Question about Dryers
Heating coil fine------how do I get at thermostat and other part
  • jeffhonzik Sep 13, 2010
    It is a Kenmore, model number 11062812101
    heating coil will not heat, think it is the thermostat and/or TCO(?)
    how do I get at???
    Thanks
    Kenmore dryer, model number 11062812101
    Need to learn how to get at themostat and/or TCO(?)
    thanks
  • Dryers Master
  • 3,361 Answers
We must have a model number to help you.
Posted on Sep 13, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post back with the manufacturers name and model no#, also please elaborate on your question so that I can assist you.
Thanks
Rylee
The dryer will not heat up every thing else seems to run fine
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 14, 2010 | Dryers
The dryer is running fine but is not heating at all. does the heating element need replacing
Please rate me
Sep 10, 2010 | Frigidaire FER641FS Electric Dryer
It runs fine, but no heat
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor.
Please rate me
Aug 16, 2010 | Dryers
Dryer starts up just fine but will not heat up to dry clothes.
Good Luck, Hope this helps
Please rate me,
Thank you
Aug 15, 2010 | Whirlpool Dryers
Runs fine--just no heat.
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me,
Thank you
Aug 12, 2010 | Roper Dryers
My Kenmore dryer runs fine, but will not heat and the heating coil seems to be fine. What else could be the problem
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Please do not forget to rate me, Thank you
Jun 02, 2010 | Dryers
Dryer will not heat,all else seems to work fine. I have 220 volts out of outlet. Thanks Robert
May 25, 2010 | Dryers
Dryer not heating up but is otherwise running fine.
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil. You should read continuity across the terminals, if not you will need to replace the coil as it is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape. If the coil heats up then replace the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, Hope this helps Please rate me, Thank you
Jan 03, 2010 | Whirlpool LER4634J Electric Dryer
Dryer stopped heating
Good Luck,
Hope this helps
Nov 03, 2009 | GE DSXH43EF Electric Dryer
No heat
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 19, 2009 | Bosch Nexxt 500 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
