How to Open the door of Asea Cylinda 12000 Washing Machine. We just move in a house, and there is Cylinda 12000 Washing Machine, we have try to open the door, but could not make it.
3 Suggested Answers
SOURCE: need a manual for a
Dear sooty388,
Have you found a manual for you Asea?
I need one too.
If you would, please reply at this email address.
Kind Regards,
Dhugal Bissett.
Melbourne.
Posted on Nov 28, 2008
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
Asea Cylinda 1400 dishwasher not filling. Keeps waiting for water to fill. Continues normally if manually add water. Tap is on and water available.
The incoming water valve is faulty. Look at the back of the machine where the hose connection runs into the machine, there should be a solenoid operated water valve there. Check that out or replace it.
Dec 05, 2014 | Dishwashers
Asea cylinda
go by manual so you dont mess up
Aug 08, 2013 | Dishwashers
Hi - I have the Askko asea 12002 and the machine won't empty water and therefore door won't open. How do I get around this. I need to get the clothes out ASAP.
Remove outlet hose at back of machine and drain into a bowel or bucket the door will then open. Check your filter is not blocked and also the pump
Jul 29, 2010 | Asko Washing Machines
Manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Apr 24, 2010 | Dishwashers
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
I push the start button on my Asea Cylinda 1500 dishwasher and nothing happens. Could it be the solonoid?? If so where would I find it so I can replace it?
Had the same problem. After years of opening and closing there is a risk for one or two cabels to be cut inside the door. Easy to fix.
Apr 13, 2009 | Dishwashers
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
Need a manual for a asea cylinda 12000 washing machine can you help please
Dear sooty388,
I need one too.
Kind Regards,
Dhugal Bissett.
Melbourne.
Apr 14, 2008 | Zanussi FJS1225W Front Load Washer
Apr 02, 2008 | Asko Washing Machines
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
