Question about Pit SSR 110CC Pro Beginner Bike
I have a ssr 110 pitbike. I just bought a inner flywheel stator kit and I am attempting to wire it. Instructions not so easy as it states one thing, then pictures another. I have a kill switch with green and white/black wires, magneto with black wire and pickup with white wire. Coil has yellow/black with green wire, green from kill switch wired into coil green, and a CDI box with yellow, red/white, white and two green wires. Any assistance would be outstanding, thanks
  • jkonecny Sep 14, 2010
    hi, thanks for your response. The ignition part is a performance inner rotor kit. It looks generic. It has a plate with a coil magneto on one side, a pickup on the other, a cdi box, and the magnet that goes on the crankshaft. Wires as described before, thanks
  • Anonymous Mar 11, 2014
    what size are the stock bearings,
    President:
  • 2,777 Answers
This is very difficult to help with, without being there in person. What is the Make / Model of the flywheel kit you purchased?
Thanks, let me know and I can help
Tim
Posted on Sep 13, 2010
  • Tim Grayson
    Tim Grayson Sep 14, 2010
    Hmmm, I am unfamiliar with that brand, is that in fact the brand / manufacturer of the part, "performance"? There should be a manufacturer listed, that just sounds like the generic part name to me... Let me know, but chances are you may need to give the manufacturer a call for clarification, but once I know who makes it I can check what I can find for you.
    Thanks
    Tim
There are two yellow wires and 1 red wire on a voltage regulator on a Briggs and Stratton 22hp. The the mower flooded recently.
the two yellows go under the flywheel to the stator , they are a/c current that is converted to 13.8 volts D/C in the voltage regulator .I would not think it being under water would hurt the stator or regulator . Maybe the mud under the flywheel might grind things.
Aug 27, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
My pitbike 110 cable come lose out off cdi so bought new wiring kits but cant get it to spark need help were the wires go
this is cdi wiring plan. notice wires to coil, kill switch, 2 to magneto and earth the diagram link shows what the wires are. physically look to see which wire on bike goes to ht coil, the kill switch, 2 from magneto and earth or to from earth. hope it helps http://tboltusa.com/store/images/5_wire_Lifan_Wiring_041605_HI.jpg
Feb 15, 2013 | Motorcycles
SSR 110 bike wont start
ok so if its BRAND NEW take it back to the place you bought it mate its engine is dead there is no compression either that or your sparkplug is not in tight or at all (lol)
Dec 08, 2012 | Pit SSR 110CC Pro Beginner Bike
No compression in 110 pitbike
your piston or your piston rings are gone. take off head if you r confident enough it is only 4 head screws. just don't try to rip it off. gently ease it off and i am 100% sure its your piston or your rings mate:)
Jul 14, 2012 | Pit SSR 110CC Pro Beginner Bike
How do i remove the ststor from my ktm mxc 300
Disconect the stator wiring coming from the engine cover, drain oild if its a wet coil, remove engine cover, remove fly wheel (will need a puller or flywheel removal tool witch threads into the fly wheel inner thread and pops it off when you screw the bolt down the inner thread of the puller) remove the stator bolts and thats you.
Jan 26, 2012 | KTM Motorcycles
I have a Roketa MC-07-50t that won't start. The Spark plug is not getting a spark. We have replaced the C.D.I. Still no spark. Help.
4bbd330.jpegthis is a asic wiring diagrame for a pitbike and if you carefully follow this with yor new cdi mabey coil and spark plug you should deffo get a good spark and if that fails then you need a new stator plate or inner roator kit off ebay    ... hope this helps    email josh_radford2k10@hotmail.co.uk
Oct 06, 2010 | Cycling
My 110 bike is slower than others i no on
adding a performance exhaust system to most motorcycles will boost horsepower 3 to 7%. If the motorcycle is carburated, a larger jet and a high flow breather (filter) will help to gain the maximum.
Sep 21, 2009 | Pit SSR 110CC Pro Beginner Bike
I just got a 110 ssr pit bike. is the back brake
It should be below. Not to sound rude, but I think you could have figured this one out yourself. You sound like a smart guy.
Thanks for using FixYa.
Aug 12, 2009 | Pit SSR 110CC Pro Beginner Bike
Radiator fans dont run????
I believe that the problem you are encoutering is a bad SSR (solid state relay). This device is wired in series with the fans and causes them to run at various speeds depending on engine needs. It is quite common that these devices fail. I would look at trying to get a new one...not sure of the cost but very easy to replace yourself.
Aug 14, 2008 | 1997 Plymouth Voyager
Pit SSR 110CC Pro Beginner  Bike Logo
210 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
