Question about Electrolux Dryers
Hi! Have a Electrolux front load dryer Model LEQ2152ES0 approx 5 yrs old. It will start but shuts down immediately and the display reads PF. It will run with on the "No Heat" cycle but that's it. Unpluged the dryer for half day but that didn't help.
    President:
  • 1,554 Answers
There are only two possibilities why this happens. First is a faulty control board and second is a fault in the heating circuit and there's one simple way to determine which is which; that is disabling the heating element by disconnecting the safety thermostat.
Start by unplugging the dryer then remove the two screws securing the to panel to the rear of the dryer as shown and lift the panel off.
Once the top panel is removed, locate the safety thermostat on the heater housing at the rear of the drum with black and red wires. Refer to the illustration for the location of the safety thermostat.
Disconnect the wires from the safety thermostat terminals and properly insulate the connectors with an electrical tape. Hi! Have a Electrolux front load dryer Model - 222f006.jpg them together.
Once the wires are insulated, plug the dryer back in and run it in heat setting mode. Check the heating element coils for any part touching the housing if the dryer does not shut off. Otherwise, replace the electronic control board which is part number 34523200.
Posted on Sep 13, 2010
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
When I load my clothes into the dryer and turn it on it runs for approx a minute to a minute and half then shuts down and starts flashing pf on the display.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Kenmore Elite Oasis ST 6806 Electric Dryer
Dryer model # ALE866SAW approx 9 years old ran great until tonight. Went to touch up load of whites (socks underwear etc) and get a sound from the back that sounds like an electric motor that just went on...
Yes it sounds like the motor is bad and that is very fixable, but what about the belts the guides and the wiring??? If this has been used hard ( more then 6-8 loads a week for 9 yrs then I would go new...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 09, 2010 | Dryers
PF display -power failure
you have short somewhere could be broken element or just broken wire
Apr 23, 2010 | Kenmore Elite 45986 Front Load Washer
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
DISPLAY SAYS "PF"
HI, there may have been a power surge that shut this unit down or, the junction box may be shorting the power sector. this will damage the main control in this case. i recommend shutting the power off by, pulling the unit plug from the wall socket or, shut the circuit breaker off. let the unit sit for 5 minutes without any power. this will reset the logic chip.
Power the unit back up after this 5 minute wait to see if the reset worked. if the PF is still present, this will confirm a main control fault. replace the control in this case.
**check the power cord junction point for worn connections.
Jul 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Model LEQ2152ES0
check the drive belt is on the pulleys
Jul 08, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
421 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
