Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
I have Whirlpool ADP 962 dishwasher. The front door is leaking when washer is running. I can feel a rubber seal at the bottom of the door, when I open the door, which seal is wavy and corrugated. How do I replace the seal, and what is replacement part number. Thanks Trevor H
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
q4w5ifgf
Posted on Sep 29, 2010
My neighbor has a whirlpool deut front load set and the washer is leaking front the bottom of the door.
Clean the front of the bellows or rubber also clean the inside part of the door as a single hair can cause any front load to leak. ( breaks the seal) good luck need more help please ask thanks for voting
Mar 15, 2011 | Whirlpool Washing Machines
I don't have a model number right now, but the front door on my Admiral dishwasher is leaking at the bottom. I have changed the gasket inside the door panel at the bottom but it still leaks. This is a...
it may not be the door that is leaking if this is an older admiral or whirlpool dishwasher the lever that holds the soap door closed has a little rubber seal that after time will let water in during the wash cycle it the runs down the inside of the door and out the bottom if you rmove the in side of the door you will probably see the water trail from the wax motor down. this gasket is not expensive or hard to replace.
Mar 08, 2011 | Admiral Dishwashers
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
We have water leaking out of the left side of the dishwasher occasionally. About 1 in 3 loads will leak. Most of the time it is a small leak 1/4 cup or less but once it was a spray out.
One (or possibly both) of your door seals needsreplacing. It's more likely to be the lower door seal as these usually go first. This seal isn't visible like the goalpost seal that runs around the sides and top of the wash compartment. If you open the door, you can feel this rubber seal when you run your fingers along the bottom of the door on the inside. Be careful though, as there is often a build up of dirt down there!
I don't advise buying any parts until you are certain of where the leak is coming from. Identifying the source of the leak (and therefore which seal to replace) is relatively easy but the best way is to run a wash cycle with the front panel of the door removed. It's quite easy to remove, but you might need a T20 T-Star screwdriver to remove it. Sorry, I can't remember exactly what the fixings are on this model.
A simpler - but not always accurate method - is to check by look and feel. If the water seems to be coming from the sides of the door panel at the bottom when you run a wash cycle, it's the "goalpost" seal that needs replacing. These are easy to obtain and replace - they simply push into a slot.
To test the bottom door seal, run any wash cycle and, when it's finished, stand to the side of the washer and open the door. There is a white plastic panel under the door. Have a feel around on top of this. If it's wet you probably need a new lower door seal. These are much harder to replace as it involves removing the door panel and partially releasing the hinges. I don't recommend this as a DIY fix unless you are competent, confident and have good instructions - i.e a service manual!
Whichever seal you need, they cost around $30 / £20 each.
Please rate this solution if you find it helpful. Thanks.
Oct 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My inglis front loader washer is leaking at bottom of the door....inside rubber area near leak feels gummy....any advice??
Scrub the glass on your door and the rubber boot. This works in almost every case. The washer gets a build up of scum on these parts and doesn,t allow a tight seal. In rare instances you have to replace the rubber boot. Good Luck, Appliance Specialists.
Jan 04, 2010 | Whirlpool Inglis IP4400 Washer
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY DISHWAHER WHEN IN CYCLE HAS WATER LEAKING FRON THE FRONT DOOR.
there is some damaga in the rubber sealing please see that and change that front door rubber sealing then you ll find water not leaking after that.........
Sep 11, 2008 | Whirlpool Dishwashers
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
312 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
