Question about Car Audio & Video
Audi A4 (B6) fitted with Symphony II radio and 6 CD changer. Problem: Majority of buttons unresponsive. The tuner works, but radio cannot be changed from current waveband setting, volume cannot be changed. If CD is activated, the limtied radio reception is lost unless CD removed. None of the other buttons other than on/off, band tuning, CD load are working. Fuse has been removed and replaced. no change. Many thanks
  • 13433 Answers
SOURCE: My 2004 Honda Accord EX
if the repair guys didn't finish the job and fix the radio if that was the point of the repair then I recommend you contact them again or why is the radio missing or not fixed yet?
Posted on Jul 13, 2008
  • 2427 Answers
SOURCE: I have a Ford AU
more than likely something got stuck or broken ..
You will need to open it up and see if there is anything you can notice that may be causing the problem. more than likely the loder. if you think you can move it back into place or frmove the jammed components then by all means do. if not take it to an electronic technician.
Posted on Jul 20, 2008
SOURCE: 2000 Audi A6 Quattro Concert Radio
what do push on the radio to get the code to come up so i can enter my code in
Posted on Mar 15, 2009
  • 59 Answers
SOURCE: 6-Disc CD Changer is not working
Unfortunately most times with these 6-disc systems once it quits working it is usually time for a new unit. The manufacturers all reccomend reprogramming the radio, but this rarely does anything other than waste your time and money. Go for the new radio.
SOURCE: I have a 6 cd
i have a 2002 mustang and my radio did the same thing. when i went to load or eject it would say cd error or no cd. then when i would select load cd, it would say slots full. i had someone unplug the positive cable on my battery and let it sit for a few hours to reset. then when it was hoooked back up and i started my car, the cd player started working again.
Posted on Mar 30, 2009
What are the steps to enter radio code for Audi A2 2008 Model?
I'm not sure which model you have but these are the instructions for Symphony 1.
I'm not sure if this also applies to Symphony 2 (which has a built in single slot 6 CD changer)
Switch on - display shows SAFE as you indicate
Press and hold TP and RDS buttons at same time until 1000 appears
Release buttons (dont touch again or 1000 will be entered as the code)
Using station select buttons 1 to 4 enter code. Use button 1 to select first digit of security code, button 2 for second digit etc (buttons 5 and 6 cannot be used)
Once code is entered press TP and RDS buttons together and hold until SAFE appears
Release buttons and a radio frequency will appear in the display
Job done
If you accidently enter the wrong code the word SAFE will start flashing. You get ONE more chance to go through this procedure and enter the correct code.
There is a more complicated procedure to go through after this with one hour time delays between attempts
Let me know how you get on!
Jan 10, 2015 | Audi Cars & Trucks
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
Jul 04, 2010 | 2007 Audi TT
My audi a6 radio has a SAFE message in the screen what it does mean?
Did you disconnect the battery or run it down? This message means you must enter the correct code. If you do not have the code contact your Audi dealer. I'm not sure which model you have but these are the instructions for Symphony 1.
Switch on - display shows SAFE as you indicate.
Press and hold TP and RDS buttons at same time until 1000 appears.
Release buttons (dont touch again or 1000 will be entered as the code).
Using station select buttons 1 to 4 enter code. Use button 1 to select first digit of security code, button 2 for second digit etc (buttons 5 and 6 cannot be used). So, say the code is 5238, you'd press '1' five times, '2' twice, '3' three times and button '4' eight times.
Once code is entered press TP and RDS buttons together and holde until SAFE appears
Release buttons and a radio frequency will appear in the display.
There is a more complicated procedure to go through after this with one hour time delays between attempts.
Curtorsey Audi Owner's Club:
Dec 10, 2009 | 2006 Audi S4
No sound from 2004 Audi A4 factory stereo
You just go to the link I attached I'm sure you will get the solution of your problem
2004 Audi A4 Workshop Repair Service Manual PDF Download
Sep 06, 2017 | 2004 Audi A4
Symphony radio goes soft and looses bass at high volume
all that is, is the speapers cant handle the sound
Jul 08, 2009 | 2004 Audi A4
I get a ERROR 1 code on my audi Bose symphony radio. The CD player will not work. The tech bulletin dated 9/16/04 has a notice that says clean the disk. If that doesn't work, it says replace the radio! Is...
i had same problem with 01 a4 bought from arnold clark .kicked up a fuss and they got it repaired for me, this was nearly 2yrs ago and it's been perfect since so i would say all you need is good audio engineer. by the way audi also told me the radio needed replaced
Mar 18, 2009 | 2001 Audi A4
Any other fuses for radio?
There should be a fuse on the stereo itself, to remove it you will need the special radio pins to remove
Feb 23, 2009 | 1998 Audi A4
2000 Audi A4 stereo system
Yes. I know of two units out there: Denison's IceLink, and the Phatnoise box (or Phatbox, as some call it). I believe both install the same way. You figure out where you want the iPod connector (say, glovebox). Pull the stereo out of the dash, disconnect the CD changer (you'll lose the changer function with these but who cares?), and plug the adapter cable into the changer's port. It'll allow the iPod to play through the factory stereo, and will allow you to control the iPod with the buttons on the factory stereo.
Oct 20, 2008 | 2000 Audi A4
How to connect a Blitzsafe AUDI/M-Link1 V.1B - iPod interface
I have the same problem. Did you get anyone to help you? I have the same car. A4 1.8T 2005 with the Symphony factory radio.
Jul 08, 2008 | 2006 Audi A4
Car Audio & Video Logo
326 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
