Question about Smeg 18 in. DWI410 Built-in Dishwasher
My smeg dishwasher stopped working think anti floading was tripped
Smeg dwf 409 ss free standing slimline
it just stopped suddenly, with water left inside the machine, think it is showing error code 1.
we managed to drain it by pressing each cyle button which pumped a little water each time.
i think the anti floading system was tripped because the drain the dishwasher emptys into needed clearing, which has now been done, but cant get the dishwasher to work now! how do a reset it and cancle the anti fload trip?
  • chrismargot Jun 07, 2008
    My dishwasher just stopped suddenly, with water left inside the machine, the error code that started flashing showing was error code 1.
SOURCE: Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Posted on Aug 21, 2008
SOURCE: anti flooding system
yes I will for $14.99 !
Posted on Aug 28, 2008
  • 93 Answers
SOURCE: Spray arms don't spin on Smeg DWF 410 ss
Remove he wash arms and visually check for obstructions in the holes where water sprays out if any number of these are blocked it will happer the turning of the arms
Posted on Jan 21, 2009
SOURCE: smeg dishwasher dwf 44 ss 1
http://www.smegtech.com/site/smeg/pdf_libretti/19590066100-GB.pdf
Posted on Feb 15, 2009
  • 3741 Answers
SOURCE: E9 error on a smeg dwf 66 dishwasher. Can't find
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=45951 click the link directly also click this link directly to get the exact picture http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=102 --------------- also try this open the door, switch it off, switch it on and immediately press the program button 4 times within 3 seconds. (Don't wait for any lights when you switch it on, just quickly press the button 4 times).
The two end lights should light up. Press the program button and one of the lights should go off.
Switch it off for about 20 seconds, switch it on, switch it off for about 20 seconds, switch it on and it should be reset.
If resetting doesn't cure it, check that the base isn't flooded and the anti flood device activated.
If you're getting any other error code don't do the reset, just post the lights that are flashing, 1 being left and 5 being right.
------------- Check for water in the base of the machine, not the tub.
Drain the water from the base, if there is any, and the machine will reset itself.
If there's no water follow the reset procedure as previously described.
You must get the two end lights lit first before you can carry out the rest of the reset procedure.
If you can't get the two end lights lit then it's possibly a faulty pcb.
----------- if by chance its faulty pcb then Faulty PCB.ne pcb costs £120 + VAT + call out charge so not worth doing
Posted on Aug 30, 2009
Smeg dwf 409 ss went bang
is the power light on the board or a separate indicator?
were did the current go when the capacitor in the filter blew? probably into the board......
Oct 16, 2013 | Smeg Dishwashers
Detergent dispenser on SMEG DWF 44SS1 doesn't open during cycle - any ideas?
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Oct 18, 2009 | Smeg 24 in. DWI612 Built-in Dishwasher
My smeg dwf 64 sse blew the main fuse yesterday. The machine was up to its rise stage on program 8 then the breaker went. Every time I switch the main back on it blew. I have managed to stop it...
Your element was initially short circuit, which caused circuit breaker trip. It is now open circuit and timer will not advance because water has not reched required temperature, recommend thermostat replacement also.
May 18, 2009 | Dishwashers
Jan 21, 2009 | Smeg 18 in. DWF410SS Slim-Line...
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Hotpiont fdw65 dishwasher fault lights
On the base of the dishwasher you have a anti fload switch, this has probably got stuck on or has been jammed when replacing the base of the dishwaser, I would take a look at this first.
Oct 21, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Open Questions:
See all Smeg 18 in. DWI410 Built-in Dishwasher Questions
Smeg 18 in. DWI410 Built-in Dishwasher Logo
387 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
