Question about Craftsman 25cc Gas Line Trimmer
I pull cord it turns over but to no avail, it sounds like it wants to start. I think it has to do with the two small screws underneath the throttle dont really know the names i checked the spark plug changed it and all, need help
  • richdawg_tor Sep 13, 2010
    its a 31cc craftman sorry is there a great difference between 25 and 31?
  • 1,041 Answers
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carburetor cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Sep 13, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    No, all are basically the same when it comes to the carburetors.
After warming up my 350 will not idle down, over rev's and seems weaker than it was power wise. I compared compression to my dads exact same saw and they are identical? His runs excellent and strong...
Sounds like it is running a little too lean, replace the fuel filter in the fuel tank first, check the fuel hose up to the carb for cracks or leaking, to make an adjustment to the carb screws will require pulling the anti tamper sleeves back on the screws, you will only have a small amount of adjustment before doing this, to pull them back you need to find a very small self tapping screw, this will screw into the end of the plastic sleeve, when it strikes the screw head underneath the cap will draw off, do not pull it right off, only far enough to insert a 2mm flat screw driver through the middle of the sleeve and turn the screw underneath, screw the L screw out 1/4 turn, and the H 1/8 turn out, then see if it has made any improvment, erratic/fast idle can also be due to and air leak, or the small impulse hose from the cylinder has cracked or come adrift, to check this will require removing the carb, the pipe is a small curled pipe conecting the carb fixing plate to the induction tube.
May 11, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I cannot remember how to start my tiller
This Could be a problem? Turn the fuel on, place throttle lever to choke, prime if available and pull cord. when running move throttle to run. Good Luck, your gonna need some!!!!
Apr 20, 2011 | Mtd Products Yard Machines 158CC Tiller
I have a 350 husqvarna, starts up fine, runs fine when at half throttle, when u put into full throttle it lacks power and backfires, go back to half throttle runs fine
This is classic fuel starvation, start by removing the fuel hose from the tank and replace the filter on the end, if no better, it may be a tank breather issue, when the saw starts to die slacken the fuel cap, if the saw picks up you need to replace the breather, if no better you can make a small adjustment to the H screw on the carb, unscrew ( counter clockwise ) the H screw this will richen the mixture, you will need to pull the anti tamper sleeves back on the screws, this can be done by gently screwing a suitable self tapping screw into the sleeve, when it hits the screw head under neath the sleeve will start to pull back, once pulled half way off you can enter a 2mm screw driver through the centre if the sleeve and intp the slot in the adjuster screw underneath.
Mar 01, 2011 | Husqvarna 350 Rancher Chain Saw
I turned the screw labeled T all the way out by mistake when i was fixing the pull cord.It runs with the screw back in but it will not idle .I was wondering if there is a good start point {like all the...
There should be a small compression spring on the screw which helps hold the adjustment setting. Did it get put back on? If the screw is all the way CW, the engine should idle at a high speed (enough to cause the chain to turn). Normal procedure is to start the engine and adjust the screw til the chain stops trying to turn, but the engine will continue to idle without stopping. Remove the cover over the air cleaner/carburetor to inspect the screw action on the throttle arm of the carburetor. Hope this helps!
Dec 19, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Pulon pro 200e cord is stuck and wont pull. It's stuck Cord seems to be stuck in the recoil positionl I was pulling it and it was retracting, I was pulling pretty fast because it would not start and the...
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. You may be able to remove it with a long thin-blade screwdriver also.It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the top of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the handle. Reassemble and you are done. Disassembly requires Torx head drivers or a good flat-blade screwdriver.
Nov 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Homelite trimmer ut 15151 How do I replace pull
Nov 10, 2010 | Homelite Garden
Need to replace pull cord on craftsman weedeater it is a standard residential model with pull cord located under motor
Nov 03, 2010 | Garden
How can you start a Ariens 824 snowblower
Ignition key on, throttle three quarters on, full choke, press primer 3 or 4 times, pull cord. Should cough, maybe start and run rough, then as it's chugging, turn choke to half, then quarter choke, let it warm up slightly, then choke off.
Dec 05, 2009 | Ariens Garden
My Stihl FS-52 ran super. Re=filled the tank and she won't start back up for nothing.Think I over-oiled my mixture so I poured that out and re-mixed but no start.Spark plug keeps flooding over and over.I...
take a pair of needle nose pliers and pull the carb screws out toward you. then start the trimmer and with a small flat head turn them until it runs with no sputter and that one is set and the other one do the same but you need to hold the throttle down and adjust the screw until it sounds and runs good and push them back in when set
Jul 19, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
37 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
