Question about LG Televison & Video
T.V. Engineer working on a LG 3000 model: When you switch the set to standby, the red led blinks and the set will come back on again!! it will not stay in standby, I have changed the main board (new ) three times, and also the remote receiver module it still will not stay in standby!! Anybody any ideas please your help would be very appreciated.
  • johnclaytonv Sep 15, 2010
    Hello Ginko, Working on this 42"LG 3000, I have checked all supplies from the Power supply which are correct, including scoping for any ripple,I also notice that if you remove aerial signal, this set will stay in standby mode, if any signal is present it will not stay in standby,(pulses comes back on again) yet i have changed the AV board as expained, I cannot seem to find a tech line for LG do you know of one?
    obviously i have tried factory re-set etc, to no avail,customer uses this set in a bedroom and needs to be able to switch to standby,and it stay there.
  • LG Master
  • 19,396 Answers
Before replacing the main board, the PSU should have been tested. This TVs PSU provides power on different voltages, and each voltage is controlled through a low DC control line from main board. A defective PSU may turn off and restart by itself.
In real word I repair many LCD TVs. I do not get tired of repeating that LCD TVs are very different from home computers. Repairing by simply board swapping does not work. Although this units have few parts, the working process of the TV does not allow identifying reasons of faults from symptoms (with a PC you can often tell), parts are expensive, and testing is always necessary.
In your case for example the problem is likely a faulty PSU, but a bad grounding caused by missing screw may also cause the problem. The PSU, which is likely culprit, must be tested by jumping the control lines and reading volts to main board. This is made more difficult by the fact that the TV is forcing shut down, and turning volts off continuously.
Posted on Sep 13, 2010
  • Ginko
    Ginko Sep 15, 2010
    Hi.
    Problem eviidently was not the AV board. I think there is a grounding problem. The antenna is grounded, TV finds its ground through antenna coax cable. Ensure that all internal screws holding boards are mounted properly, they warranty grounding to boards. Check earth on wall socket.
My Sony KDS-60A3000 randomly turns off, then the red "Power LED" blinks three times repeatedly (not "Lamp LED"). We turn it back on, the process repeats again between 20-60 minutes.
3 blinks of Standby/power LED of Sony sets denotes a SMPS board [G-board] failure. . Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 16, 2016 | Sony KDS-60A3000 60" HDTV
Sony LCD TV Red LED light constantly blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 06, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
My LG T.V., model number 55LM7600UA receives power has no picture or audio. The red led light in the corner just flashes. What board would I need to replace? I think it has been affected by lightning
Nov 11, 2015 | LG Televison & Video
Lg LCD TV power up issue
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Normally continious flashes of standby LED indicates a main board failure. Anyway, count the number of blinks as stated above, and make sure about the fault. Contact any service technician.
Sep 16, 2014 | Televison & Video
I have Sony Bravia 46in model kdl-46w4150 it was working fine then just shut off and red standby light blinking 14 times. I've unplugged and tried to turn back on but still just goes to red standby light...
14 times blinks is a rare case to Sony Bravia sets. Just count it one more time.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Aug 06, 2014 | Televison & Video
I have a "LG 42PC5DC - UL" that blinks 3 times "green" then back to "red standby"
Jul 31, 2014 | LG 42PC5DC 42 in. Plasma HDTV
My lg tv has power and blue light comes when powered up the goes to red blinking light never a picture or audio
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Apr 28, 2014 | LG 32LK330 TV
I have LG 32LC46-ZC TV. It suddenly stopped working, no picture, no sound. The LED blinks 5 times after turning on, but nothing else. Any suggestions?
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | LG Televison & Video
32 inch, hannspree tv.1080P I need code to get my sky remote to work.
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV (try 0206)
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Mar 15, 2011 | Hannspree XV32 32 in. LCD Television
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
Feb 18, 2008 | Televison & Video
Televison & Video Logo
161 people viewed this question
Computer Repairing
Computer Repairing
