Question about Garmin n?vi 265WT Car GPS Receiver
Garmin 265WT, connected to 12v car supply, keeps going into mass storage mode then crashing in the middle of giving directions.
  • 1,514 Answers
This happens a lot with the 2xx series nuvis. Generally the cause is that the mini USB plug on the power cord when it appears to be fully in is not. This is due to wear on the mini USB socket. Push the plug in further and it should solve the problem
Posted on Sep 13, 2010
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 40 goes into usb mass storage mode when pluged to charge
I updated my Nuvi 40 with the latest software and it will not reboot into GPS mode with the usb cable connected. It used to work. I have figured out how to get it to charge with a standard USB cable:
1) Power it on.2) Press the battery icon for 8 seconds - it will enter TEST mode.3) Plug in your USB cable from the PC to the Nuvi - the screen will change to say charging.4) Press the power button 3 times rapidly - it will say Charging across the screen and it will go dim and then dark.5) To wake it up and use GPS mode while charging simply press the power button 3 times rapidly, again.
Works Great!
Nov 15, 2011 | GPS
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
My garmin nuvi 200w keeps going into mass storage mode when plugged in to charge.as soon as it is plugged in to charge the screen appears that shows the garmin plugged in the computer. and the map...
1) Disconnecting the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi should now reboot, but remain in GPS mode!
Aug 06, 2011 | Garmin nuvi 200W GPS
Whenever I turn on my Nuvi 200 it shows the mass storage mode icon and will not display maps. How do I get rid of this problem?
With a Nuvi, If a Garmin or Garmin compatible power cord is not used, GPS will stay on the USB Mass Storage mode and will not go to Map Screen even though connector fits fine. In this case GPS can slowly charge. So, you need to find/obtain a power supply that works right.
Mar 22, 2011 | Garmin nuvi® 200 Car GPS Receiver
Garmin nuvi 265wt shows mass storage mode on screen when i plug into in-car charger so can't use it?
Sometimes this is caused by the mini USB plug not being pushed fully into the back of the satnav. It feels like it is but due to wear on the socket it's not. Push it in further and it may solve the problem.
Dec 05, 2010 | GPS
I just bought a Garmin 265WT. I ran the registration program, but the computer does not recognize the Nuvi. I've checked My Computer and it does not show a new drive ( the Nuvi should like like a drive...
Try these steps:-
  • Unplug the USB cable from the computer.
  • Turn the unit off and then back on again.
  • Plug the USB cable into your computer.
  • The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Also, in some cases the operating system does not support the device. Try upgrading it to the next higher level. In most of the cases windows Xp service pack 2 does not recognise this Garmin device. Try upgrading it to service pack 3.
If you are still experiencing the problem then you will need to contact Garmin for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 12, 2010 | Garmin nuvi 260W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
My Garmin 265wt will not turn on for navigation when connected to a computer anymore. It displays the computer connection but I cannot get to the navigation while charging like I had before. Any help how...
I asked Garmin how to display maps when connecting a 265WT to a PC with a USB cable. Based on the following reply I received from Garmin the answer is you can't. Have you ever updated your software in your Garmin 265WT. Perhaps you were able to display a map with the USB cable connected with an earlier version of the software. Whereas the latest version of the software will not let you display a map with a USB cable connected.
"Thank you for contacting Garmin International.
I will be happy to help you with this. Unfortunately when your unit is
connected to a computer you will not be able to use the device. The unit
is designed to go into mass storage mode when connected to a computer."
Sep 20, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin n?vi 265WT Car GPS Receiver Logo
411 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
