Question about True GDM-7 Beverage Cooler
Setting are set on 9 and my drinks are still exploding.
  • True Master
  • 17,130 Answers
Possible that the thermostat control is not reacting to the setting.
so you must check if there is any break or replace the unit.
Posted on Sep 13, 2010
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Setting constitancy of product
I think your Bunn machine is producing the 'ice frozen drinks" it was designed for.
May 18, 2016 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
Not keeping ice cream cold enough in freezer & milk and drinks in refrigerator are not cold enough
You need to change the settings on the thermostat. Its a dial setting inside or digital setting on the door. Lower the temperature until you are satisfied.
Feb 29, 2016 | Refrigerators
When I am taking photos, it will flash about 3 photos and then takes 6-9 seconds before it recharges and will take again. I miss many good shots while waiting on the flash to operate. I have a fully...
Lower the fflash power setting if posible,\. Then you will have to open the aperture more or use a slower shutter speed. This is true wether using the camera built in flash or an external flash. Even with freshly charged batteries, the capacitor that releases the charge to the flash tube will lose all charge and have to be recharged. Lowering the output releases mless charge from that capacitor. Like drinking from a glass, smaller gulps=more drinking time.
Dec 19, 2010 | Nikon D90 Digital Camera with 18-105mm...
My drinks keep exploding
You need to turn the thermostat up ....the drinks are frezzing and that explodes them...
heatman101
Sep 13, 2010 | True GDM-7 Beverage Cooler
Drinks in fridge keep exploding
are you sure that they are not filled with dry ice?
Oct 21, 2009 | Haier Refrigerators
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
Dec 13, 2007 | Electrolux 23 in. ESI6104 Built-in...
True GDM-7 Beverage Cooler Logo
109 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
