I got my comp a whille back now it just wont start it gets to the chec screen and at the end of it it says )cmos checsum is bad) and then the fan stops and powers the hole system off after what do i do to fix that
  • 97 Answers
Reset your BIOS setting
Posted on Sep 13, 2010
I can hear the fan running but wont turn on
Cmos ng, motherboard ng, bad peripheral, bad memory, power supply?
Start checking.
Jan 08, 2016 | Dell Dimension C521 PC Desktop
Msi h55-p31 randomly starts cycling and then wont come on
3 things you need to do. if it comes up with video i have a very simple solution. no video you may have issues. what i have had happen in the past is if this happens it means that the cpu fan is not secured onto the board all the way. you need to reinstall the fan untill it is all the way on and it has not wiggle room at all. if thats not the issue and you think you are sure of it. when it starts go into the bios and cmos and look for where it shows the temp of the cpu. if it shows it is heating up fast that means that it is not on properly enough yet. and if that doesnt work then you need to make sure your version of windows is not faulty because if you get a blue screen really quickly it means you need to reinstall windows. all of that fails and there is no video. *********** board or power supply are most likely fried and you can take all the ram. the processor and any peripherals you have off and bring it to your comp scrap area and get rid of it.
Sep 20, 2012 | MSI MSM LGA1156Intel H55uATX 6x...
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
Peugeot 406 hdi turns over but wont start, no lights or gauges work on dash except oil light, climate, multi function screen, stereo, heated seats wont work, everthing else does, lights, windows, electric...
chec the fuse box for bad then do an inspection of the wires for any corrosion/cuts--may hav a module thats bad or computer problem-get a tech that can do a mobile scan
Dec 31, 2009 | 2006 Peugeot 405
Signs of a bad compressor or condenser
plug this unit into a receptacle with a lamp also in the recept. unit will try to start the lamp will dim for a couple seconds and go back bright unit wont start maybe fan but no comp. sit and watch a few minutes later lamp will go dim again then back to bright, this is a classic low tech way of confirming the comp is trying but not working possible bad run capacitor, much cheaper than new unit
Aug 11, 2009 | Fedders A7DH65B2A Dehumidifier
Comp stuck on vaio screen
It might be a motor going bad, as in a HDD or fan. Try to pinpoint where the noise originates. Is it coming from the speakers or somewhere else?
Dec 28, 2008 | Sony VAIO Digital Studio PCV-RX560 PC...
When i turn my comp. on it will go to promp me to choose star in safemode,safemode w/promp,last config,...when i pick anyone.it starts to load then takes me right back to that promp.i can't start up my...
Hi tracy_laster,
Whats happening is when the the computer boots, first stage goes thru CMOS, second stage loads drivers and starts to look for the operating system. And if it does not find the operating system, then it re-cycles.
Here are some possibilities:
1) Go into your BIOS and set CMOS setting to default. Save settings and reboot. See if this makes a difference. If not, move on to next step.
2) Memory Module - If you have more than one memory module, take one out and reboot the pc., Do this one by one until you discover the culprit. If there is no bad memory module, then move on the the next step.
3) Make sure the cable ribbon or harness is properly inserted on both ends of the cable (one end to the hard drive and one end to the mother board). If you dont find any problem, then next step is important.
4) At this point, your hard drive may be going bad or gone bad. You can try to reformat and install everthing back. But if you dont have the installation or recovery cd then you will need furhter help with data recovery.
Hope these steps help and good luck.
Jul 25, 2008 | E-Machines Computers & Internet
Cmos error
change ur cmos battery n reset ur cmos settings in cmos setup.click f10 to apply settings n restart ur machine.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Jul 01, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
