Question about Exercise & Fitness
THE TENSION CONTROL DOES NOT CHANGE THE PEDDLE SPEED
  • pat_redmond Sep 14, 2010
    The only numbers I can find are:cat no.KP176 en957-12005 :en957-5
    SOHS L 701 AB,4308
    President:
  • 2,777 Answers
I need some more information on your problem here, what make and model system are we looking at? In the past did the tension control work just fine? It sounds like it is a recumbent bicycle, but I am not sure. Please let me know the make and model and we will get it fixed.
Thanks
Tim
Posted on Sep 13, 2010
  • Tim Grayson
    Tim Grayson Sep 14, 2010
    Hmm it looks like that is a Dynamix KP176 bike, is that correct? Has it ever worked properly? Did you just go to use it one day and it would no longer adjust the speed?
    Thanks
    Tim
When pressing on the accelerator my safari bogs down and starts to lose power.
Sounds like the accelerator linkage or kick down band of the transmission need adjustment.
Mar 23, 2015 | 1998 GMC Safari
How to fix mercedes 1998 ML320 ets light
Hey,ETS stands for Electronic Control System, a diagnostic check is needed to verify which sensor, wiring or module is fault. The ETS is part of your ABS system, they share speed sensors etc. The ETS light will come on when its activated (car slipping while foot on the gas peddle) and the ABS light will turn on when its activated (car slipping while foot on the brake peddle).
hope this helps
May 08, 2014 | Vehicle Parts & Accessories
Briggs and stratton 3.75 sprint engine handle throttle doesn't change speed
there is a long spring that goes from the level the cable connects to to the governor rod does that have any tension on it?
Apr 26, 2012 | Garden
2000 silverado 4.3 5 speed truck bucks at part throddle while driving.push down on the gas peddle and it gos away let up to just cruse and it surges and bucks again. replaced plugs,wires,cap,rotor.no...
sounds like it is in the throttle sensor or idle control valve causing problem not responding fast enough to take over also try the fuel filter could be clogged.
Aug 30, 2009 | 2000 Chevrolet Silverado 1500
The thread keeps jamming under the fabric and making a large knot. the needle seems to get bent quite frequently and the foot drop peddle is broken - do you know how to fix any of these?
It is either incorrectly threaded and/or the top tension is too loose. Rethread carefully and start with the tension dial on no 4. Make sure thread is between the tension discs.Re the foot I assume you mean the foot which you can change for buttonholes etc. These are generally fairly interchangeable and any sewing machine supplier should have them.Im assuming you do not mean the foot pedal which you operate the speed of the machine with.
Jun 07, 2009 | Euro-Pro Shark 80 - 7133
2007 Dodge Ram 2500 - Brake peddle wobbling
only comes as a whole pedal assembly. not to hard to change out though just takes a little while if its your first one
May 21, 2009 | 2004 Dodge Ram 2500
Cruise control NOT WORKING
Check your rear brake peddle and see if the sensor for the cruise control is out of adjustment. I had the ame problem on my 1990 GL1500.
Apr 28, 2009 | 1990 Honda GL 1500 SE Gold Wing
Brake lights
under the brake peddle is a switch. Lift the brake peddle upwards and you will see that the brake light goes out [requires two people; one to hold the peddle up, other to view the brake lights]. Restrengthen the spring tension on the brake peddle.
Should the lights remain ON after you lift the brake peddle up, unplug one of the wires to the brake peddle switch. At this point, the brake lights should be off. This basically will determine whether your switch is shorted or is just a peddle pressing down on the switch due to a bad spring.
Oct 15, 2008 | 1991 Honda Accord
Exercise & Fitness Logo
87 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
