Compaq presario v3000
Hi, i am facing power on password in my laptop,is there any solution except changing the board.
pls reply
thank you
    Guru:
  • 859 Answers
If you know how to open a laptop and access the board you only need to disconnect the battery power connector from the board and leave it off for a minute or so.
Laptop batteries that keep the bios powered and retain the time/date and of course passowrds look different than a tower pc. They are usually a long round cigar shapped unit about 2-3 inches long with a power wire set and a connector that goes to your board. Naturally, the look and shape does vary a lot and so don't expect yours to look exactly as I described.
When you reconnect it and put the keyboard, etc.back on power up and enter Setup. You will need to reset the time and date and configuration options that suit your needs.
Hope this fixed ya!
Worldvet
Posted on May 15, 2008
How to clear compaq v3000 laptop password cmos battery open but nothing clear please help mp immideataly jumper not found
>Go to this link:
http://www.syschat.com/download120.html
click on the "DOWNLOAD" button to download a program for CMOS reset...
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | HP Compaq for Presario V3000 Motherboard
Facing Problem with compac v3000 no display
First see if any monitor will work, plugged in at back? If works, check, just isn't been LCD monitor has been disabled by a key command, then if NOT work, it is probably Video card. OR actual LCD, OR the LCD power supply and/or Inverter? may also be bad connection to MB? Or Broken ribbon in lid, or case. Faulty sleep open/close LCD switch? Try those.
Mar 02, 2010 | Compaq Presario 2580US Notebook
COMPAQ V3000 AMD SEMPRON COPROCESSOR PROBLEM
If your v3000 only shows leds but no video you need to replace your GPU(graphics processor) Hp has an active recall for this problem for certains models, you can check if your v3000 qualyfing for this recall in ww.hp.com
The manner that we resolve this issue:
you need to remove your MoBo completely from your laptop, remove your heatsink and coller from your Cpu/Gpu, with a heat gun(similar to hair dryer) reheat your gpu, this will cause that your gpu re-soldering and will function very well.
If you think this is so hard to you you can send your laptop to: VCRTECH
10001 buckwood Av. 79925 El Paso Tx
We repair your laptop in 2-3 business days and we charge $80 usd for this repair.
Thanks
vcrtech
www.vcrtech.com
support@vcrtech.com
vcrtech@hotmail.com
Please give me your feedback
Apr 21, 2009 | HP Compaq Presario V3000T Notebook
I m looking for sound driver for presario v3000 for xp service pack 2
Here is the download page for the v3000:
V3000 Downloads
Note that there is a different driver for AMD.
If you need additional help with downloading, just commment back.
Mar 05, 2009 | Compaq Computers & Internet
Compaq presario v3000 laptop
www.hp.com
in locate product type
laptop v3000
then click next choose your laptop type ( v3000 )
and options will appear for
software downloads other options are
solve problem
or setup install
please let me know
Feb 17, 2009 | Compaq Creative Sound Blaster PCI 128...
I need lan driver for v3000 laptop
There are several versions of a Presario V3000, nevertheless, pls try here and select your model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 11, 2008 | Computers & Internet
Presario v3000
Hi Jan, you can try removing the RTC battery for 5 minutes and see if that clears the password.
You can do this by turning the laptop upsidedown with the hinges away from you. Next remove the main battery and unplug your laptop from the wall.
Now you'll need to remove the hard drive access panel its a large rectangular panel located near the bottom right corner of the laptop. Once the panel is removed you'll see your hard drive and to the left of the hard drive you should see the battery it will have two wires coming off and going into a plug on the board. Unplug the battery from the board and wait 5 mins, then plug it back in.
Your password should now be cleared.
May 16, 2008 | Computers & Internet
Presario v3000
one way is bypassing. which can be done at chip level servicing only.
else there is a option like we can use any tool like ERD.. but we cant assure that u will get solved by that method.
only sure shot method is chip level servicing.
so u should take it to company(if with in warranty) else take it to some local service centers.
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
