Question about Faberware Coffee Makers & Espresso Machines
I need to replace the coffee basket on my Farberware 155A Coffee Urn and cannot find it. I have tried thepartzbiz.com and MarBeck.com. Any suggestions?
SOURCE: Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Posted on Apr 04, 2008
SOURCE: Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
Posted on Jan 12, 2009
  • 59 Answers
SOURCE: My 25cup Farberware urn quit perking coffee can it
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Posted on Dec 04, 2009
Testimonial: "I will try the cleaning methed first. Thanks for the helpful hint. I don't use it very often,so I'll see."
espressonist
  • 1711 Answers
SOURCE: How much coffee Decaf do I use for 55 cup
Depents from the aroma and taste you want. You can use from 7 up 9.5 gr per cup of about 150cc
Posted on Feb 17, 2010
  • 176 Answers
SOURCE: Need instructions for use of Farberware 55 cup Coffee Urn
Hi 2 scoops of coffee to 3 cups not mugs. Then take it from there, adjust to your liking. Ron
Posted on Jul 27, 2010
I need an instruction manual for my Farberware 36 cup coffee urn.
Hello!
I think that this instrucion manual will work for you: http://www.useandcaremanuals.com/pdf/FSU122.pdf
It would help if you mentione the model of the coffee urn.
Greetings!
Mar 25, 2016 | Farberware Coffee Makers & Espresso...
I have an 18-55 cup farberware stainless steel coffe urn. I loaned it to a friend and the manual is now missing which includes the directions for making the coffee for the various cup levels. Can you...
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For coffee makers try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FiXYa!
Aug 08, 2011 | Farberware Coffee Urn 1255 cup Coffee...
I just purchased, what seems to be in very new condition, a 55 cup Farberware electric pot. It did not come with directions. I would think a 1lb can of coffee in the basket? There must be a fill line...
For coffee urns try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Jul 23, 2011 | Faberware 12-55 Cup Coffee Urn
We want to make 42 cups in our Farberware Urn. How much coffee in oz. should we use to make medium strong coffee? Thanks.
For coffee urns try the e-mail address for Electric Appliances. Send your model number with your request for a manual.
Sorry some one has not responded sooner but I think this had to do with lack of a ready source.
Feb 15, 2011 | Faberware 12-55 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
Need pump tube for 55 cup farberware coffee urn.
Hi. Go to repairshack.con. Good luck. bobbyone
Sep 10, 2009 | Faberware 12-55 Cup Coffee Urn
Have lost instructions for how to make coffee in FSU235
This site can help. It is a pdf file with chart and instructions: http://www.pacificpartycanopies.com/images/pdfs/coffee-urn-36c.pdf
May 18, 2008 | Faberware Farberware FSU236 12-36 Cup Urn...
Coffee Makers & Espresso Machines Logo
37 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Dael Escher
Level 1 Expert
Kolbrun...
richie46
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
