or "atari joystick" looking plug? I had one on my first Toshiba PDR-M1 camera but that was like 9 years ago. You can probably find the pinouts online for that cable, I believe it is a standardized cable.
    The stereo plug is wired to the PC serial port as shown in the following diagram:
    tip ring sleeve +---------------------------------+
    | RxD | Gnd | TxD | 2.5 mm Stero Plug |
    DB9*: pin 2 pin 5 pin 3 +---------------------------------+
    DB9*: Optionally short together pin 4 (DTR) to pin 6 (DSR) and
    pin 7 (RTS) to pin 8 (CTS)
    The following table also describes the camera cable's wiring: Camera PC's
    Plug DB9* Signal Name Direction
    - 1 Carrier detect (CD) input to PC
    tip 2 Receive data (RxD) input to PC
    sleeve 3 Transmit data (TxD) output from PC
    - 4 \ Data terminal ready (DTR) output from PC
    ring 5 | Signal ground (Gnd) -
    - 6 / Data set ready (DSR) input to PC
    - 7 \ Request to send (RTS) output from PC
    - 8 / Clear to send (CTS) input to PC
    - 9 Ring indicator (RI) input to PC
    * Note that the cable's D-subminature DB9 RS-232 serial port connector is female. This connector also goes by the historically more correct name of "DE-9J".
    Feb 22, 2008 | Epson PhotoPC 500 Digital Camera
    JENSEN XA 184 AMPLIFIER
    Hi, Jensen is under different ownership from when your amp was made, so it's unlikely that you'll find a replacement plug for the high-level input. A high-low converter is also called a line-out converter. It's a device that connects to the speaker wires and changes the signal to a low-level RCA connection. This allows you to use the amp's RCA plugs with your speaker wiring (through RCA signal cables). A line-out converter should be available any place that sells car audio accessories.
    Aug 11, 2007 | Jensen XA92 Car Audio Amplifier
    Computers & Internet Logo
    942 people viewed this question
    David Payne
    David Payne
