Question about Samsung WF337AA Front Load Washer
What is the proper soap detergent needed for front loader samsung washer and dryers?and where to purchase?
  • 3,153 Answers
These types of washing machine require HE (high efficiency) detergent and it is available from most supermarkets, costco, wallmart and many other stores.
Just lokok for "HE" on the front.
Detergent brand names may vary but "HE" remains.
DO NOT use regular detergent as this can and does cause many issues on these washing machines some may even require an engineer to call and fix them.
These are by far one of the best washing machine types saving both energy and time for a much better clean.
Bob
Posted on Sep 13, 2010
  • Samsung Master
  • 17,129 Answers
Use any good detergent the best will be to see with a practical use.
so you can try with detergents that are made for use with front loaders, and decide yourr brand.
Though popular brands like Surf have a lot of choice , there are many to try out with your experience than the advertisements.
Not sure which compartment soap goes in. Samsung front loader J10451W1/XSA
The soap goes in the front left "container". Also, don't forget to use HE liquid detergent. This is a must for front loaders. I hope that this helps.
Jul 15, 2014 | Samsung Washing Machines
Have a 4 day old Samsung Front Loader WF330ANB. It is leaving grey spots on my white towels. I do not use Fabric softener and I do not use the HE detergent over the Max fill line. Both Samsung and...
your using to much soap. use 1 tablespoon of detergent. too much soap will cause spots. depending on which cycle your using . might not be enough water on the rinse cycle. nothing wrong with your washer. i'm a certified samsung tech. hope this helps
Jun 03, 2011 | Samsung WF330ANB Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
The washing detergent doesn't wash out of the clothes it leaves marks on the fabric. what is wrong?
Too many clothes in the load , reduce by 25%
Switch to an old fashioned soap powder that has more agents in it to help it dissolve
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
How much detergent that is not HE can I use?
It is strongly recommended that you DO NOT use regular detergent in an HE washer. The regular detergent is formulated for a wash tub capacity of 35 gallons. A High Efficiency washer, such as yours, only uses 5 to 7 gallons of water per load. You can potentially cause premature failure of the gaskets and seals, as well as drain pump problems by using a higher concentration of detergent. In addition, you may end up with residual soap left retained in your clothing which can cause skin irritation. So...if you do the math, you would have to use about 1/5th the amount of soap you would normally use. However, if this is a new washer, you will void the manufacturers warranty if it discovered that you purposely used improper detergent. There is a disclaimer in the Owner/Operators Manual that should explain this. I hope you find this information helpful.
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Usage of HE detergents
The best he soap I have seen yet is all, he is high effieciency low suds soap. The rule of thumb for liquid he soap is 2 Tbl for every 1 Tbl of softener. Powder can be used but is not good on pumps and build up in tubs. If you have a water softener you can use 25% less soap. Still with powder you need about a 1/4 cup per load to equal a 2 Tbl liquid variety. Suds damage pump impellers, seals and hoses from expansion and that is it on the reason "why to use he".
Sep 04, 2008 | LG WM-2277HW Front Load Washer
LAUNDRY DETERGENT
Greetings MOMMA2,
Typically it is recommended to use only HE (High Efficiency) in your front loading units. The difference between HE soaps and normal detergents is that they are low sudsing soaps. HE Machines need low sudsing detergents and if regular detergent is used, the excess suds could lead to washer problems. Unfortunately just using a smaller amount of regular detergent does not fix the issue. Only the use of HE detergent assures the proper performance of your unit.
Due to this, it is NOT recommended using Dreft in HE machines.
One recommendation out there is to look for 2x Ultra Tide HE Free, which is made without dyes or perfumes.
Thank you,
Dorothy
Go Ahead. Use Us.
May 24, 2008 | LG WM-2277HW Front Load Washer
Type of detergent
You can use either but it must be "HE" or high efficiency soap for front loaders. It will be marked with an HE symbol on the container.
May 13, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Samsung WF337AA Front Load Washer Logo
218 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
