Question about Ovens
I have sanyo microwave oven purchased in 1996 in dubai was fully functional untill few weeks back it has not been serviced for long time ,i am looking for advice on service or replacement
  • Ovens Master
  • 3,740 Answers
Usually when a microwave quits either the Power Diode or High Voltage Capacitor has failed. When they fail they usually also cause the internal 15 Amp fuse to fail. The back comes off by removing the 4 screws (2 on each side) and 6 screws in the back. (UNPLUGGED!) The you slide the cabinet cover back about 1/2 inch.. lift the rear of the cover 30 deg and remove the cover by pulling to the rear of the unit.
Once inside take a bladed screwdriver and short across the capacitor at least 3 times just in case it was not the failure. If you don't do this and the Cap is good it can really ruin your day! Then isolate the Cap by removing the set of terminal connections that include the power diode connection. Use an analog meter on R x 10K and probe the cap terminals. You should see resistance then watch the resistance increase to infinity. Reverse the leads and watch for the same indication....resistance then increase to infinity. It should do this each time you reverse the leads. To check the diode you read both ways with the meter leads across the diode. One way will read ZERO ohms and the other way should read close to infinity. (You have to reverse the leads.) Like I said usually the Cap or the diode fails. Make sure you check the fuse for continuity also. Most of the time they fail when one of the 2 components above fail. DO NOT replace the fuse until you replace the failed part. Otherwise the fuse will fail again.
The fuse is located in the fuse block at the end of the power cord.
When your reinstall the cover make sure you ensure the front side locking tabs near the bottom front are engaged with the front of the internal chassis.
If you need product specific parts replacement information we will need your exact model number. I will tell you that if you find the problem via the steps above you can walk into any LOCAL Appliance Parts source store and they will have the part you need in stock.
Thanks for choosing FixYa.
Kelly
Posted on Sep 13, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    This KitchenAid combination wall oven and microwave unit was purchased in 2002. Except for having to replace a fuse in 2004, it worked fine until the microwave started acting up recently. In September...
    Good Question. I work on all brands of appliances, and I swear by KitchenAid-Whirlpool appliances. That being said, I do not recommend oven-microwave combinations, because the ovens will last 30 to 40 years, but the microwaves start having major repairs from 6-10 years on. I would bite the bullet and put in a separate Panasonic microwave (with an inverter) and a seperate KitchenAid Oven. You also need to install a 2000 Joule or higher surge protector, for your microwave oven. Panasonic microwave ovens are better than the KitcheAid ovens at this time.
    I would suspect that the touch panel-control board failure may have been caused by the repairman, just because the timing is a little too close to the mag repair. No way to tell you for sure, and I myself have had control board failures the same day that we changed a light bulb, so anything is possible. Usually a factory defect is going to show up before 8 years. In the last 4 years in the greater Seattle area, 70 - 80% of our business is from power surges hitting the electonics in the different appliances, so this could also have been what has caused your repairs. On a 240 volt Oven, the only way to protect it from power surges is to have a whole-house surge protector installed on your house electrical panel. You still need to have individual surge protectors, above 2000 joules, for your appliances that are 120 volts. Good Luck, Appliance Specialists
    Dec 09, 2010 | KitchenAid Architect® KEMS378S Electric...
    I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
    Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
    Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
    New oven won't work and can't set time, display keeps blinking
    Hey--  You've spent a bunch of time on this already, so let's figure it out. The first step is to check power connections. L1, L2 , Neutral for proper location and tight connections. Should have 120v and 220v checked at bus block. If these check out, then this new unit should be under warranty and qualify for service. Not unheard of bad board or loose wire on a new unit. Let a tech sort it out on site. Let me know if this info helps- have more if needed-  Thanks-  Ed
    Mar 15, 2010 | Whirlpool Ovens
    Bosch oven won't pre-heat/heat with door closed
    Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
    May 24, 2008 | Bosch HBN 430560B / 430520B Single Oven
    New oven won't work
    cobrapilot sorry to be the bearer of bad news. Some where in the oven the contacts going to the oven probe are closing. This could be wiring going to the probe missing insulation and hitting the sheet metal, or the probe socket itself closed. I usually see this after the unit is in use, not right after install. Have you tried to cook a roast or such in the probe mode to see if it will work? For the oven may work just fine then. You are correct about your last line, until service resolves this issue, you have just an expensive microwave. Also as a side note, be sure an be there when the tech showes up. They may just try to say we need a part and not actually attempt to fix your unit. I am not sure what area you are in, however try Olson Appliance Service, He has a website, he is authorized Kitchen Aide service and maybe he can help.
    Feb 03, 2008 | KitchenAid Architect Series KEMC308KSS...
    Microwave will turn on but not heat
    Test the high voltage capacitor, the rectifier diode.or the magnetron.
    If it additionally does not spin and no light, then check also the door switch.
    The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
    Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
    All locations, and description of this parts can be located using the diagram here: Counter top.
    Parts must be tested to find out what is wrong.
    Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
    A microwave energy leakage test must always be performed when the oven is serviced for any reason.
    Regarding parts, contact the seller here to purchase parts. (here in UK).
    Nov 26, 2007 | GE JTP85 Electric Double Oven
    Function button keeps failing
    only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
    Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
    Dacor ECS230 Wall Oven Control Panel Time functions not working
    Try turning the power off at the breaker for 12 hours.
    I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
    Leaving the power off overnight seems to have fixed it.
    Nov 09, 2007 | Dacor Millennia MOV130 Electric Single...
    F2 error code
    Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
    Nov 18, 2006 | GE JGRP17 Gas Single Oven
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
