Question about ASUS Socket7 Bios:0202 R:3.10Motherboard (PIP55T2P4)
Invalid mac address - ASUS Socket7 Bios:0202 R:3.10Motherboard (PIP55T2P4)
  • ASUS Master
  • 8,404 Answers
Impossible. MAC addresses are what are burned onto the device. you have recorded them incorrectly or the device is faulty and will not work anyway.
Posted on Sep 13, 2010
I have invalid MAC address in my clx 3175 samsung printer how can i fix it
A media access control address (MAC address) of a device is a unique identifier assigned to a network interface controller (NIC) for communications at the data link layer of a network segment.
You can not just change it.
Check to be sure it is the right address.
Jun 25, 2018 | Samsung Office Equipment & Supplies
Error mac address are invalid in both cmos and flash
does your mac have a battery back up battery like pc's do.
the battery in the mac may not have enough power to keep the cmos information together, replace the battery and you should be okay
Sep 23, 2014 | Asrock Computers & Internet
Mac adress are invalid in both CMOS and Flash
i have your problem.but when i use asrock mac tool it said "Not supported"!.infact it not supported mac address on stick on main board!but my hope was the mac 6 digit that newer tool write.then i change my mac by mac changer from windows and then set that mac to bois and flash by asrock mac tool.every thing get ok:)
Jun 19, 2014 | Asrock Computers & Internet
Blank wan mac address
You can't telnet based on the mac address you would be using the ip address. The mac is burnt into the device and isn't touched by a firmware update. If you did an update and the ip address changed, you can use a port scanner such as nmap to do a ping sweep and find the devices ip address.
Nov 17, 2013 | Computers & Internet
My asrock p4vm890 is has invalid mac address for both cmos and bios
The MAC is the unique identifier for the onboard LAN chip - if it's invalid then the chip has been fried - disable it from the BIOS and install a new PCI LAN card.
Mar 27, 2011 | Asrock P4VM890 Motherboard
"MAC address are invalid in
Find the highest version bios flash file 1.50 and do it from DOS from a Boot Floppy or CD
http://www.asrock.com/mb/download.asp?Model=775VM800&o=BIOS
Feb 05, 2011 | Asrock 775VM800 Motherboard
Router does not accept mac address
in network adapter properties enable dhcp reset router
Apr 07, 2010 | D-Link DIR-615 Wireless Router
Mac address is invalid in both cmos and flash
The MAC address is burned in the Ethernet card chip, you won't see it in the Bios or if you do you can't change it. MAC address changer are tweaks to not being tracked.
The solution to know if the card is blown is to do a complete reinstall of your operating system and if then you can't connect whit it, it is indeed dead. Then Disable it in the Bios and had a PCI one to replace it.
Those kind of problem whit network cards happens a lot when you get a power outage, if you had one in the last couple of days your problem is most likely it.
May 27, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
'mac address are invalid in both cmos and flash'
K, i hv a solution for u, first u need to download afudos utility from http://www.ami.com/support/downloadagreement.cfm?DLFile=support/downloads/amiflash.zip&InpDrvID=90. And then go to DOS mode, n type command like,
D:\...........\afudos /mxxxxxxxxxxxx
There is /m is the command n 12 times x is ur mac ID. N u can find ur MAC on some were on ur MB.
I think this will fix ur problem.
May 16, 2008 | Asrock 775VM800 Motherboard
Computers & Internet Logo
127 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
